BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > what are these error codes mean ?
      03-25-2015, 09:59 AM   #1
badsay
Drives: 1.16i M Sport
i have 2014 1.16i AT and dont understand this fault codes.
      03-25-2015, 03:26 PM   #2
fecurtis
Drives: 2014 BMW 335i M-Sport
http://www.ismotors.com/bmw-repair/bmw-fault-codes.html
P0811 - Excessive Clutch Slippage
Maybe that's what it is?
      03-25-2015, 03:34 PM   #3
badsay
Clutch slippage on torque converter automatic
Don't get it.
      03-25-2015, 06:42 PM   #4
Chihuahua
Chihuahua's Avatar
4075
Drives: E30 329iS, E65 Alpina B7
Don't get it.
Automatic transmissions have clutches too. Several of them.
      03-26-2015, 10:32 AM   #5
fecurtis
Don't get it.
An automatic transmission can have clutch slippage. It could also be a faulty sensor.
      03-26-2015, 01:17 PM   #6
Twixboy
Drives: '04 Z4 3.0i 6spd
A 2014 is still under warranty. Bring it to the dealer for diagnostics.
      05-29-2020, 03:56 AM   #7
dvdx95
Drives: F30 328i 2012 300+hp
Hello.
I would like to answer to this topic because i had the same error codes
The code 0811 - "Bonnet Open or Unlatched", i started my car with open bonnet and got this error once,
The code 0557 - "Rolling Possible, Secure Vehicle", i set "N" position on gearbox and i left from vehicle, didn't use handbrake and didnt switch gearbox to "P" position then i got this error.
I hope this will help anyone who have the same codes, you dont need to worry about anything.. (0811). this is NOT "Excessive Clutch Slippage".
If you want check other BMW error codes i recommend to use this website https://www.endtuning.com/ccidcodes.html
1addicts
