11-09-2008, 03:30 AM | #23 |
Rep 230
In addition to most of the good advice, I would suggest doing some more compound exercises. If your goal is to improve your PT scores, you need to realize that your muscles work in tandem with one another. Large, complex motions will help out overall. I usually throw in something like this into my routine, maybe once or twice a week:
Grab a straight bar and throw on around 50lbs, then place on the floor in front of you and do the following routine one complete motion after the other, no rest: 1) 1 deadlift (up to your knees and back to the floor) 2) 1 bent over row (lift again from the floor, do bent over row and return to starting position for the row) 3) clean (jerk? snatch? can never remember the term) the bar to your chest 4) do a front squat. same as a normal squat, but with the bar resting across your chest 5) press the bar over your head, and down behind your head on your shoulders 6) do a normal squat 7) step forward and do a lunge, one for each leg. 8) then do reverse lunges, one for each leg. 9) press again over your head, and then you are finished. Do like 3 sets of this, and you should be pretty exhausted afterwards. I like it becuase, again, while its fun to develop individual muscles, its good to work everything together and do really large compound exercises. |
11-09-2008, 03:39 AM | #25 |
Rep 230
Im curious tho, Doug, why do you hit chest and tris on the same day? You work out the tris as a minor muscle when you do chest exercises, and when you target them individually aren't they are already tired from the chest stuff?
11-09-2008, 09:49 AM | #26 | |
Rep 57
also.... shouldnt the op stay away from "cleaning" excercises as he currently has a shoulder injury? just a thought |
11-09-2008, 11:30 AM | #27 |
dork
38
Rep 477
Pyramiding worked wonders for me (you should look into that)
I sorta glanced over this thread, but Im sure its been said.. you need to hit your chest a lot harder Decline/Incline/Flat. Dumbells work wonders over Barbells especially when your trying to build your stabilizers muscles, but mix it up. Dumbell fly's are awsome as well Cable crossovers are awsome as a finisher. If you can afford supplements, look into the Universal/Animal line, their shit is a little on the expensive side, but i've had great results with them, and they have an awsome rep Animal Pump - pre workout Torrent - Post workout |
11-09-2008, 02:33 PM | #28 |
Rep 57
i had succes with the animal products.... but i got too edgy and the pills were getting to be a PITA. im using controlled labs supps right now..... they work great
11-09-2008, 03:36 PM | #29 |
dork
38
Rep 477
I also use Purple Wrath from controlled...its a staple as well. White flood got me a little edgy and sometimes sent me into the toilet before I worked out. I use Orange Triad and think its an outstanding multi. Glycergrow is kinda neat as well.
11-09-2008, 03:41 PM | #30 | ||
Fapmin
399
Rep 2,660
Plus you could ask the same question about the Back/Bicep day. You're already working out the minor muscle on that day, so I see it as, why not work it out more? Quote:
11-09-2008, 09:58 PM | #31 |
Rep 516
11-09-2008, 10:01 PM | #32 |
Fapmin
399
Rep 2,660
11-09-2008, 10:54 PM | #33 |
Rep 170
Since you asked, here is my two cents:
Way too much focus on flat benching and curling. For someone who's benching in the mid 200's, you should be lat pulling 160+ for 10 reps. You really need to work on your shoulders, back, quads and hams. I would add the following lifts: 1) Incline dumbells or Military dumbell presses - start will low weight and work your way up due to shoulder injury 2) Deadlift 3) Squat 4) Power Cleans 5) Upright rows |
11-09-2008, 11:03 PM | #34 | |
Rep 516
11-10-2008, 10:59 AM | #35 | |
Rep 2,900
Chest/Tris: Add incline bench as well. Switch up and use dumbbells instead of barbell. Focus on form first, then weight. You have to work on getting your shoulder stronger, so use light weights. Dumbbell overhead extenstions. Cable pulldowns/pullovers Back/Bi: Pull-ups. Wide grip, shoulder width grip Various rows Dumbbell Curls: Hammer curls Inside Curls - to work the outer bi Outside curls - to work inner bi You HAVE TO add a shoulder day. You need to rehab your shoulder back to normal. And to add shoulderdefinition you don't have to use heavy weights. They respond to lighter weight high reps. Watch the huge guys at the gym, they typically use no more than 25lb dumbbells. Most of the guys I see with great shoulders definition use 20,15,10, and 5lbs. Abs: Leg Raises Decline crunches/situps You need to do legs. A must. And as has been said, add leg days and cardio. You have to get cardio Here's a ton of good excercises listed. http://www.bodybuilding.com/fun/wotw41.htm |
11-10-2008, 11:00 AM | #36 |
Rep 2,900
There's a website I've seen that details how to work the shoulder cuff. I'll find it and link it for you.
11-10-2008, 11:35 AM | #37 | |
Rep 57
i disagree with the use of incline bench in the op's case. incline bench is a great workout however, it can be very taxing on the shoulders. the op should lay off the shoulder as much as he can until it is healed and that slowly incorporate some shoulder movements. maybe some assistance exercises for the rotator cuff. decline bench will work your chest while working your shoulders minimally. personally, i think thats too many bicep exercises, if you hit your back hard with rows and pullups your biceps should also have been worked. Keep in mind that there is only ONE bicep. Im not a believer in the inner, lower, upper muscle idea which many people say about chest as well as biceps. Legs are a must and I think deadlifts are a must. |
11-10-2008, 01:50 PM | #38 |
Rep 2,900
Rotator Cuff excercies:
http://www.exrx.net/WeightExercises/...lRotation.html http://www.exrx.net/WeightExercises/...lRotation.html There's more out there, just gotta look for them. |
11-10-2008, 02:06 PM | #39 | |
Rep 2,900
There's nothing to believe as far as the inner, lower, upper, etc you mentioned. Look at the anatomy of the male body and there is an upper and lower chest. As well as different heads on the tricep. As far as working bi's, the different routines can have an affect on the different muscle fibers. I added the inner and outer curls to my routine and have noticed a difference in my biceps. Everyone's different though and won't see the same results. As is everyones reasoning for working out. I started going simply because I was feeling lethargic, as well as being scared for other hereditary reasons. Now trying to get a decent body is up there. May as well. I work one-two body parts a day. With a minimum of 2 days off. So working my bi's as much as I do is a non issue. It's only too much when the results become diminishing. So far, that's not happening. And I switch up my routine every 8-14 weeks. I'd look at adding some forearm curls/wrist curls to make your forearms pop. But I don't know what the OP's overall goal is. Not trying to argue with you. Just speaking on what I've experienced, as well as noting that everyones goals are different. What works for one person, may not work for another. It's all about trial and error. |
11-10-2008, 02:54 PM | #40 | |
Rep 57
thats the thing about workingout/bodybuilding/muscle building... it seems that different things work for different people... i respect your opinions |
11-10-2008, 03:18 PM | #41 |
Rep 2,900
11-11-2008, 10:19 AM | #42 |
Rep 516
Ok I have established that squats are not doable anymore. Did my typical free-weight 135lb 10 rep x 3 set and the thing that is the most sore is my fucken shoulder.
Anything that is going to put sudden trauma on my body is a no go for the workout, I'm thinking whatever it is going to be it has to be something that is slow repetition. Dead lifts, cleans, squats... anything of that nature is a no go. It may make a healthy body stronger but there is nothing strong about a guy with a blown shoulder. I can do push ups and light bench, prob decline but nothing incline. Flys are out too... |
