06-10-2011, 08:52 PM | #1 |
Rep 39
Just Installed H&R springs
Just installed my new springs and I am not really noticing a change in height, has it been the same for some of you?
So my question is..does it settle and change after a certain amount of time? |
06-10-2011, 09:52 PM | #3 |
Rep 1,002
Installed Eibach Pro-Kit on my 2007 Z4MC and could not be happier! The car only drops about less than 1/2" Rear and about 3/4" Front but the ride is so much better
[IMG][/IMG] |
06-10-2011, 10:08 PM | #4 |
Bad Lieutenant
233
Rep 3,517
They should settle with some miles on them. A lot of people are happy with them.
06-11-2011, 10:44 AM | #5 |
Bimmer Noob
30
Rep 566
H&R springs are reported to lower the ride height ~1", Dinan ~1/2", Eibach as mentioned above. Unless you measured before, I found it difficult to notice any difference.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
06-11-2011, 05:37 PM | #8 |
M = Midlife Crisis
65
Rep 2,006
My drop was immediate and the springs were new...
2006 Z4MC - #LL93158
06-19-2011, 02:44 AM | #10 |
DHS
203
Rep 4,013
Drives: 2023 M4, 2020 Land Rover
I have had them for about 6 months or more on my Z4M and it drops front and rear about 1 inch. Now it has settled a bit more and its about a 1.25 inch drop, front and rear now. I would like to drop the front one more inch but like how I can get around now with no issues VS my 3 inch drop on my M3.
Here is my H&R's on my Z4M....
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 Last edited by Endless619; 06-20-2011 at 01:39 AM.. |
06-19-2011, 02:48 AM | #11 | |
DHS
203
Rep 4,013
Thanks.
2023 BMW M4 2016 X3 |
09-26-2011, 08:11 PM | #15 |
Rep 1,530
Did you guys install these springs yourselves or had a mechanic do it? My brother is a mechanic for Audi and he says he might be able to install these springs depending on what is involved. He's installed Tein lowering springs on my Honda Civic before and all we did was put the car on jack stands.
09-26-2011, 08:34 PM | #16 |
Rep 1,002
Piece of cake! It took me. longer to jack the car up and removed the wheels than swap the springs. I did not even need to use the spring compressor.
09-26-2011, 10:34 PM | #17 |
DHS
203
Rep 4,013
When all said and done my front wasnt low enough on just the H&R springs so went with full suspension.
10-04-2011, 09:20 AM | #18 |
Rep 1,530
I read in another thread that with H
10-04-2011, 05:29 PM | #19 |
Rep 12,565
10-05-2011, 05:11 AM | #20 |
Rep 1,530
Dang. For some reason my post got cut off. I think it has something to do with using the BimmerPost program for the iPhone. Whenever I have an apostrophe a "/" symbol always gets added. Looks like a "&" symbol causes the post to be cut at that point. Weird.
Anyway, as I was saying. I read in another thread that H&R springs are pretty stiff and will most likely require owners to repair the the suspension after around 20,000 miles. Does this occur with the Eibach springs or is it more reported with H&R because H&R has been used more often? If premature wear occurs with all lowering springs, I may just want to go with coilovers as some other users have stated they wish they had done from the get go. |
10-05-2011, 03:34 PM | #21 | |
Booyakasha!
40
Rep 413
Drives: '13 Mini Cooper S Coupe'
'08 M Coupe--AW/IR--SOLD!--My M Coupe Obsession
'13 Mini Cooper S Coupe - My Maui Mobile '13 Mini Cooper S Paceman- My Maui 'Stuff Hauler' |
