Login
08-12-2019, 03:05 PM | #1 |
![]() 2
Rep 58
Upgrading to LED's on Z4 M
I've been trying to upgrade the bulbs on my 2007 Z4 M and was going off a previous list I could find. I felt it was very vague and some bulbs were incorrect (especially the brake bulbs).
This is everything I have used and have completed everything except for the interior headlight bulbs (turn signal, angel eye, and parking light). Bulb Type - Color - Qty - Location - Link 194 - white - 5x: (2x license plate, 3x map/dome light) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 NOTES: center map tight to put in. also, these might be a little too bright to have as map/dome (they are BLINDING). Buy 3 packs, you will have 1 bulb extra 194 - amber -4x: (2x side marker roundrel, 2x headlight -parking- light) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 BA9S - warm white <5000k - 2x: halo/angel eyes https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 NOTES: anything cooler than 5000k and the light will look blue due to the actual ring having a blue tint BAY9S - amber - 4x: front turn signals (2x on each side) https://www.aliexpress.com/item/3284...73e64c4dzFc5zm 1156 - red - 2x: brake lights https://www.amazon.com/gp/product/B0...KG5BQMBR&psc=1 7507 - amber - 2x: rear turn signals https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 921 - white - 7x: (2x reverse lights, 2x footwell, 1x glove compartment, 1x center console, 1x trunk/cargo) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 NOTES: buy 4 packs, you will have 1 bulb extra. I used a 921 INSTEAD of the normal 194 in the footwell, glove compartment, center console, trunk/cargo. it fits if you decide not to use the black heat-shielding piece on some of them (i forget which ones had it) BAY9S - red - 2x: brake force display bulbs (comes on under hard braking) https://www.aliexpress.com/item/3284...73e64c4dzFc5zm ![]() Last edited by jteran5; 08-12-2019 at 03:45 PM.. |
08-13-2019, 11:41 AM | #4 |
![]() 2
Rep 58
08-13-2019, 06:13 PM | #5 |
![]() ![]() ![]() ![]() 59
Rep 961
Do you have a bulb out light on your dash? The halo LEDs I used gave me a light on my dash.
![]() CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights |
08-15-2019, 12:02 PM | #6 |
![]() 2
Rep 58
Actually, I did change out my halo bulb to an led when i did a projector upgrade for the low beams. Did get the bulb out warning and coded out with Carly. Coded everything out at the same time so not sure if the rear lights triggered the warning too or not. I coded everything out because I was getting the hot and cold light check show with the LED's.
