08-13-2012, 08:17 AM | #1 |
Rep 400
Can someone tell me what I just removed from my car?
Ever since the first day that I bought my car the battery drains pretty fast when it's left idle for a few days. When I was connecting the leads for a battery tender this is what I found connected to the positive terminal of the battery.
After taking apart the right side trim, I found the other end of the wire double stick tapped above the wheel arch. It is grounded using a screw on the rear right tail light and has what looks like an antenna wire that was threaded up under the headliner of the car. Here's what everything looks like when removed. Here's how electronics professionals install components in cars... Black tape will have to do for now, until I replace the cable. Can anybody tell me what I just removed. It doesn't have any "BMW" logos on it. It looks to me like the wire that is in the tubing is an antenna. So is this some sort of "lojack" transmitter or maybe a radar/laser jammer? I've also removed a black plastic box in front behind the bumper a few months ago. It had a loose wire that wasn't connected to anything. |
08-13-2012, 11:57 AM | #2 |
Rep 12,565
If there's no telephone plug connectors, most likely NOT laser jammers.
08-13-2012, 12:14 PM | #3 |
Retired Paratrooper
Rep 146
I have no clue what that is, but if you keep having problems with the battery draining fast after removing that mess, get the alternator tested to see if it has a bad diode. You shouldn't need a battery tender for just a few days of not running.
08-13-2012, 02:51 PM | #4 |
Rep 439
You're probably on the right track with the LoJack, or possibly GPS position monitoring. Considering it doesn't have any interface with the vehicle other than the power/ground wiring, anything it is doing, it is doing wirelessly. A tracking device would seem likely.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS |
08-13-2012, 03:34 PM | #5 | ||
Rep 400
It's definitely not getting re-installed until I find out that it is necessary. Judging by the wiring job someone put it in for a particular reason (that is not benefiting me). |
08-13-2012, 04:58 PM | #6 |
Rep 987
Wow that is a GHETTO install. Home Depot has some good thick shrink wrap that will cover that open area.
As far as the fuse... it looks like the fuse used to go to that black box but the fuse blew and so the person just bypassed it with limited tools by cutting the wire and sticking it into the red power wire. It seems he only had a steak knife and electrical tape on hand. Last edited by Jumbosock; 08-13-2012 at 05:04 PM.. |
08-13-2012, 05:39 PM | #7 |
Rep 400
Good idea, I'll be sure to stop by home depot tonight.
There were a couple of drops of solder on that wire, so they had more than the steak knife and electrical tape. Still Ghetto. |
08-13-2012, 05:50 PM | #8 |
Rep 11,667
Holy schit.....
What a great install!
08-13-2012, 10:51 PM | #10 | |
Retired Paratrooper
Rep 146
The Russian version must be a lot cruder install than the ones the FBI got caught using a couple years ago. You should know within the next 24 hrs whose it was |
08-14-2012, 01:02 PM | #12 |
Rep 280
It does look like there is a serial connector under the cap opposite from the power wires.
Betcha the prior owner had some trust issues. |
08-14-2012, 01:09 PM | #13 | |||
Rep 400
Here is the final install of my new battery, the old one had a bad cell and was six years old. Complete with shrink wrap. |
