09-28-2019, 03:57 AM | #1 |
Rep 150
Drives: 2016 BMW 340i
What is the definition of "cell" in relation to downpipes?
Can anyone explain?
09-28-2019, 04:28 AM | #2 |
Rep 10,120
In scientific terms...
The cell count of a catalytic substrate refers to the number of holes per square inch and is a direct indication of the flow capabilities of that substrate. The lower the count of holes the bigger the hole need to be to fill one square inch, a bigger hole subsequently flows more exhaust gasses. |
09-28-2019, 07:09 AM | #3 |
Rep 460
Might also refer to CEL or check engine light. A normal occurrence when swapping in catless downpipes. Performance chips typically clear that problem.
09-28-2019, 07:22 AM | #4 |
Primo Generalissimo
4672
Rep 4,022
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
I believe what’s going on is the higher cell count means more holes yes, but also more material to react with exhaust gasses to reduce emissions.
09-28-2019, 08:37 AM | #5 |
Rep 4,145
Drives: '18 M2 6MT
CELLS - Literally the little connected boxes inside the converter.
CEL - Check Engine Light The factory converter has 750 cells, and is therefore more restrictive than the after-market converters, which usually have 200 cells. A 300 cell converter will not usually cause a check engine light, but all but 1 (Fabspeed) 200 cell converters will cause a check engine light. |
