      04-12-2020, 08:01 AM   #1
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
upsizing 265 to 275
Hello folks
will upsizing of 235/35 -> 245/35 and 265/30 -> 275/30 give me a big comfort difference on 19" rims? my current setup feels like too stiff
      04-12-2020, 08:07 AM   #2
Murf993
Murf993's Avatar
3340
Drives: Porsche 911
I'm no expert but I don't think you'll notice the difference going to a wider tire. I had 19" on my Z4MC and those side walls are pretty short. I think if you want to soften the ride you'd probably have to go to an 18" rim, or softer suspension components.
      04-12-2020, 08:28 AM   #3
AK72
AK72's Avatar
its not about comfort only, I have my 10" rims and 265 looks odd on them, thats another reason for upsizing
      04-12-2020, 08:46 AM   #4
Murf993
Murf993's Avatar
3340
Drives: Porsche 911
So it sounds like it's not about comfort at all and about how the wider tires would look on your rims. I can't comment directly on that without seeing what you've got.
https://www.tyresizecalculator.com/c...rim-size-chart
AK72106.00
      04-12-2020, 09:12 AM   #5
maupineda
Drives: E86 Z4MC
Hello folks
you will only gain 3mm on tire sidewall height, not much TBH, but it may help. is best if you go for high-end tires, like MPS4S or F1 Asymmetric 3/5.
I learned my lesson too late as I had bought my tires already, I went back to OE sizes and went with a tire that is too stiff on the sidewall, so the change from the 19s to the 18s was not significant in my case even when I added a significant amount of sidewall height.
I was running Falken on the 19s and Now Potenza S007A, which is a good tire and much better to the budget Falken subjectively, but stiffer. On the upside it makes the car feel more direct.
Whatever you do, go with a good tire even if you need to budget up
AK72106.00
      04-12-2020, 09:51 AM   #6
AK72
AK72's Avatar
please take a look at https://www.zpost.com/forums/showthr...2#post26001462
post #2050 my rear tires are too small for my rims but I got this way and now trying to fix it
      04-12-2020, 09:52 AM   #7
Murf993
Murf993's Avatar
3340
Drives: Porsche 911
They do look too narrow for those rims.
      04-12-2020, 10:32 AM   #8
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2008 Z4M Coupe  [0.00]
2004 X5  [3.50]
OP, are you running 10" wide wheels on all 4 corners? If so, that 235 or even 245 are still too narrow for the 10" wheel.
The rear, especially looked stretched in your post. I don't remember 275 on a 10" wide wheel being that stretched, so may be going to 275 will help a bit. As "maupineda" indicated, tire is a factor too - not all 265/30 have the same treadwidth. Some have more squarish shoulders than others. I think 285/30/19 is best on a 10" wide wheel. Even my 275/30/19 Conti's on 9.5" wide wheel have a tiny bit stretch, which I think can be fixed going to MPS4s
      04-13-2020, 06:06 AM   #9
AK72
AK72's Avatar
M359s are 9" fronts 10" rear
I don't think that I can fit 285 in my car
Thanks
      04-13-2020, 07:02 AM   #10
Murf993
Murf993's Avatar
3340
Drives: Porsche 911
Unless of course you're going for the "stretched tire" look, I hear some folks love it.
      04-14-2020, 08:16 AM   #11
AK72
AK72's Avatar
they not as bad as you think
Murf9933339.50
      04-15-2020, 10:33 AM   #12
maupineda
Drives: E86 Z4MC
I think this is also because of tire design. Tires with wider shoulder design won’t look as stretch. 265 seems to not be uncommon with 10in wheels
AK72106.00
      04-21-2020, 12:19 AM   #13
Cyclops
Cyclops's Avatar
Drives: 09 E91 328i & 07 E86 M
Esthetically I think your biggest issue is the wheel gap. Also, a different brand of tire will have different sidewalls design, so running a 275 Continental, Michelin, Dunlop, Falcon, Etc will all yield different results as some are more square. What is the offset on the rear?
I'm running a 275/30 Firestone Firehawk Indy 500 on a 19x10 ET 38 with a 15m space. I rub the outside face of the tire under really hard compression (on track only) so going down to a 12 or 10mm spacer will possibly fix the outside rub on this tire but not sure if I'll rub on the inside.
PS I have a set of H&R coilovers I used for about 10k km if interested.
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning - Instagram ->@e91kiter
      04-22-2020, 12:27 PM   #14
AK72
AK72's Avatar
Maybe you can guys suggest me narrowest 285 30 19 tires by brand model?
      04-22-2020, 12:58 PM   #15
dbarton62
Drives: 04ZR 3.0 6 speed VF SC
AK click on any tire and hit specs on the next page.
Compare the section width and the measured rim width, it tells the story of the theoretical bulge in a particular tire.
https://www.tirerack.com/tires/TireS...earDiameter=17
Intercooled Vortech V3Si, custom ducting, 2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial BPV,Ceramic header, magnaflow section 1, SS race muffler, megan mounts,42 design catch can, CDV delete ,custom strut bar,3.64LSD, H&R bars, Hotchkis links.ST coils,Koni Yellows. Megan camber arms. Carbon interior, CF Aero.APEX
      04-22-2020, 10:07 PM   #16
AK72
AK72's Avatar
Thanks David I will take a look
      04-24-2020, 05:05 AM   #17
AK72
AK72's Avatar
Attachment 2290504
Attachment 2290505
M359 wheels specs
Front Wheels - 19x9" ET31
Rear Wheels - 19x10" ET25
      07-01-2020, 06:53 AM   #18
AK72
AK72's Avatar
I guess nobody tried before but I have successfully Installed 285 30 19 Indy 500 on my rear wheels with no Issues
      07-04-2020, 12:14 PM   #19
HBC
Drives: BMW Z4M
Too hot outside today to do anything outside so I'm looking at what mods I want to do on my Z4MR and it seems that on both the exhaust and rim/tire threads, you have done exactly what I want to do. Where did you buy your rims or did they come with the car when you purchased it? Looks real nice btw.
      07-05-2020, 06:58 AM   #20
AK72
AK72's Avatar
I purchased them from local guy, BMW OE M359s hard to get and they pricey so I would suggest you to go with avant garde rims
