      09-30-2019, 10:53 AM   #1
2282
Disable Bulb Errors via Coding
For those running LEDs on the exterior of their car, can you confirm which bulbs you were able to successfully disable the voltage monitoring via coding or Carly?
I am currently running LEDs on the rear plate (not monitored) and DRL (successfully disabled). However I’m not able to code out the turn signals using Carly. Still her bulb dash light and signals are flashing too fast. Has anyone been able to successfully run LEDs in turn signals?
      10-01-2019, 09:35 AM   #2
Residentj3553
Residentj3553's Avatar
Drives: 2008 BMW Z4M Roadster
I'd like to know as well!
2008 E85 ///MZ4 Roadster - Sapphire Metallic Black / Imola Red Int.
IG: Jessed.alvarado
Mods: ProFlex E85 Flexfuel kit, Eventuri Carbon Intake w/ RPI scoop, Megan Headers, Custom Axle-back exhaust, KW V3 Coilovers, Stoptech ST40 BBK, Poly FCABs, APEX PS-7s, Diode Dynamics Headlights, CF Trunk Spoiler, Sideskirts & Diffuser.
      10-03-2019, 06:32 PM   #3
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Ditto
      10-03-2019, 09:21 PM   #4
eggman51
Drives: 2006 BMW Z4 M Roadster
From a forum post here I used these for the fronts:
https://www.aliexpress.com/item/3284...73e64c4dzFc5zm
And these for the rears:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I disabled pretty much all the voltage monitoring in Carly iirc.
No errors / dash warnings / fast blinking.
Cheers
Eamonn
3002 tii2281.50
      10-03-2019, 09:32 PM   #5
2282
Cheers
Eamonn
Thanks, this is helpful. Maybe I need to revisit my Carly settings. So to be clear, you replaced all 4 bulbs on the front with these? What color did you go with?
I experimented with 6000K and it actually came off more traditional yellow than the stock amber which I kinda dig lol. Obviously if I went down this route I’d change the parking bulb too but it’s a good comparison shot.
      10-03-2019, 11:38 PM   #6
eggman51
Correct 4 bulbs for front turn signals using the Yellow lights from Aliexpress. I tried to find the equivalent on Amazon, but couldn't.
I used these for the parking bulbs:
(from the same thread linked above).
I like using LEDs because it got rid of the amber glow, just pure white, tho on the parking bulb you can see some amber if you look closely.
Your retrofit looks excellent - sometime soon I will post up what I did for light mods - pretty extensive (aka nutty). I shoulda thought to replace the projectors, might do that later.
Cheers,
Eamonn
3002 tii2281.50
      10-05-2019, 12:38 PM   #7
2282
Originally Posted by WickedNy View Post
Ditto
I'll try to summarize what I learned when researching bulb replacements...
Cliffs Notes
1. In general any bulb that takes on a "wedge" style (T10, 168, 194, etc.) can be upgraded to LED w/o errors.
2. Most of the interior bulbs use 168/194; the only exception is the coupe's trunk which uses festoon.
3. LED replacements for bayonet style are harder to come by so you'll likely need to buy 'no-name' product made in China off eBay or Amazon.
4. If upgrading your bayonet bulb, be sure to pick a LED bulb that has forward facing light output. A lot of the newer LED have chips embedded on the side only and rely on the surrounding reflectors.
Interior
As mentioned above, all the interior bulbs with exception of the coupe's trunk, use wedge style bulbs. Try to go with 168 as they are brighter than 194 but you may not even be able to tell the difference TBH. Color wise, upto you but I actually prefer a soft white (4000K) for ambient lighting and only use 6000K for areas like trunk, glovebox, and console.
For the 3 dome lights, the spacing is really cramped so a typical 168/194 led may NOT fit in there easily. I got lucky and found that the Philips X-tremeUltinon fit perfectly. The regular Ultinon LEDs are cheaper so you could get away with those for the other lamps.
Headlights
Corner lights take on W5W, so any 168 or T10 should do. 194 would work as well but 168 is closer in terms of wattage. I think these bulbs can be upgraded to LED w/o warning errors but I am not entirely sure.
Angel eye (inner halo) uses a 5W incandescent BA9S that's integrated into bulb holder. Plenty of threads cover how to replace it but this is one of the bulbs that WILL trip an error. I was able to disable the voltage monitoring using Carly.
Turn signals take H21W (or BAY9s). The difference between this and the halo bulb is how the tabs are positioned on the base. BA9S tabs are positioned directly across from each other (180 degrees apart), whereas the spacing on the BAY9s are obtuse (120 degrees apart). These too will result in error unless coded out.
Tail Lamps
The parking/fog light is H21W or (BAY9s), same as the turn signals just mentioned above.
The reverse light can be upgraded to a 921 LED. I replaced this with the Sylvania Vevo 921 and thought it turned out great.
The brake light is P21W but there seems to be a lot of confusion as to whether the 1156 or 1157 is the correct LED equivalent. But 2 things I know are 1) our brake bulb is single filament and 2) the tabs are spaced 180 degrees apart but their vertical positioning is offset. Based on the diagram below I think you can rule out 1157 (bottom right) and assume 1156 (or BA15S) is the correct application.
Only reason I’m not entirely sure is because there’s a review on Amazon from a fellow Z4 owner who mentioned some minor modification to the socket was necessary. But if I had to guess he was trying to fit the 1156 in his turn signal socket...
The turn signals use a PY21W. The Y stands for yellow and it’s very similar to the P21W except the tabs are spaced 150 degrees apart. Therefore I think you need to find a BAU15S (or 1156PY) bulb (upper right above).
XMetal1131.00
      10-17-2019, 10:11 PM   #8
2282
Small update... I experimented with some BAY9s bulbs for the turn signal indicators. They do indeed "fit" but I would NOT recommend going the LED route. Not sure if it's just the particular brand of bulbs I bought but the tolerance in the bulb socket is too tight for anything other than stock. So in my case, the LED bulbs would pop out really easily... which meant I had to spend 15 mins ytrying to fish these out of the headlight assembly! Seriously, not worth the effort lol.
      10-30-2019, 07:48 AM   #9
CSM3
CSM3's Avatar
Drives: E86 Z4M, F80 M3CS
Did they make the entire housing look clear?
      10-30-2019, 03:02 PM   #10
2282
No because the orange covers will always block the lights. Putting in 6000K bulbs turned it from orange to yellow.
