      09-26-2007, 10:26 AM   #1
jmontello
JaBaby!
jmontello's Avatar
Drives: 2004 z4 2.5i
///M Coupe rotors on a 2004 2.5i
Hey guys, does anyone know if i would be able to buy the rotors from a new ///M coupe and put them on my 2004 2.5i// i upgraded to the M6 rims and my discs jsut look so small.. any advice??
      10-07-2007, 10:46 PM   #2
BlackSapphireZ
Drives: 22 GLE 53 Coupe
you need M caliper as well as carrier...more than likely because thats what its needed for a 3.0 brake swap.
but i heard Z4M's are totally different so who knows what will be required
2022 GLE 53 Coupe
      10-24-2007, 12:30 PM   #3
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
Just get yourself a Brembo or StopTech BBK and it'll be much more simple than tryng to get M parts to fit.
      05-31-2008, 01:32 AM   #4
nemex12
Drives: e60,z4
but as far as i know brembo only makes brakes for the front of the z4, they dont do the rear ones(except for the ms which are very different, i think)
      05-31-2008, 04:06 PM   #5
The HACK
The HACK's Avatar
1821
To use the MZ4 rear brakes you will need the ENTIRE SUBFRAME. That means the subframe structure, the diff, the control arms, the king pin, and the output shaft. It's about $5,000 total in parts and labor.
Not entire sure if it's an upgrade worth the cost, when it's going to make your car rear heavy, accelerate like it's got a 4 cylinder engine with only 3 firing and not at the same time, make your car cruise at 4,000 RPM at 65 mph in 5th gear, and frankly, handle like SH*T because you don't have the equal springs and shocks up front.
