      04-15-2010, 04:54 AM   #23
ryanchua
Z4MC Sapphire Black
Singapore
45
Drives: 570-4SL
Has anyone installed this yet?
Are there already defined bolt points?
Sorely missed:
Zeta le Z4M Coupe (2008-2012)
BMW.SG - Singapore's Ultimate BMW Enthusiast Community
      09-20-2010, 04:40 PM   #24
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
This looks mighty tasty
      09-20-2010, 09:32 PM   #25
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
I ended up going with a completely custom cage built by a local builder who's well known in the SCCA community. FYI. He felt the Wiechers cage a harness bar that offered no additional protection in the event of a roll over. He also didn't feel comfortable with the strength of the mount points they chose. And on the subject of it being a harness bar, the upward sloping of the horizontal bar to which harness attach avoids interference with the center compartment (as does mine, FWIW) but caused us to question if that has an effect on the harnesses. I don't know the answers to those questions but the mere posing of them is cause enough for me to want to stay away. Needless to say, he advised against it. Granted, he may be biased a bit, but I believe his assessments.
|www.onehotlap.com|Real People|Real Cars|
      09-20-2010, 11:45 PM   #26
mfanatic325
///M-fanatic
Taiwan
193
Interesting. So how much did the custom cage run u? Also, could u perhaps snap some shots so we may get an idea of where and how they're attached to car?
This is still a half-cage we're talking about? Or did u go all the way with it?
      01-16-2011, 05:13 PM   #27
wrose
Drives: 2007 Z4MC
2006 Z4M Roadster  [8.50]
2007 Z4MC  [0.00]
2005 X3  [0.00]
Hi
Do you have photos of the cage installed? I am interested in a 4-point roll bar for my M Coupe and maybe you can help me arrange it with the shop that did your cage.
Look forward to your reply
Wayne
      11-16-2021, 03:05 PM   #28
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
So does anyone know where to find a half cage for a coupe in North America?
      11-22-2021, 08:56 AM   #29
3GFX
3GFX's Avatar
Just updating some information for future searchers. Depending on your rulebook the Weichers probably won't work for classification due to the thin walls of the tubing. I emailed them and they won't substitute different size or grade tubing.
I've attached the dimensions for comparison and some local rulebook requirements to compare.
      11-22-2021, 05:28 PM   #30
dre99gsx
Drives: 1994 Toyota Supra
Hmm..
SCCA: Over 2699 lbs: 1.50 x .120, or 1.75 x 0.095, or 2.00 x 0.080"
NASA: 3001 - 4000lbs: 1.75" x .120
If I'm reading this correctly, SCCA would be legal...
      11-23-2021, 01:01 PM   #31
3GFX
3GFX's Avatar
Originally Posted by dre99gsx View Post
Hmm..
I found what you referenced:
file:///C:/Users/david/Downloads/GCR%20-%20January%202021as.pdf
Page 95
If a car is over 2700lbs they accept one of 3 tubing sizes (alloy or mild steel)
1.50 x .120
1.750 x .095
2.00 x .080
So by that standard the Weichers would meet the middle standard with its mild steel roll hoops.
      11-24-2021, 03:06 PM   #32
3GFX
3GFX's Avatar
Page 95
1.50 x .120
1.750 x .095
2.00 x .080
Update: The rearward stays are thinner both in material and diameter in all of Wiechers options. So it also does not meet SCCA standards. I emailed them to ask if they can provide an FIA certification example but they simply said no. So for those in North America with this half cage (or considering it) just a heads up.
