      06-07-2020, 04:30 PM   #45
DRedman45
DRedman45's Avatar
28
Drives: E86 //M coupe, e84 X1
The Turner kit is a pretty good place to get your extra parts list from. The extra nuts at not necessary, you can use the factory hardware. The csl dipstick would actually be more difficult to check the oil since it's essentially under the intake. I had bought it prior to doing a bit more research on it. The only thing I needed outside of what turner listed is the 5/8" heater hose to extend the crankcase vent.
I'll see if I can borrow a GoPro with a wind sock...phone videos are almost useless :
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Eventuri intake. Airrex air suspension with autopilot v2 management.
My Build Thread
      06-07-2020, 06:18 PM   #46
SLC801
Drives: LSB Z4MC
Please! Really debating this exclusively for the sound.
Bought an AFE to hold me over and it's "good" but would like even more.
      06-16-2020, 04:15 PM   #47
proboner
Drives: 2003 Z4 3.0 6-speed
Would very much like to hear your exhaust setup as well. Hows the rasp?
      06-16-2020, 05:56 PM   #48
maupineda
Drives: E86 Z4MC
I finished up my install today. No real issues with installation. I bought the csl dip stick, but ended not using it and opted to rotate the factory dipstick back towards the firewall. I extended the vent tube using 5/8 heater hose.
it sounds amazing on the top end
I have the CSL dipstick and to be honest I don’t find it difficult at all, plenty of space to reach and pull it to check oil. The biggest “issue” is that you may drip oil in the process.
      06-17-2020, 01:12 AM   #49
RossBMWZseries
I did see the list on their website but I also read some parts weren’t required as we could use factory parts like you stated above. So I can do away with the CSL tube and the dipstick and also the nuts.
The other items such as “bracket”, does Anyone know the part number(s) or what bracket they’re referring to?
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
      06-18-2020, 11:50 PM   #50
RossBMWZseries
I ended up buying the whole kit for an extra ~$500. ECS and Turner have a 15% discount on the airbox alone and also the airbox kit. In case anyone is interested go check it out. An airbox at $1274 is not bad at all!
