11-11-2015, 05:25 PM | #23 |
エアーマンが倒せない
279
Rep 2,041
Sorry to necro this old thread, I've been away from these forums forever!
Aside from your WiFi routers, check your devices. WiFi devices B N and G have longer range, A N and G can transfer more data, more quickly. If you can set your WiFi routers to run in only N or G, you'll get improved data transfer and good range. A only will give good data transfer speeds, B has better range than A. Most WiFi routers are configured to run in Compatibility Mode by default, meaning it auto configures itself ABGN, basically B range and speed, but usable by A G and N devices. If you don't have any devices can only run A or B, go ahead and switch to G or N. I did this for my parents', and my father's setup in his garage went from 11 Mbps to 32 Mbps over WiFi!
11-28-2015, 09:54 AM | #24 | |
Rep 11,147
11-28-2015, 06:25 PM | #26 |
Rep 11,147
11-28-2015, 06:42 PM | #27 |
Fool
1857
Rep 3,542
Very much so, I ran the 10/100 version for 8 years before upgrading to a managed Cisco 24Gb one. My 10/100 never did a single thing wrong and was running for 8 years constantly.
11-29-2015, 09:46 AM | #29 |
Rep 11,147
Correct, opted for no patch panel as I wasn't sure if it was something I'd really need once I got my switch in place. And the cables are nicely terminated/labeled as you can see. I have two drops at each wall outlet, and they are labeled accordingly. However, the different colored cables mean either direct burial or non-direct burial. Black is the direct burial. The blue is the "regular" cat 6.
11-29-2015, 11:50 PM | #31 |
Rep 11,147
11-30-2015, 10:02 AM | #32 |
Rep 3,242
Which Hikvisions are you looking to get? It seems there are a new set of Hikvision PTZs with IR/night vision capabilities coming out. If they're as good as the Dahua, I might ahve to pull the trigger on it. I just found out a feature of some PTZs which will make it easier for me to get a PTZ which is auto tracking. I'm not sure how good the auto tracking implementations are. It's a shame I can't correspond with the guy responsible for Network Camera Critic. I was browsing through the site and found a post where his family announced his sudden passing earlier this year. The guy was a wealth of information....truely a great loss.
On another note with PoE switches, I have to find time to migrate off of the Dell Networking N3024P switch to the bigger N3048P. I need to do this soon as I'm about out of ports on the N3024P and I would like to put the 2 port 10GbaseT module online. I have another project where I want to spin up a storage array which can support iSCSI over 10GbaseT. |
11-30-2015, 10:10 AM | #33 | |
Rep 11,147
So far, thinking a turret, two bullets, and two cubes. That's in addition to the dome and the bullet I already have. And yes, the Networking Camera Critic was an amazing site. Very unfortunate that the writer passed away. I heard they're getting someone to replace him, but not sure if that's happened yet. I need to look for a new PC also. Been eyeing the Dell XPS 8900. Sighthound runs OK on my older Dell, but adding the above cameras will bring it down to its knees. |
11-30-2015, 06:24 PM | #34 |
Rep 3,242
I'm looking at my options too. One of my Hikvision cube cameras decided to stop responding to HTTPS connections. Can't figure out why. I'm a bit scared to do a factory default to see if that fixes the problem since it's the Chinese version flashed with English firmware. Wrightwood Surveillance where I bought them from just changed management and said they'll be looking to move to the full English versions once they deplete their current stock of Chinese version cameras.
11-30-2015, 06:41 PM | #35 | |
Rep 11,147
12-02-2015, 11:09 AM | #37 |
Rep 11,147
12-02-2015, 11:24 AM | #38 |
Rep 3,242
