03-18-2021, 08:24 AM | #617 |
Rep 3,004
Vanne!
Wowie - do you have any data on the octane rating of the crappy fuel? Or, is the octane ok but it is the contaminants in the fuel that screw things up? It must be low octane otherwise you could install high-performing fuel filters to sort out the solids.
Racerbruce
Vanne1620.50 |
03-19-2021, 12:13 AM | #618 |
Down Under!!
1621
Rep 4,294
well its the same as what you guys get over there. Ron .95 x98 = 93. so thats the ocatne rating.. which, unless your running low compression pistons (i am not) , will be an issue with 9 psi boost. Running Meth will up the octane rating to around 112 or 108 at the least, depending on the mixture. As an added bonus , it will also clean your intake and TB's/Valves/ etc.. so pretty much a win-win.. I guess the old engineers from WW2 knew a bit about engines.
There is a lot of stuff/muck in the fuel too though, and maybe yours is pre-filtered a bit better.
Powered by |
03-19-2021, 08:37 AM | #619 | |
Rep 3,004
Well said -
Racerbruce
03-19-2021, 10:52 AM | #620 |
Down Under!!
1621
Rep 4,294
hahaha, thats gold.. ill take that advise to heart and act on it, starting tonight.
Powered by |
racerbruce3853.50 |
03-23-2021, 05:19 PM | #621 |
Down Under!!
1621
Rep 4,294
I spent most of my day off today refitting the oil coolers properly, as Initial placement had it rubbing the heat exchanger. Had to remove it any ways as it had a leak. (Go figure, brand new)
Other side. ... Bonus ABS pump picture with custom braided lines. And then things started looking up, my uprights arrived.. sadly though upon closer inspection, they need to go back and fixed, as they are slightly off. New DSSR went in today. Last edited by Vanne; 03-23-2021 at 05:45 PM.. |
wdb4732.00 |
03-23-2021, 06:20 PM | #622 |
Rep 2,704
Epic build Vanne
Vanne1620.50 |
03-25-2021, 10:54 AM | #623 | |
Rep 1,373
07 Z4 M Coupe AW/IR |
03-29-2021, 09:40 PM | #624 |
Down Under!!
1621
Rep 4,294
Good question... As ive gone for a complete brake system from Wilwood, which included the removal of the brake booster, resiviours , and master cylinder, the Wilwood system is Imperial (que starwars music) and ofcourse the Bimmer stuff is all Metric. This wouldent have been an issue, however i need to keep the ABS unit, so had to make some custom lines from the new wilwood bias valve (allows me to change the brake bias front to back on the fly from within the drivers seat) to the ABS pump, which is what your looking at there... did they need to be braided? ofcourse not, i could have had them plumbed in solid lines, but for me this is much much easier. And yeah dont even start asking me about bubble and non bubble flares... lol.. Hope that made sense... meanwhile... meth kit turned up, and drive shaft is back from the balancing shop. New DSSR is installed as are the new rear Toe adjusters. Hopefully get some logs for Josh today...
Powered by |
wdb4732.00 |
03-30-2021, 09:30 AM | #625 |
Rep 3,004
Go Vanne....GO!!!!
This is an unreal build....this is well beyond just having the funds to create The Beast....its the skills required to create The Beast. We are living vicariously through your pursuit - keep up the great work!
Racerbruce
04-13-2021, 07:56 AM | #626 |
Down Under!!
1621
Rep 4,294
Decided to fix the uprights myself, sick of them just fucking it up..
Spent the day grinding (lol the alu...). And Next off to the paint shop for powder coating...
Powered by |
wdb4732.00 |
04-13-2021, 09:09 AM | #627 |
Rep 3,004
Greetings from Seattle -
They look great Vanne - well done; what is the back-story re those that fuc*ed up the process??
Racerbruce
04-13-2021, 09:29 AM | #628 |
Down Under!!
1621
Rep 4,294
Greetings right back at ya from Dubai
The inserts that were cut out with water PSX machine, were offset by about 3mm’s from each other.. they couldn’t even figure out if they bolted them together than it would /have/ to be the same on each upright..
Powered by Last edited by Vanne; 04-13-2021 at 09:55 AM.. |
wdb4732.00 racerbruce3853.50 |
04-21-2021, 05:40 AM | #630 |
Down Under!!
1621
Rep 4,294
Goeije dag then right back at ya!
Bit of wheel work.. I can't claim the credit, was completed by wheel paint shop.. Turned into this... Fiat 750 marron Volcanio with 15 percent of A32 bmw. Shit pictures.. but looks amazing.. (oh, if you use that, make sure to leave me some credit or paypal me a beer or 2
Powered by Last edited by Vanne; 04-25-2021 at 04:34 AM.. |
04-22-2021, 04:19 AM | #631 |
Rep 52
Nice wheels. Is that a dark bronze color?
Alpine white/Imola red, G-Power SK1 kit 416 whp, 200 cell cats, Supersprint Race cans, Fortune 500 coilovers, 19" Z Performance ZP2.1 Wheels, Vibra-technics Engine mounts, Rogue transmission mounts, Rogue RTAB, Tekarbon CF trunk spoiler, Carbon roof Geoff Steel, OE ZHP short shift knob, CDV delete, stubby antenna
04-22-2021, 07:29 AM | #634 |
Rep 3,004
Well done Vanne!
What color have you chosen for the body?? It seems that the rim colors will compliment most any body color, for sure.
Racerbruce
04-26-2021, 02:40 AM | #638 |
Down Under!!
1621
Rep 4,294
