View Poll Results: What Rod bearing did you use or going to use? | |||
Original Genuine BMW Rod Bearings | 8 | 29.63% | |
WPC Treated Genuine BMW Rod Bearings | 13 | 48.15% | |
VAC Performance Coated Rod Bearing | 4 | 14.81% | |
Other | 2 | 7.41% | |
Voters: 27. You may not vote on this poll |
02-03-2020, 08:39 PM | #1 |
Rep 1,483
Drives: 09 E91 328i & 07 E86 M
Which Rod Bearing did you use?
So going to be doing the rod bearing in the coupe next month and wondered which bearing you guys used. I was planning to do the WPC treated bearings but my mechanic recommended the VAC Coated. Looks like the VAC kit is $480 with the ARP bolts and the WPC kit with ARP bolts is $600. I started to read about the difference between the 2 and honestly I'm more confused now than before. I know it comes down to opinion so what yours?
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter |
02-04-2020, 06:20 AM | #2 |
Rep 23
I need to know as well. I read alot too and it looks like the VAC bearings are pretty tough as some supercharged cars showing no wear at all after 20-30k km. They are also the best value but whats an extra 100-200$ for peace of mind if other bearings are better...
I hope others share their experiences |
02-04-2020, 08:40 AM | #3 |
Rep 264
Not to complicate the matter further.....
I have not done mine yet FWIW, but I know a lot of the local car club guys with e46 and e92 M3s have replaced theirs with BE bearings. However, a not insignificant number of them also swear by the OEM ones since a) aftermarket ones provide a false sense of security and b) you keep tabs on your oil reports with OEM bearings, and are more likely to catch an issue. An opinion on which bearing to use is like an asshole. Everyone has one! haha
2017 M2 - Camber Hubs, MPE, and some other goodies 2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s 2004 Z4 3.0i - Gone, but not forgotten! |
02-04-2020, 09:51 AM | #4 | |
Rep 2,860
My vote is OE or WPC treated OE bearings. I'm against any added coatings as those will reduce the clearance on the already tight tolerance that is on our engine. The other issue I have with VAC or other coated bearings is the material used - what is it? You'll probably lose the use of oil analysis to look for wear because you don't know what to look for - it will probably no longer be lead! OP, if cost is an issue, ACL is a good alternative to OE => https://store.langracing.com/acl-rod...mw-e46-m3-s54/ Last edited by XMetal; 02-06-2020 at 12:35 PM.. |
02-06-2020, 09:21 AM | #6 |
salty cowboys fan
6155
Rep 3,402
I can’t remember off the top of my head what I bought, but I’m not convinced it matters so much. I’ve accepted that these are basically a wear item, and will need to come out before too long anyway just out of prudence. The state of my OE’s was terrifying lol
02-06-2020, 09:25 AM | #7 |
Get off my lawn
932
Rep 1,158
Drives: 6MT
When did folks do this? I am approaching 84K miles and the car is tracked 3-4 days a year, budgeting for a VANOS and rod bearing overhaul soon...
02-06-2020, 11:46 AM | #8 | ||
Rep 2,860
02-06-2020, 05:03 PM | #9 | |
Rep 382
https://www.bimmerpost.com/forums/sh...php?p=24477227 |
02-06-2020, 09:59 PM | #10 |
Rep 135
And mine at 120+k. Lots of easy highway miles by the previous owner.
I’m in the WPC camp based on my Indy tech’s reco. https://www.zpost.com/forums/showpos...6&postcount=11
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i |
02-07-2020, 10:50 AM | #11 | |
salty cowboys fan
6155
Rep 3,402
02-07-2020, 11:30 AM | #12 |
Get off my lawn
932
Rep 1,158
Drives: 6MT
Looks like it is time to start sending Blackstone Labs samples at oil changes...
02-07-2020, 11:53 AM | #13 |
Rep 2,860
If you have no prior history or oil analysis data, doing one right now won't be much of help. If you read my thread, you will understand why. At your mileage and usage, I would just bite the bullet and change the bearings. Otherwise, you're just pressing your luck at this point - IMHO.
86Zed932.00 JimBob0047268.50 |
02-07-2020, 12:07 PM | #14 | |
Get off my lawn
932
Rep 1,158
Drives: 6MT
Truth be told the pictured painted online and what I hear from race/performance shops surveying 100's of S54 engine cars could not be more different. Outfits and people I trust are less inclined to jump way out front of this issue with preventative maintenance at low miles. As my mileage increases my comfort is certainly wearing thinner and thinner. |
02-20-2020, 03:35 PM | #15 |
Rep 64
I am going to go with BE or WPC because these have copper core so Blackstone can pick up the issue more accurately. I believe BE bearing was designed for s65 and s85 to fix the bearing clearance issue. Some people pointed out the bearing issue on the S54 isn't its tight clearance but its small size. So regardless of what bearings we use, the only surefire way is either mod the crank and use big bearings, or keep and eye out and replace them every now and then. I am going with the latter.
I am planning to use the ecs be rod bearing kit or the ecs wpc rod bearing kit. The oil filter looks shitty. I need to look into it. Last edited by Intentional Brown Stain; 02-20-2020 at 03:49 PM.. |
12-13-2020, 10:55 AM | #18 |
Rep 2,860
Those look pretty bad for 50K miles. What year is your car? I'm starting to conclude that the latter years are worst with bearings, which is the opposite of my original assumption - perhaps laxing on the assembly specs in the latter years of productions?
12-13-2020, 10:57 AM | #19 |
Rep 433
2006 M Roadster
12-14-2020, 10:53 AM | #20 |
Rep 50
I went with WPC treated bearings. These are my original bearings after being replaced with 140k miles on them, I've seen worse with less miles on them.
I also don't think there's enough data out there to conclude which option is better than the other. Is anyone on their 3rd set of bearings to see what the 2nd set looked like after x amount of miles? |
12-14-2020, 12:11 PM | #21 |
Rep 12,305
Went with OEM everything. Saw a few threads were guys have tried aftermarket, and it still showed "some" wear second time around.
I've just accepted that this is going to be an item I keep replacing throughout the lifetime of the car. Luckily, I don't drive the car that often it's OK.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
