      06-28-2016, 06:22 PM   #1
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [10.00]
1991 BMW 318is  [10.00]
KW Clubsport Settings
Hi all. Hoping to find others with KW Clubsport coilover experience on the Z4M platform. I purchased my Z4M used with a KW CS setup and about 8K miles later (64000 miles on the car) the car is starting to feel a bit ragged and rough around the edges. It no longer feels as planted and tight as it did day 1.
Troubleshooting in my head, thinking its worthwhile to inspect
1. Alignment
2. Suspension bushings, bolts, etc. refresh
3. KW CS settings
The car is rapidly approaching 9 years of service, no doubt a few items need replacement. Where to start and what should I look for? Car shots for your time
      06-28-2016, 07:52 PM   #2
Drives: M2 Comp
FCABs, RTABs, motor & tranny mounts would be at the top of my list to check.
      06-30-2016, 02:15 AM   #3
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
+1 I can give you a much more *cough* exhaustive list, but yeah id def start with what Ian said. and in case you don't have limiters installed at the back, id be adding them when replacing the Rtabs.
Powered by
      06-30-2016, 01:49 PM   #4
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Thanks for the notes. Going to get under the car this weekend and survey the situation, then overnight some parts
      07-05-2016, 02:40 PM   #5
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Dove into the car this weekend. Bushings, linkages and sway bars all check out. The alignment was slightly off and the KW shaft collars (purple bits to set ride height, etc) were stripped meaning the collar could spin on the coilover shaft.
Found a short term remedy for that and dropped 4-6 psi out of each tire since I was way too high (scared after a cracked wheel ) and the car seems much more planted and stable.
      07-05-2016, 03:49 PM   #6
Beedub
their should be a small set screw.... this just need very small amount of Tq, I'm guessing this is the bit that is stripped,
      07-05-2016, 04:13 PM   #7
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
The set screw threads are intact, unfortunately it is the threads on the shaft collar (nearest the coilover) that are stripped. I put in a longer M3 bolt and it seems to be holding for now while I get parts from KW on order.
      07-06-2016, 03:54 AM   #8
Beedub
i have no idea how that shaft color has stripped..... thats crazy... did you get these new or used? because if they were new id be asking for a free replacement.
      07-06-2016, 01:08 PM   #9
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Threads on the set screws look good and the collar itself looked worn so that seemed the only culprit. Oddly enough the rear coilovers are fine. Car is used and I doubt the previous owner even knew about the issue.
Reached out to KW, awaiting their response.
      07-06-2016, 03:51 PM   #10
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Sir, do you know the length of your Springs?front and rear?
Instagram: ariusen26
Youtube: Track vids
      07-06-2016, 04:31 PM   #11
Beedub
yeah sounds like something else is being missed, the collar is a hardened composite plastic so unless it was seized and then forced at some point theirs no way it those polymyde collars can strip really, the only way i can see them spinning freely is if the set screw is stripped which is really easy to do and not my fave design but i see why they choose it.
the set screw Still would stop the colour from turning if you used ur hand and forced the color , the set screw just holds the color from the tiny loads it will see in thread direction on the car.
      07-07-2016, 12:02 PM   #12
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Compressed length or uncompressed length? I can measure next time I am under the car otherwise you can find more information in the user manual
http://www.kwsuspensions.com/extras/...ah35220834.pdf
The set screw Still would stop the colour from turning if you used ur hand and forced the color , the set screw just holds the color from the tiny loads it will see in thread direction on the car.
Doesn't seem to be doing the trick, however I might try new set screws prior to splurging on spring collars (spring perch KW is calling it).
      07-07-2016, 12:38 PM   #13
Drives: M2 Comp
Yes, this is the lower spring perch. (Supports the car)
I had thought several times , when I had my Clubsports that I would like to add a second perch as a jamb nut the way most other mfgs. do it.
Then there is no need for the set screw at all.
If the perch itself is stripped, I would be concerned about it supporting the spring (and car) under compression.
It could shift around on the damper threads, or let loose completely.
      07-12-2016, 03:52 PM   #14
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Ordered both parts from KW, shall see what's what underneath the car. Best case it is only the set screw and I can double up spring perches.
