      07-29-2019, 10:54 AM   #1
nadaclue
Drives: Urban Green 2003 3.0
Ford Mustang alternative to BMW soft top motor and pump
This is buried in various threads across Z4 forums, but I feel it deserves its own attention. The going rate for a bmw soft top motor and pump is $650 at the time I'm typing this, but there is a Ford alternative that works just as well. I recently relocated my motor and pump to the trunk using the Mustang part as follows, and it works great and is faster at raising and lowering than stock:
I just finished up my roof top motor relocation this weekend as well, I utilized the Ford Mustang motor/pump assembly too.
I'm attaching pictures of the pump assembly I used in case it helps other people out. I received the assembly with some of the wiring attached, including a disconnect so I reused that as well.
Some basic info on the pump I used:
  • Purchased for $180 off ebay.
  • It was listed being for 2008-2014 Ford Mustang.
  • Made by Hoerbiger (same as the Z4).
  • Pump assembly showed part numbers S109024 and HB80069-002P.
  • Electric motor shows part numbers 3M5042, 1090069, and HB80006-019C.
  • The fluid reservoir is about 2x the size of the BMW one, but they're interchangeable so I put the BMW reservoir on the Ford pump.
  • For wiring, Mustang red to BMW green/grey and Mustang yellow to BMW blue/grey.
  • The banjo bolts on the mustang pump are the same size as the BMW, however the inlet/outlets are on the opposite side. Meaning the holes in the bolts are on the bottom when screwed in instead of the top. I'm not sure if this matters but I reused the BMW bolts just in case.
  • The pump outlets were labeled 11/13 on one and 12/14. This runs backwards from BMW's setup (at least for my 2003)! I initially plumbed it per the numbering on the pump and it ran in reverse, the open button closed and vice versa. So I had to switch the hydraulic lines so the 11/13 were attached to the pump at 12/14 position, and the bmw lines 12/14 were at the 11/13 position on the pump. Once done, it runs correctly.
kaybat55.00
      10-01-2019, 08:17 PM   #2
SD ///M4
///Multiple
SD ///M4's Avatar
I can't believe that it's been over 2 months and no one has commented on your post. This is excellent news for anyone who needs or may need to replace their OEM pump.
Can you post more pictures of how you mounted it in the trunk? Possible wiring/plumbing diagram?
      03-01-2020, 02:00 PM   #3
Woody99
Drives: 2008 BMW Z4 si
Mustang pump to BMW Z4
good work and a money saver.
      03-01-2020, 03:35 PM   #4
Drives: Z4M, X3 35i, i3 REx
Btw were you able to relocate the pump without taking the top out? Seems like there’s a lot of info on the boards suggesting it’s possible but no definitive DIY. And I don’t see that shop in Europe who does this offering their trade secrets anytime soon.
      03-02-2020, 07:56 PM   #5
deemo319
deemo319's Avatar
Drives: BMW
I really need to do this with help from Don.
kaybat55.00
      03-06-2020, 09:29 AM   #6
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
Cool news. I didn't know about this
      03-10-2020, 04:43 PM   #7
mas3423
Drives: BMW Z4
Send a message via AIM to mas3423
Great find! I am in the processing of sourcing one of these motors/pumps. This might be a dumb question, do they come with fluid already in the tank, or do we have to add it? The one I found, is missing the hydraulic line bolts and the tank looks empty. They are asking $125 for this.
19" Beyern Mesh Wheels / Dinan Exhaust / Dinan Stage 2 Software / AFE Intake / Umnitza LED License Plate Bulbs / Apexcone 3000k HID Fogs / Yellow Laminex / ZHP Short Shift Knob / Color Matched Stubby Antenna / 35% Tint / Valentine One Radar Detector
      05-21-2020, 09:09 PM   #8
farco
Drives: z4, 335, X5, X3,
BMW Z4
Hi
to replace the motor you have to take top off if you want to relocate the motor to trunk?
where did you mount it in the trunk?
      05-21-2020, 09:45 PM   #9
mas3423
Drives: BMW Z4
I successfully finished the job last week. It it weren't for the excellent resources online, this would have not been possible. Huge thanks to Shipkiller for the incredible instructions. As expected the OEM motor was soaking wet and corroded. I am extremely happy with the replacement Mustang motor. It is very fast at opening and closing, and was a fraction of the cost of the BMW part. It even came with a bracket to mount it on. Relocating to the motor to the trunk was very simple, and did not require any additional wiring or extensions. My replacement motor/pump already had plenty of hydraulic fluid in the tank, so I did not need to add.
Just to correct the original post, reversing the positive and negative terminals on the motor, will either cause the top to open or close. Not reversing the hydraulic lines. So if you press the open button and the top closes, just reverse the positive and negative terminals.
If anyone has any questions, I would be happy to help.
      05-27-2020, 09:00 AM   #10
cjmahone66
Drives: 2003 BMW Z4 2.5i STauto
very nice, thanks for sharing. wish i had known about this motor option a couple years ago.
      06-26-2020, 01:37 PM   #11
rsutoratosu
Drives: Z4 3.0i
Lmk when I can come over and work on my broken top
-Roranji
