08-15-2019, 08:01 AM | #486 |
Space Shuttle Door Gunner
6430
Rep 5,309
Pretty open for a 1957 house, yep. The main living areas (kitchen/dining/living/family room/hall bath) are basically a big circle with a double fireplace in the center of the house.
ETA -- House numbers going up on the carport this weekend, hopefully. Pics to follow. Last edited by hooligan_G01; 08-15-2019 at 09:48 AM.. |
08-16-2019, 02:43 PM | #487 |
Rep 1,189
08-18-2019, 04:08 PM | #488 |
6430
Rep 5,309
House numbers are up! Also a shot of the mailbox that I installed last month.
08-18-2019, 04:23 PM | #489 |
6430
Rep 5,309
Also the new entry door that went in last month, along with the Eames Hang It All and the light from West Elm that I hung the 2nd week we were in the house.
Excuse the beat up siding out the window. House painting happens at the end of the month. |
08-31-2019, 07:33 AM | #490 |
Rep 14,522
so while i'm waiting on finishing up the garage I've been working on the room in the basement. previous owners did a Mickey Mouse job on the whole room so I tore out the whole ceiling since it wasn't done right. decided were going to just paint it flat black to give it that industrial look in which I will continue this look throughout the basement as well. i'll take pictures of how the last owner did the ceiling to give you guys an idea of what i'm talking about. the basement is finished but i'm going to redo it. was gonna install wood framing around the walls to install drywall but after much research don't wanna have mold issues since if it's not done right that will be the first problem in the that'll arise. the basement will be more of a lounge with a 80" LED and pool table setup with probably a bar in the corner. still getting some ideas or if you guys have any suggestions that would be great!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
09-01-2019, 08:11 AM | #491 |
Rep 14,522
just finished my son's room with the Bamboo flooring. this was the last room upstairs that wasn't done. so many projects going on at once lol!
09-01-2019, 08:13 AM | #492 |
Rep 14,522
so here's the basement room where now the ceiling is completely removed
also ripped out the closet to open the room up. this will be more of a guest room and we have ideas on what our guest can do with their clothes. the closet to me felt like it was just put in just to say there's a closet but really was taking up valuable space
09-01-2019, 08:22 AM | #493 |
Rep 14,522
here's what i'll be using to paint the ceiling with. Wagner 2000 from Home Depot. had a coworker refer this as he had great results. i'll be using Behr flat black paint for the ceiling.
bosstones1154.00 |
09-01-2019, 08:26 AM | #494 |
Rep 14,522
so here's what the last owner did when he drywalled the ceiling. it's very bad. so annoying to look at. eventually once i'm done with the guest room is start working on the basement. ripping out all the ceiling. from there i'll end up running new can lights throughout on separate switches for each part of the room. it'll take some time getting some ideas as I visit showrooms and browsing images on Google. the room will eventually be a lounge with a big TV and a pool table. just a place to hangout with family and friends
09-01-2019, 12:19 PM | #496 |
Rep 14,522
Bricks will still be exposed but painted a different color. still keeping with the neutral colors so probably a gray. I think the bricks and the open ceiling will give it somewhat that industrial look
spazzyfry1234358.50 |
09-01-2019, 05:45 PM | #497 | |
Rep 1,543
How are you handling wire runs? I wasn't sure that I wanted to get those painted.
- Jeff
bosstones' flickr |
09-01-2019, 06:45 PM | #498 |
Rep 14,522
Wire runs will be painted as long as they're in romex sleeving. The can lights tho there a part inside that needs to be masked off according to my Electrician. I'll have to post a picture of that
bosstones1154.00 |
09-02-2019, 06:55 AM | #501 |
Rep 14,522
you just paint it. any duct work will be painted. for the grills I gotta find something that allows the grills to be mounted floating
edit: I think I know what you mean by HVAC are you talking about the flexible duct work? mine are all aluminum pipes/cylinders if that's the correct word for them
09-02-2019, 08:03 AM | #502 | |
Rep 755
lsturbointeg9158.50 |
09-02-2019, 08:08 AM | #503 | |
Rep 1,543
However, I have Cat6, RG6, and other low voltage are coming in from different points and converging in certain areas. Knowing me, I'll want to re-arrange some of the wiring at some point so I'm not sure if the paint will flake off and leave a mess or if some of the chems in the paint will have an effect on the outer jackets (I have horrible luck lol). I was thinking of maybe a solid cable trough or something. It'd also help protect the cabling from unwanted interference although the blue Cat6 jacket would look cool against the black background. Still, though, I'm interested in any lessons learned about tarping/masking that you run into. The job can get quite messy, quite quickly.
- Jeff
bosstones' flickr |
09-02-2019, 08:11 AM | #504 | |
Rep 14,522
09-02-2019, 08:14 AM | #505 | |
Rep 14,522
hooligan_G016430.00 bosstones1154.00 |
09-04-2019, 04:36 PM | #506 | |
Rep 2,524
bosstones1154.00 |
