      08-17-2018, 11:52 PM   #1
StickMon
StickMon's Avatar
Drives: 2006 MR
Hot! Hot! Hot!
So the Wife and I get in the car tonight to go to dinner for our 24th anniversary.
Car's been sitting in the Sun all day so it's about 120° inside.
I turn the air on, and of course, at first it blows hot.
I tell her "It'll cool off any second ... wait for it ... soon ... hmmm ... fells like it's getting hotter ... ho li fuk ... damn wtf that's definitely getting hotter ... crap, now that's broke, too."
With the engine off (for quiet) and the ignition on, I can hear a motor whir for about 15 seconds when I move the temp control, so the 'tronics seem OK.
Guess I need to pull gear motor #1.
Any good advice on how to get to it?
This is going to hurt my back, isn't it.
      08-18-2018, 11:10 AM   #2
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
deep breaths. are you low on freon?
      08-18-2018, 11:26 AM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Unknown, but the compressor kicks in.
It's not just not blowing A/C, it's blowing proper heat, well above outside ambient.
      08-18-2018, 04:33 PM   #4
bosstones
Drives: o_0
Are those for opening/closing the vent blinds? If you adjust which vents are active via the control knob, does the air (al beit hot air) come out the correct corresponding vents?
Happy 24th, btw.
      08-18-2018, 10:46 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
Thanks.
I think the one that failed is the hot/cold.
If I adjust which vents, hot air comes out of the requested ones.
Recirc works too.
I took the panel off below the glove box and had a rummage around, but no way to get to it from there. The whole dash has to come out.
Ironically, it's too hot in the car to work on why it's too hot in the car.
      08-18-2018, 10:53 PM   #6
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
@StickMon Sorry your Z is giving you such problems recently.
2006 Z4M Interlagos Blue/Beige
StickMon636.00
      08-19-2018, 01:36 AM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
We're just old. She just hit 180k miles.
Front bumper cover looks nice though.
I need to spend Sunday in the middle of the Mojave.
Won't be the first time I've done it without A/C.
      08-19-2018, 01:49 AM   #8
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
This might be a long shot. But when I first bought my Z, the A/C would blow hot. Turns out is was in transport mode. So did you disconnect your battery recently?
2008 Z4 3.0si Coupe
      08-19-2018, 09:53 AM   #9
Lucky1
Drives: '08 128i Coupe SGM 6MT
There are pressure gauges that can be used to tell how much refrigerant you have in the system. For sh*ts and giggles check it anyway? Just in case it actually is something simple.
      08-19-2018, 02:56 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
Nope. Was blowing cold one day and hot the next.
And I think there's other strange things that happen in transport mode.
I'm just full of hot air. Everything else seems to be fine.
Yep. I'm going to take it some place and have the freon checked before I spend any more time on it.
No hurry. Not like it's hot out.
      11-30-2018, 04:31 PM   #11
StickMon
StickMon's Avatar
Drives: 2006 MR
Thanks to fixherz4 I was reminded that instead of playing Destiny I have to get around to hooking up the laptop and see if DIS or INPA can give me a clue.
DIS wasn't much help, but INPA was, as it often is.
Temp sensors are good, temp control on dash is good, "Air manifold Rotary knob" is bad. Also mixing motor is stuck at 0.
Not sure what's "Air manifold Rotary knob", but I think this is pointing to the actuator motor.
Guess the dash has to come out.
      11-30-2018, 09:58 PM   #12
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Attachment 1946698
Attachment 1946699
Perfect opportunity to recover the dash in Alcantara
Gotta see the good in it.
      12-01-2018, 01:20 AM   #13
Grumpy Old Man
Grumpy Old Man's Avatar
Drives: Porsche 993, 2015 MB GLK
So I'm an old guy. Priorities, Happy Anniversary.
StickMon636.00
