      04-12-2010, 12:47 PM   #1
Serious
1M advocate
Serious's Avatar
Drives: 2018 S4. 2011 M3. 2012 S1000RR
Recaro Pole Positions
These are out of my e46 m3, but I think the mounting is exactly the same for the MZ4 considering the stock seat bases are almost identical. Do your own research to confirm before buying though please!
Selling because my e46 m3 was wrecked and im moving to an mz4 coupe and need the $$$ cuz mz4's are expensive! I really wish I could keep them to put in the mz4 but sadly I can't.
For a fixed back racing seat these are by far the most comfortable seats I've experienced, they actually caused me less back ache and pain then my stock seats which were full power, heated, and lumbar.
As long as you aren't fat you should be able to still squeeze into the back with the seats as far forward as possible, (im 6'3 180 and can still slide into the back seats).
I also prefer the cloth pole positions to the leather versions because they tend to wear less, retain less heat in the summer, and they have more padding then the leather versions.
Seats come with speedware floor mounts, recaro sliders and side mounts. I also have an extra BMW passenger mat sensor. So this setup is pretty much plug and play into an e46 m3, just swap out your factory seat belt receptacle (no wire cutting required btw) and bolt the seats to the floor.
No rips, tears, scratches or blemishes to the seats, they don't show any noticeable wear.
New this setup is ~$2400 + shipping for everything. I'm looking for $1700 + $175 shipping.
Pics:
2012 BMW S1000RR
2011 BMW M3
      04-13-2010, 07:58 AM   #2
hansaysso
hansaysso's Avatar
Drives: 07 Z4MC, 93 RX7 FD3S
^ interested, OP, do you think i could check these out in person? i'm local. i'm out of the country and wont return till may 2nd, but if you still have these i'd love to pick them up
      04-13-2010, 10:01 AM   #3
Serious
1M advocate
Serious's Avatar
I may still have them by the time you're back, send me a PM closer to that time.
2012 BMW S1000RR
2011 BMW M3
      04-16-2010, 08:17 AM   #4
Master Apex
Drives: '17 F80 M3 '07 Z4M '06 E60M5
Does the rail fit Z4M?
Can the stock seatbelt buckle be used with this seat?
