09-19-2012, 07:39 PM | #67 | |
Rep 2,551
[QUOTE=mousitch;12702169]
10-01-2012, 10:37 PM | #68 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Recoded to the E85. Not dramatically impressed but the "wobble" bass in the rear is gone which is cool. Overall better. Less distortion. Noticed that the rear speakers have no bass whatsoever when fader turned all the way to rear. I assume this is the same for you, Pungo and MHeavC?
Wish we could read MhHeavNCs factory recoded amp and check his settings. Not sure what else there would be to change. Also I left the CID setting not active as I do not have nav. Wonder if that was correct. Everything seems to be working fine though. This thread is all win. Pungo, which module and setting did you use to turn off key dinger? No big deal if you cant remember. There are a huge number of parameters. |
10-01-2012, 11:01 PM | #69 | |
Rep 820
Drives: 2007 Z4MR silver grey
10-01-2012, 11:03 PM | #70 |
Dark Sider
129
Rep 1,779
Correct, Had it in the 2006 but really dont miss the console popping up and down all the time. I did dig my custom "m" start up screen but I'm glad its gone. Does suck not having an EQ. But as far as nav my iphone with Tom Tom is much better.
01-17-2013, 10:53 AM | #71 |
Rep 507
What are some good settings for the 7 bands on the EQ? I listen to mostly electronic type music when I'm driving but I don't like when ALL you hear is bass
SOLD: 2008 M Coupe
01-17-2013, 11:04 PM | #72 |
Rep 820
Assuming you have the factory amp coding in your coupe, I wouldn't know where to start with any graphic settings for you. The coupe and roadster are two different listening environments obviously, then factor in the fact that BMW changed the amps "factory EQ curve" for the coupe, and I'd probably screw you up with any recommendations. Maybe aother coupe owner can chime in for you.
02-08-2013, 02:37 PM | #73 | |
Rep 45
!! Does anyone know if this will work on a non-nav 10 speaker thx system? Or, if it's ok to simply change the e86 to e85 in the amp coding file? |
02-12-2013, 02:36 AM | #74 |
Rep 32
Hi all, I have bought the cable and having difficult to install the software. The recoding process seems to be quite difficult. Is there a step by step guide somewhere I can read?
02-12-2013, 06:15 AM | #75 | |
Rep 704
Drives: '08 MC
^This... I am unable to help with, a few others here probably could though.
02-16-2013, 04:38 PM | #76 | |
Rep 45
This was a huge improvement over my 08 coupe, no nav 10 speaker stock coding. It was worth figuring out ncs expert and buying the cable. Something to keep in mind... The stock coding damages your subwoofers. It's no different than any other speaker when you severely underpower it, they get muddy and distorted if this is done over a long period of time. I have a feeling that there is more improvement to be had over the e85 coding in the e86. |
02-18-2013, 09:13 AM | #77 |
Rep 45
Discovered a couple of things..
I no longer have access to the "DSP" settings My CD player won't play MP3 CDs Not the end of the world, and I'm sure it's something in the DSP coding, but something for everyone to be aware of. Also, if someone has the carver 10 speaker system, no nav, no 10 disc, from an e85 I would LOOOVE to have the DSP coding :-D |
02-18-2013, 06:16 PM | #78 | |
Rep 704
Drives: '08 MC
I would tend to agree that there is more improvement to be had out there. Is there any chance someone devises an 'ultimate and optimal' coding for an E86 Amp? The E86 clearly has the proper bones and hardware for a great stock system, and the E85 Amp coding or some variation of it is clearly the key to unlocking and unleashing it all. Well done!
02-18-2013, 06:18 PM | #79 |
Rep 2,138
Drives: Me
I recoded my amp to the E85 spec. but lost the DSP. I think I know how to get it back...
02-18-2013, 06:18 PM | #80 | |
Rep 704
Drives: '08 MC
Nice! Make that 4 re-codes. Is this approaching 'sticky' status yet? Ship - if you are involved... this will get fixed, I just know it. What results did you get overall?
02-20-2013, 12:24 PM | #81 |
Rep 299
When I get my coupe out in a few weeks, I'm gonna get a cable and try this. One of the first things I noticed on this car is how the stock sound system was pretty bad.. I think the base sound system in a chevy cobalt is better than this! I definitely don't want to change much, and having a cable is a very useful tool anyway, so this should be a good upgrade...
I don't ask a lot from a stock sound system, but getting distortion anything above half volume is pretty poor I think.
- Wes
2007 BMW M Coupe 2016 VW GTI |
02-20-2013, 01:08 PM | #82 | |
Rep 1,772
Drives: 2007 Z4M Coupe
GtMC, take the lead on this buddy! I will even buy the cable for you
02-20-2013, 04:39 PM | #83 |
Rep 704
Drives: '08 MC
Schmoupe,
There are enough of us around here to get this done and map it out. We are all still in the 'beta test' mode though... If Ship also had success, then that means Pungo, Ship, Mousitch, and Armatron all recoded with success that I know of, and Myself and mHeavnc also swapped out with success. Thats good enough for me. Elwesso & Abyss and a few others sound like thay are going to try it too. I'm down for helping you recode, lets do it when the cars come out of storage. If DSC_OFF still has any interior left in his soon to be track-only car, maybe he'd join us. you guys are smarter than me anyway.
02-20-2013, 04:49 PM | #84 |
Rep 2,138
Drives: Me
I am waiting for the delivery of the BMTechnic cable and software. Yes, I have a cable and have kludged together all the software and it all works BUT, I do get some non-critical errors sometimes when I use it.
So I purchased the BMTechnic package due to the fact that it seems to have folded all the 'free' BMW software into a nice package that seems to make using it easier. I joined their support forum site, http://forums.m3cutters.co.uk/index.php and Chris the owner, was VERY responsive to questions. When it gets here next week from the UK, I will let you all know. . |
02-22-2013, 05:23 AM | #86 | |
Rep 32
02-22-2013, 08:20 AM | #87 |
Rep 45
No kidding, if I had known how much better it was I would've taken the time to figure out the coding process years ago. IMHO it's worth taking the coding file to someone and paying them to code your car (especially once we get all of the different codings figured out... nav/no nav, DSP/no DSP, etc)
It is totally different.. Listening to the coding back to back it sounds like a completely new sound system. Even after a week of the 'new' coding I am still amazed every time I get in the car. It is a terrible shame that BMW screwed this up so badly from the factory as the speakers and amp sound really good when coded properly. I'm fairly particular about audio quality.. I have a full audioengine setup at home, etc etc, and am very satisfied with the 'new' coding in my e86. Again, I have a sinking feeling that even with the new coding many of you will need new subwoofers to get the full effect if you've tried to overcome the original coding issues by raising the bass level. Over time mine got noticeably muddier and muddier, I suspected it was due to amp coding so I had them replaced under warranty and they sounded a good bit better (but still extremely underpowered). After they were replaced I basically stopped listening to the stereo above quiet volumes to prevent the new subs from getting distorted. This is the same as home theater stuff... Take a 300 watt sub, power it with 100w and you will eventually damage the sub. Once this happens, even if you power it with 300w it's not the same. |
02-22-2013, 08:28 AM | #88 | |
Rep 45
After that, you need to update the daten files in ncs expert with v47 for the e86. Instructions should be with the download, it's basically just copying files around. After that, download the revtor profile for ncsexpert. That's really about it. There is a lot of extra stuff you can do if you want to get into coding.. ncs dummy, etc etc, but for simple amp coding just ncs expert is fine in my opinion. It will take quite a bit of reading. I'm a fairly technical person and I probably spent 6 hours or more last weekend getting it all setup. It is VERY easy to click the wrong button and screw up your car, so be sure you are following a guide that explains how to switch from write to read in ncs expert. |
