01-08-2019, 01:54 PM | #1 |
Rep 399
Suggestion on N52 headers
Hello Z folks
Since Ontario Canada have no more emission control I decide to upgrade headers on my engine. Need you advise on what should I go with for my N52 3.0si engine headers Brand, price. Best regards Last edited by AK72; 01-08-2019 at 06:50 PM.. |
01-08-2019, 02:39 PM | #2 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
Believe supersprint has the only real plug and play set avail for the si...best time to buy is Black Friday, huge discounts on super sprint items
01-08-2019, 05:35 PM | #3 | |
Rep 2,704
SS header not cheap.
01-08-2019, 05:42 PM | #4 |
Rep 399
01-08-2019, 05:46 PM | #6 |
Rep 399
01-08-2019, 06:13 PM | #7 | |
Rep 2,704
Not cheap but they have deals on occasionally also. I paid zero duties when I bought my section 2 and silencer https://old.schmiedmann.com/Z_series...age7.htm#18477
AK72286.00 |
01-08-2019, 06:45 PM | #8 |
636
Rep 3,124
Wow! Good for Ontario!
"Ontario is cancelling the Drive Clean passenger vehicle program and avoiding taxpayers costs up to $40 million a year." ... "While Drive Clean effectively reduced vehicle pollution, auto industry standards have significantly improved since the program was created in 1999 making this program no longer necessary." Too bad I'm in Ontario California.
01-09-2019, 06:57 AM | #9 |
E86 M Coupe
265
Rep 403
I have the supersprints on my N52 and they are crafted beautifully but they 100% do not come with flanges to mate to the rest of the cat back exhaust. I believe they were designed to be fitted with all supersprint exhaust components. So you still will need a bit a fab work to mate them to the complete exhaust system.
AK72286.00 |
01-09-2019, 08:40 AM | #10 | |
Rep 399
01-09-2019, 11:48 AM | #11 | |
Rep 2,704
You may not want to run catless. Could not stand the smell honestly when first putting the headers on. What I ended up doing is buying the Magnaflow section 1, cutting off the flanges and clamping slip flanges on to the ends to match the header flanges. From there I used the SS section 2 with 2 into 1 - 3" and silencer. https://www.hottexhaust.com/Magnaflow_51725 https://old.schmiedmann.com/Z_series...11.htm#1973240
AK72286.00 |
01-09-2019, 01:00 PM | #12 |
Rep 12,565
I had SS headers on my n52. Loved the bump in power but 2 things to keep in mind. Unless you spring for their section 1, it won’t mate up to your oe pipes in PnP way. Though it shouldn’t be difficult for any decent exhaust shop to fab something up.
Secondly, I don’t know if it was software or the physical location of the bungs but for longest time I had a fluctuating idle (and it definitely was not due to a vac leak). Ultimately I installed an o2 sim for separate reasons related to my tune but that actually eliminated most it not all of my idle issues. The odor from catless is mostly noticeable when you’re sitting at a light but if you retain your factory secondary cats (section 1), it shouldn’t be that bad. Can’t confirm because I went full catless day 1 but I’ve sat in E90’s that did have their secondaries still intact and it was really tolerable. Also for sound reasons alone I’d keep the secondaries else you’ll probably have some drone. |
AK72286.00 |
01-09-2019, 01:35 PM | #13 |
Rep 2,704
I should clarify that I have a 3.0i so different configuration than the 3.0si
01-13-2019, 10:14 AM | #15 |
Rep 399
01-13-2019, 03:35 PM | #16 |
Rep 1,130
I’m thinking of getting these headers for my E92 N52. $599 and from others’ posts in IG, they do a good job, high quality welds, sound good, and give a good power increase. Now sure if they’d fit the Z4.
2014 BMW X5 Sdrive35i F15
AK72286.00 |
01-14-2019, 09:31 AM | #18 |
Rep 399
