      11-29-2019, 03:24 PM   #1
2282
No CEL with DKF 100 cell HFC!
Just like the title says, I swapped out my 300 cell cat for the 100 cell and happy to report no CEL or codes. The one minor thing I did however was adding a pair of o2 spacers. So I can’t tell you if it’s needed or not but for the $15, may as well throw them on so you don’t have to get under the car twice.
      11-30-2019, 12:41 AM   #2
RossBMWZseries
Very nice man. Weird though how my CEL came on after 3 starts with DKF’s 300 cell cats. Switching those out to resonators once the car is out the shop.
Did you feel/hear any difference going from 300 to 100?
      11-30-2019, 02:14 AM   #3
2282
So I guess those o2 spacers are probably a must for you.
Yea very noticeable difference...
      11-30-2019, 08:18 AM   #4
maupineda
Drives: E86 Z4MC
hi there, my car came with DFK cats, which I don’t know if it is 100 or 300, but since my car is a road fun weekend car The foul smell is driving me nuts, are you noticing much difference in terms of smell between the two? I am actually removing the DFK and install a euro set of cats
      11-30-2019, 08:35 AM   #5
2282
With 300 no smell really. With 100’s I notice small amount during cold start up. You sure you don’t have resonators (i.e. not cats) as part of your DKF section 2?
      11-30-2019, 10:37 AM   #6
maupineda
Drives: E86 Z4MC
Nope, i have seen inside, they are cats. I have euro headers, so that maybe part of the issue.
      11-30-2019, 10:44 AM   #7
2282
I have Euro headers too... you sure you don't have a leak? Did you use new gaskets?
      12-05-2019, 09:09 AM   #8
Reborn_
Drives: 2007 BMW Z4MC
Got a link for those spacers?
      12-05-2019, 09:22 AM   #9
2282
Honestly so many to choose from on eBay but I just filtered for stainless and located within USA. Some have more restrictive opening than others so you may need to play around with that. I used the 2nd one...
https://www.ebay.com/itm/Oxygen-O2-S...YAAOSwyC1dyi6o
https://www.ebay.com/itm/Oxygen-O2-S...wAAOSwRY1dup7U
Reborn_298.00
      12-05-2019, 09:27 AM   #10
Reborn_
I just wanted to make sure I get the right thread size and pitch. Not sure how much variability there exists in o2 sensor threads but now I can buy that with zero research. Thank you!
      12-05-2019, 10:20 AM   #11
2282
It’s a standard fitting, they’re all the same
Reborn_298.00
      12-09-2019, 09:24 PM   #12
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Pics of DKF 100 cell and 300 cell cats attached. If you can see straight through them, they are probably 100 cell cats.
I'd estimate 75% of the fumes are removed with 100 cell cats. 300 cell remove 90-95% of the fumes. Check for leaks by looking for black "burn marks" on the exhaust near the connections, especially around the v-bands. You can also run your hands near the exhaust on cold start, feeling for leaks. Be careful; the exhaust heats up quickly, so don't physically touch anything. Start from the headers and work your way backwards towards the mufflers. Don't take longer than 10-15 seconds to feel for leaks, because the exhaust will get too hot.
      12-12-2019, 11:34 AM   #13
maupineda
Drives: E86 Z4MC
thanks for the photos, I am taking mine out next January to install the EU section 1, with global warming is my fair share to not modify the car in a way that is more harmful =P
