      03-27-2019, 06:07 PM   #1
wyshyvanuk
Drives: 2008 Z4 MR
Valve Adjustment
Hi. I'm about to adjust the valve clearances on a 2008 Z4 M Roadster. I'll need to slowly spin the engine at the crankshaft as part of the valve adjustment procedure. To get access to the crankshaft nut, am I correct that the wide black plastic "cover" at the front of the engine, and the electric fan, both need to be removed? Also, while I'm here, am I also correct that turning that crankshaft nut clockwise (from the passenger side to the driver side) is the correct direction?
Thanks for your help!!
Ted
      03-27-2019, 06:15 PM   #2
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Ted
Just remove the intake and you'll have room to access. Clockwise is the correct direction.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      03-27-2019, 07:32 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
^WHS, but I do pull the fan cover and fan. Pretty easy to do and gives you loads of space.
      03-28-2019, 09:52 AM   #4
wyshyvanuk
Drives: 2008 Z4 MR
Thank you, gentlemen!!
      04-03-2019, 06:58 PM   #5
jmillet
jmillet's Avatar
64
Instead of paying $60 for the special crankshaft socket buy this Water Pump Shaft Nut for $10 https://www.bimmerworld.com/Cooling/...Shaft-Nut.html
Install this nut and leave on.
BTW no need to remove the fan shroud.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      04-03-2019, 08:06 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
No special crankshaft socket needed on the Z4.
That's for the M3 with mechanical fan.
Just need a whopping metric socket.
I can't remember what size. 30 or 32mm, maybe. Somebody please chime in.
      04-10-2019, 07:14 PM   #7
wyshyvanuk
Drives: 2008 Z4 MR
I'll be diving in next week. Girlfriend has re-directed my efforts to re-modeling the backyard.
      04-13-2019, 05:12 PM   #8
Rick F.
Rick F.'s Avatar
946
Drives: 2013 BMW 335i cabriolet
Ted,
As an alternative to turning the engine with a wrench on the crankshaft nut, you could put it in sixth gear and push the car by hand. (Unless it's an automatic, of course.)
Good luck with the adjustment!
Rick F.
For all my trips, check out http://rsftripreporter.net.
      04-19-2019, 03:27 PM   #9
wyshyvanuk
Drives: 2008 Z4 MR
Socket needed for crankshaft is 32 mm. The adventure continues!!
StickMon636.00
      04-20-2019, 09:11 PM   #10
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
32mm socket.
StickMon636.00
