10-16-2021, 04:29 PM | #397 |
Rep 7,422
It would be funny if max left rbr and joined Mercedes, then all of a sudden Mercedes can do no wrong.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
10-16-2021, 04:34 PM | #398 |
Rep 5,426
Drives: Beige G31 40ix m sport
It may be a little unfair to tarnish all Red Bull fans with the same brush as Belgie & MRick, I think it's more Max that they have a hard on for, I don't recollect them posting like they unfortunately do now when S4b was at RB
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
10-16-2021, 04:42 PM | #399 | |
Rep 24,651
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick59977.50 |
10-16-2021, 04:45 PM | #400 |
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
I did limit it to a couple of RBR fans...
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
Chappers 715477.00 minn1914021.00 |
10-16-2021, 04:46 PM | #401 |
Rep 11,637
Absolutely spot on!!
10-16-2021, 04:57 PM | #402 | |
Rep 19,518
Montezomolo then Ferrari F1 boss has said that Lauda told him that Merc were building a hybrid since 2007 and Lauda didn't deny he told him that while he still lived. So let's look at it now with Austin coming up,Merc are up on performance and gov. body say it's fine, that in itself is highly questionable. |
Killed by Death12407.00 ///M Power-Belgium63293.00 |
10-16-2021, 05:01 PM | #403 | |
Rep 19,518
10-16-2021, 05:07 PM | #404 | |
Rep 7,422
Again you're only twisting it to your own narrative, how do you know mercedes didn't have to pull back power previously to ensure their only 2 motors left in the pool didn't fail? How do you know if degredation didn't cause a drop off in power? You don't and thus you start to speculate. Redbull had a huge power jump mid season that was suspect - the FIA responded and said it was fine. How come you aren't all enraged by that? That's right, because you're so insanely biased you cannot see the world clearly.
10-16-2021, 05:11 PM | #405 |
Rep 5,426
I meant that I believe it's Max that they idolise it just so happens that he drives for RB, something rather unhealthy in it all imho
G31 40ix M Sport
10-16-2021, 05:25 PM | #406 | |
Rep 7,422
Sure Mercedes have been working on a few upgrades, but apparently the majority of it was already done in silverstone and they just have a few bits here and there that were already done but not released such as the front wing.
10-16-2021, 05:25 PM | #407 |
Rep 11,637
That makes is even more creepy!!
10-16-2021, 05:28 PM | #408 | |
Rep 19,518
10-16-2021, 05:32 PM | #409 |
Rep 7,422
Which was all Mclaren's fault since they did it behind mercede's back - hence why mercedes left them..... This was well documented too...
Like I said when you rely on conspiracies you literally lash out to whatever suits your narrative regardless if it will hold traction or not, if it doesn't onto the next conspiracy.
10-16-2021, 05:33 PM | #410 |
Rep 7,422
Having a favorite driver is normal, making him a roll model is fine.
It becomes a problem when it starts to twist your view points and make it so that every bad thing that happens to him (or any event that doesn't favor him) the fault of some other out side force trying to get him.
10-16-2021, 06:08 PM | #411 |
Rep 5,426
I can't be bothered to trawl back through all their posts to find it but one of them posted a pic of Max sitting back in a suspiciously tight pair of shorts, for me that's when the penny dropped
G31 40ix M Sport
MKSixer34183.50 |
10-16-2021, 06:10 PM | #412 | |
Rep 19,518
10-16-2021, 06:36 PM | #413 | |
Rep 7,422
The engineer that got the documents were also a McLaren engineer, and in the end Mercedes were in the dark because they only made the engine not the chassis. In the end fines and punishments were issued, and Mercedes left McLaren as a result of what the chassis side did... So what does this have to do with Mercedes of today? The case went to court and the evidence was read and due justice was served. The only reason why you brought it up is because it fits your narrative, either way I don't really care to correct you. You're way too far gone.
10-16-2021, 06:54 PM | #414 | |
Rep 3,514
MB flexing down on one axis is OK (Vertical strakes or support could easily fix this movement) but FIA looks the other way! RB flexing on two axes is verboten (RB & others must redesign the rear wing)...No small task!!! Hypocrites!!!! |
///M Power-Belgium63293.00 M5Rick59977.50 |
10-16-2021, 07:02 PM | #415 | |
Rep 7,422
So at first RB's rear wing passed the test no problem, after a bunch of whining to the FIA they increased the load for the test and redbull failed. This means they pushed too far into the grey area. When retesting the merc front wing it still didn't fail any tests based on the parameters given - hence mercedes didn't push into that boundary as far as red bull did. There's no such thing as "looks away", if they didn't test the mercedes front wing as per the rule book then again redbull would have a slam dunk law suit. What likely occured is like I said before, they're in the grey area but there is still enough wiggle room because they didn't push it to the absolute limit. Thus mercedes still passes tests. In regards to what triggered the fia investigation, well mercedes likely played a butt ton of mind games with hamilton's radio call then launched a formal complaint to the FIA - IDK that's just how inter team politics works I guess. In the end the FIA did their tests and that's that.
10-16-2021, 07:05 PM | #416 | |
Rep 24,651
The only access to a Merc seat is to be a lap dog on a leash ! MAX's mission is to beat Mercedes to 5H1T. Hopefully HONDA can close the gap ASAP and the RB-16B is fast enough in coming 6 races . So actually your statement is funny ..
M5Rick59977.50 |
10-16-2021, 07:12 PM | #417 |
Rep 4,445
10-16-2021, 07:14 PM | #418 | |
Rep 3,514
MB doesn't pass the eye test and it's ignored! Again, I get what you are saying and respect your opinion but HATE the double standard IMHO...Good nite all |
M5Rick59977.50 ///M Power-Belgium63293.00 |
