      07-02-2020, 07:48 AM   #1
kyriian
kyriian's Avatar
884
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
Turn signal bulb
I have a hard time finding anyone posting this so hopefully someone can offer some insight
One of my 4 turn signal bulbs burned out a few days ago, (causing hyperflash).
After some research, seems like the turn signal bulbs are the size 64136, all the bulbs I have found so far seems to be clear although I do not know if they glow amber. The ones in my headlights are likely original and look amber.
So the question is, was the original bulbs supersceded by clear ones that glow amber? I need to know if I need to buy one bulb or replace all 4
I could look into an LED, but I am not comfortable adding a flasher unit, unless someone has done this
Also, what's with the price of these, BMW Canada wanted 30 f**king bucks for ONE tiny bulb
Revolution of our Times
I will return to the track, one day.
      07-02-2020, 11:28 AM   #2
Clearancediver
Drives: 2004 Z4
Look at realoem.com to see if they are superceeded
Sent from my smart phone...
      07-02-2020, 02:04 PM   #3
kyriian
kyriian's Avatar
884
2014 BMW X5  [0.00]
it was supersceeded, the question is, did they change to a clear bulb that turns amber when lit or did it stays an amber bulb.
Dealer gave me a quote for 1 stinking bulb... 39 bucks
      07-02-2020, 07:44 PM   #4
Clearancediver
Drives: 2004 Z4
I would ask the parts dept that question.
      07-02-2020, 11:06 PM   #5
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
The bulb in question you will replace is clear for the front turn signals, theres an outer amber glass bulb type housing part of the inside the headlight that will ultimately shine out amber.
      07-03-2020, 08:02 AM   #6
kyriian
kyriian's Avatar
884
2014 BMW X5  [0.00]
So that means I don't really need to get a OEM bulb then... Sylvania ones are listed for half the price, and won't need to replace all 4 then.
Awesome, thanks
