Go Back   ZPOST > Marketplace > Sponsors Classifieds
      03-29-2011, 12:05 PM   #1
brianexeas
brianexeas's Avatar
41
Drives: Voltex Widebody Evo
▀▄ eas | smartTV, smartTOP, and remoteKEY+
remoteKEY+
The remoteKEY project was something we introduced that dates back to 2007 on BMW 3-series models, which allowed specific convenience features such as the following:
- Remote window control
- Automatic door unlocking when ignition is turned off
- All windows can be closed One-Touch with the wide "All-Windows" button in the driver's door.
- Remote Fold-in Mirrors (if equipped)
As many already know, EU models seem to keep the cool features while US models feel a bit left out in the cold, likely due to liability concerns, among other matters. Rather than create a whole different module, we felt the features would be best suited integrated into an existing product.
Please see the included video clip:
Features:
- Full factory alarm confirmation chirp/flashing corners/blinking mirror/LED emulation
- Remote window control: One-Touch operation of the windows and sunroof with the original remote on all models (US and Euro)
- Automatic door unlocking when ignition is turned off. Avoid having to pull the door handles twice to get out
- Comfort windows: All windows can be closed One-Touch with the wide "All-Windows" button in the driver's door.
- User programmable: The module can be individually enabled or disabled. All settings are retained even if the car battery is disconnected.
- Remote Fold-in Mirrors (if equipped). remoteKEY will fold in your mirrors on alarm activation.
- Shop/Diagnose mode: If activated the module is completely passive, as if it was not installed at all. It becomes invisible to diagnostic tools.
- End user upgradeable via integrated USB port
Examples:
- Setting 1 allows remote operation of the windows and the sunroof by using the original factory remote fob: Press and hold UNLOCK for 2 seconds: Open all windows
- Press and hold LOCK for 2 seconds: Close all windows
- Press and hold UNLOCK for 5 seconds: Open windows and sunroof
- Press and hold LOCK for 5 seconds: Close windows and sunroof
For those equipped with Premium package, remoteKEY+ will fold in your mirrors on alarm activation. Feature can also be enabled with the door handle on CA-equipped models.
Enough said. Simply pull the interior door handle once to exit the vehicle.
User programmable
Even with the modules - not everyone is a "one size fits all" and all features may not be for everyone. The module can be individually enabled or disabled. All settings are retained even if the car battery is disconnected.
Shop/Diagnose mode
The module works seamlessly in the background, which is exactly what is intended. As an added precaution, Shop/Diagnose mode places remoteKEY+ into sleep mode making it completely passive, as if it was not installed at all and becoming 100% invisible to diagnostic tools.
USB Upgradeable
Especially useful as new features or updates are released, module does not need to be removed for upgrading - it can be performed by the end user.
Best of all, remoteKEY+ can be installed in approximately 45 minutes with no coding/activation required from your dealer. For those with leased vehicles, the module can easily be removed with no trace of installation.
Models Supported:
2008+ 1-series Coupe/Convertible
2006+ 3-series Coupe/Sedan (e90/e92 models only)
2007+ 3-series Convertible
smartTV
BMW upgraded their iDrive systems in 2009 (CIC) which allows for DVDs to be played using the in-dash DVD system. Unfortunately, we are greeted with a "For your safety, video is only available when parked" message and and blank screen.
TVinMOTION for 2009+ BMW iDrive
The smartTV module acts as a safety override so you can decide if you would like this option enabled or not, allowing full video while the vehicle is motion for passengers on those long trips.
Product Specifications:
- Fully E13 tested and certified: E13 10R-02 4133
- Ultra-low power standby mode (less than 0.1mA)
- InstallAID LED shows correct installation and status
- Intuitive Setup menu for easy customization
Product Features:
Enable video while vehicle is in motion
Overrides video interlock at 3km so DVD feature can be displayed while driving.
Permissions
You can select for this smartTV features to be enabled/disabled through a simple command via the blinker stalk in case the vehicle is driven by someone other than you.
Models Supported:
2009+ BMW 1-series
2009+ BMW 3-series, including M3
2010+ F10 BMW 5-series, including M5 and F07 Gran Turismo
2010 BMW 6-series, including M6
2010 BMW Z4
2010+ e70 X5, including X5M
2010+ e71 X6, including X6M
Note: Safety First! Please do not watch video content while driving and obey all laws applicable in your state.
smartTOP
Raise or lower your top with the press of a button. smartTOP offers plenty of customizable, useful features, in one easy to install product.
This unique comfort controller can be installed by anyone with the help of our detailed installation manual. Installation requires little electronic skills and is done without cutting wires or soldering! The module comes with all wires and parts needed. No need for extra key fobs. Everything is done with the original key remote.
The control unit was designed by certified engineers, having years of experience on Porsche and Mercedes Benz vehicle electronics. It was developed according to all European and American (CE, FCC) directives and constitutes a state-of-the-art electronic onboard control unit. Over-voltage protection, reverse polarity protection, safety shut-off and absolutely minimal standby power drain can be taken for granted.
Product Features:
Remote Control of Convertible Top
Control your convertible top conveniently by using your original factory remote control key or key fob. No additional remote control devices are required to open and close your convertible/cabriolet from a distance.
Operate Top While Driving
Forget about the days you had to pull over to open or close your convertible top! Thanks to smartTOP you can now open or close your top while driving at speeds up to 35 mph.
One-Touch Power Top
With the smartTOP one-touch convertible top automation you no longer need to hold the top button to open or close your convertible top. Now you can tap the button and your top opens or closes automatically. This feature also allows your hands to remain free and you are able to focus on your driving.
Remote Folding Mirrors
Remote fold-in mirrors for those equipped with Premium package through the double-click of the lock button on your factory key.
Individually Programmable
Configure the features and functions of the smartTOP module to suit your personal preferences. All stored settings are retained even when the battery is removed.
Setup Menu in the Vehicle Display
You may configure the settings of your smartTOP module directly using the display of your factory on-board computer (dash) display. The individual options are displayed in plain English.
Passive Mode
You can deactivate the smartTOP module completely. This allows you to loan your vehicle to others that may not be familiar with the smartTOP features. The passive mode will allow factory electronic test equipment to be utilized without causing irregularities in their read-outs.
Extra Functions
In addition to the intelligent convertible top control, some smartTOP modules provide additional functions that you can easily learn to operate. Specific details and availability of the individual functions depend on the vehicle make and model.
Reversible Plug-in Installation
Every smartTOP module is shipped with all parts required and ready to install. The plug and play installation is completed without cutting any wires. A smartTOP installation may be completely removed at any time allowing you to sell or return your leased vehicle to its original condition.
Models Supported:
2008+ BMW 1-series Convertible
2007+ BMW 3-series Convertible
2004+ BMW 6-series Convertible
2009+ MINI Cooper Convertible
2009+ BMW Z4 Roadster
Come by and get this installed in your car! Contact us if you want to set up an appointment!
Ordering:
Phone:
You can reach us directly by calling 866.669.0705 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Tax:
All CA customers will be charged 8.75% CA Sales tax.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday/Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x31
Email: brian@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
      03-29-2011, 12:24 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
no smartTOP for the 06 z4m roadster?
      04-15-2011, 12:25 PM   #3
brianexeas
brianexeas's Avatar
41
Thanks for the inquiries, PMs replied!
      07-20-2011, 01:17 PM   #4
brianexeas
brianexeas's Avatar
41
Got a few more sets in stock and ready to ship!
