09-22-2019, 10:52 PM | #1 |
Rep 86
Drives: 3.0si Coupe
WTB LSD for non M manual 3.0SI
Looking for an LSD, Quaife or M Performance to fit my 2007 3.0SI coupe thats a manual.
09-24-2019, 04:35 PM | #2 |
dances with roads
4718
Rep 4,096
That will make your car almost perfect (still needs a hydraulic steering conversion, yes it is doable). Good luck!
Please let us know what the car is like post-LSD. I *almost* kept my 3.0si as opposed to the M car; they are different beasts, and the 3.0si has quite a few very compelling qualities. |
04-13-2020, 06:54 PM | #3 |
Rep 86
Drives: 3.0si Coupe
TTT
04-15-2020, 06:55 PM | #7 |
Rep 86
Drives: 3.0si Coupe
Yea, I'm likely to just get an MFactory new next spring if I don't come across a used one.
04-20-2020, 12:13 AM | #8 |
Rep 12,565
You may have better luck with the e46 crowd like e46fanatics
wdb4718.00 |
04-11-2021, 06:03 PM | #10 |
Rep 86
Drives: 3.0si Coupe
Bump
04-11-2021, 11:44 PM | #11 |
Rep 141
Hi, for anyone interested, I currently have my 3.0si coupe 6 speed on the lift ready to undergo an LSD conversion in the coming couple weeks. I’ve obtained an LSD from a E46 M3 (someone correct me if I’m wrong but I think they’re essentially the same as a Z4M one but the Z4M LSD weighs less than the E46 M3 one) and will be swapping that along with a Z4M driveshaft. I can update after its complete and may make somewhat of a DIY thread and what’s needed and how involved it is for anyone looking to do the same.
On a side note, I may also have a Z4M differential available for sale soon, or the E46 M3 one if I use the Z4M one instead. If anyone wants to purchase one right now I believe redline auto parts has a Z4M one available for around $1,000. Can be googled and found on their site. |
04-12-2021, 10:53 AM | #13 |
Rep 141
Most likely they will fit and bolt up as far as subframe goes but non M E46 diffs have variances. Such as 328i and 330i (I’m assuming they may be same as 2.5 & 3.0 older Z4s) diffs having different output flanges for driveshaft (4 bolt/6 bolt, the 3.0si Z4 is 4 bolt). Also I know 330i drive axles don’t bolt to the 328i diff. So depending on the differential it’s probably possible.
04-12-2021, 11:16 AM | #14 | |
1621
Rep 4,294
Powered by |
04-12-2021, 11:44 AM | #15 | |
Rep 141
04-12-2021, 12:28 PM | #16 |
Rep 2,704
Unless you use an M3 cradle the M3 diff will not fit your si or any other nonM
Edit, there used to be a website named Bokchoys.com. It had a complete listing of BMW diff ratios and which ones were exchangeable thorough out the ranges. It is unfortunately offline. I can report I have used several E46 and even an X3(E83) diff in my non M without issue, albeit they were not LSD.
wdb4718.00 |
04-12-2021, 03:06 PM | #17 | |
#buildnotbought
10837
Rep 4,891
The e46m3 had a redesign mid life, and the latter one is the same as the z4m diff. The earlier one is slightly different in design but not different in inner workings. Both diffs are speed actuated LSD's by means of pump that actuates a piston. It is afaik the e36m3 that had a ramp actuated LSD. That said, you cant fit a z4m/m3 diff to a non m z4 without swapping the complete rear axle and propshaft (or, at least from the rear axle you need the trailing arms, output shafts and subframe). Otherwise you have to make custom output shafts (and of course use the z4m rear axle subframe) Also the final drive ratio is very different.
wdb4718.00 |
04-14-2021, 03:11 AM | #18 |
1621
Rep 4,294
Hi Guido, it's not the same.. even the clutch packs are different.. ask me how I know. Z4m has 2 more clutch plates than the E46 m3 ones. Which is why now after consultation with RacingDiffs, they offer a specific z4m clutch kit and a separate E46 M3 clutch kit.
Your right about the ramps though, not sure what part of my ass I pulled that from, but the actual diff and how it's tightened up is also completely different.. Last edited by Vanne; 04-14-2021 at 03:19 AM.. |
04-14-2021, 07:54 AM | #19 | |
#buildnotbought
10837
Rep 4,891
The e46 m3 has been fitted with 2 different lsd's, an earlier style and a later style. Later style is I think fitted to e46 m3's from somewhere 2005 upwards, and all csl's
04-14-2021, 08:05 AM | #20 |
#buildnotbought
10837
Rep 4,891
Ok, check this video out.
This is not how it's done, virtually everything you can do wrong, is done wrong here
