      09-19-2019, 03:50 AM   #1
busin
Drives: z4 2003 3.0i SMG
WTB: ESS twin scroll for m54
looking for ESS kit for m54
      09-19-2019, 11:30 AM   #2
Steeler
Steeler's Avatar
2429
Will the SMG be up to the task?
      09-19-2019, 12:24 PM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
Internally the SMG is identical to the manual box gearwise and clutchwise.
So on that point there is no problem.
However I don't know how much clutch slip the SMG uses when shifting (but it always makes sense to lift the throttle when shifting )
      09-19-2019, 12:33 PM   #4
busin
Should not be a problem I've got fresh clutch
      09-19-2019, 12:53 PM   #5
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Already installed?
For safe measure you can use the e46 330i clutch disc. Thats 240mm instead of the OEM Z4 3.0i 228mm disc.
Bmwteo0.00
      09-19-2019, 04:06 PM   #6
busin
Originally Posted by GuidoK View Post
Already installed?
yep, I got a new original flywheel and 240mm clutch
works like a charm
as far as I know z4 3.0i SMG might have 240 clutch, but my car originally was a 2.5i so it had 228mm
      09-20-2019, 07:43 AM   #7
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Gonna be a tough kit to find. I bought the last new one from ESS in the spring. There was a Michigan car that had the kit. You'd almost be best to find a whole car with the kit installed.
      09-20-2019, 08:56 AM   #8
busin
Yes, I know as I've been looking for quite a while. Trouble is - my car is in Russia so purchasing a car for a kit in US or UK doesn't make any sense Although I've seen a nice US car for around $7k on this forum and a very cool car with TS2 in UK for 7к GBP.
At this point I'm ready to wait for as long as it takes, all other components are upgraded (BMW performance BBK from 135i, new roof fabric, repainted body, M hood and M bumpers, rest headlights and taillights, M seats, KW var3 suspension, M-factory LSD, revised SMG). Engine is the last thing that needs a proper upgrade ))
      09-23-2019, 08:10 AM   #9
3GFX
3GFX's Avatar
As much as I love my kit...for the budge an LS swap should be in consideration and now with the explosion of technology an electric motor conversion could also be worth looking into.
      10-03-2019, 07:16 AM   #10
busin
bump
      11-07-2019, 09:46 AM   #11
busin
bump
