      06-10-2010, 02:16 PM   #23
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by JCz04Bimmer View Post
Errr... well I ordered my kit from him right off of the website and I got two bags. One for the front with two hoses. One for the rear with four hoses. Maybe ask him to check again and actually look at what would be shipped out? He's probably just going by memory and assuming our rear is the same as the E46M3.
FWIW...
The Stoptech lines have been updated.
The Stoptech rears are a single 26.5" SS line replacing both OE flex pieces and the solid line between them on the trailing arm.
This eliminates extra fittings.
I'll post pics when I get them installed.
Last edited by inTgr8r; 07-19-2010 at 09:39 AM.. Reason: clarrification on # of rear lines
      06-10-2010, 07:04 PM   #24
RBull
Drives: 2007 M Coupe
^looking forward to seeing them.
      06-11-2010, 12:07 AM   #25
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
FWIW...
The rears are a 2 line set with one 26.5" line replacing both flex pieces and the solid line between them on the trailing arm.
Interesting! Good to know. Very curious to see what they look like. It's a cheap enough part that I would entertain updating what I have installed so I don't have to use zip ties!
      07-19-2010, 09:00 AM   #26
Tonybest
Enrollment Officer
Tonybest's Avatar
Drives: 997.2 Porsche C4S
I had my brake rotors and pads changed under wear&tear warranty with OEM stuff just before last weekend's Calabogie event. I now realize that as my ability improves, my brakes are not sufficient enough. I'm thinking of cutting out the little plastic part that is obstucting half of the air coming from the front end of the car. Will this be sufficient?
My other alternative is to start doing pad changes at the track with the Hawks HT10s that I had purchased earlier. I need to learn to do this since I think it will become a must soon enough.
What effect on the stock rotors as I am alternating from the Hawks HT10s to the OEMs when going from DD to track back to DD ???
      07-19-2010, 09:44 AM   #27
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
After running at Shannonville (tough on brakes)
I'm completely sold on Cool Carbons as a combo street/track pad.
I also have the Stoptech lines & Motul 600 fluid.
      07-19-2010, 04:05 PM   #28
david @ eas
david @ eas's Avatar
Drives: BMW
We're actually running a July Special on the Cool Carbon pads, with special pricing if interested. There's a good discount involved, and especially now that we're doing a free shipping deal for all our products, you cant beat the prices we're giving away now.
PM me for more details
      08-02-2010, 09:10 AM   #29
Tonybest
Enrollment Officer
Tonybest's Avatar
So this is what I've learned this morning. Using HT10s on OEM rotors is not suggested. Sure it will work but the rotors will wear out very fast.
I will need to purchase a new set of track rotors that have been properly frozen in the manufacturing process. This gets all the air pockets/bubbles out of the rotor by contracting the metal.
So if I understand, Use my OEM set (rotors and pads) as long as acceptable. If still on warranty, change again to the same thing.
Then, buy a set of track rotors (?) and I will be able to switch from HT10s pads to regular OEMs pads at any time I see fit.
Does this make sense?
      08-07-2010, 03:29 AM   #30
Tonybest
Enrollment Officer
Tonybest's Avatar
Brake fade almost nonexistent today. Motul RBF 600, and ducts were opened up. SS Brake lines were already there. OEM pads and rotors.
So I'm quite happy now.
Now the tires are my next question... they seem to not grip as much anymore.
      08-07-2010, 10:56 AM   #31
jmillet
jmillet's Avatar
64
SNIP
I run PF-01 pads on OE rotors and am down to minimum thickness in front and heat/stress cracks around holes. Dealer will replace rotors under the 4 yr/50K BMW Maintenance Program.
I'm on my second set of Toyo R-888 tires; 245/40-18 front and 255/35-18 rear mounted on E46 M3 wheels. Camber is critical with these R-compound tires; I run -3.5 degrees front (TCK camber/caster plates) and -2.0 degrees rear. Handling is neutral to some controllable over steer at the friction limits.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      08-12-2010, 06:07 AM   #32
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
You are lucky to have a sympathetic dealer service dept. Mine would refuse to pay for rotors that had stress cracks or other evidence of high temperatures.
