05-01-2012, 09:51 PM | #1 |
Rep 518
"error light"
hey guys I did the rear lights conversion on my car, from 05 to 08, but the error light came on the dash, how can I eliminate that, I used resistor and I know that there is a way to code my car to eliminate that. I have ncs expert program. do you guys know under what module and what code do I have to change??
thanks..
2005 z4 2.5i/// Aero front bumper, m rear bumper,08 rear lights, custom quad exhaust, matte black front grill, OEM alarm, llumar security film,m wheels, HID lights, LED interior and trunk light,Ipod integration, stubby antenna,tein s-tech springsx
05-01-2012, 11:00 PM | #2 |
Rep 2,546
Module LSZ
try to set all the following to nicht_aktiv as see if that does it. CC_RUECKLICHT_LINKS CHECK CONTROL (CC) - TAIL LIGHTS - LEFT nicht_aktiv not active aktiv active E85 CC_RUECKLICHT_RECHTS CHECK CONTROL (CC) - TAIL LIGHTS - RIGHT nicht_aktiv not active aktiv active KALTUEBERWACHUNG_RL_2_RE COLD MONITORING - TAIL LIGHTS - RIGHT 2 nicht_aktiv not active aktiv active E85 KALTUEBERWACHUNG_RL_3_LI COLD MONITORING - TAIL LIGHTS - LEFT 3 nicht_aktiv not active aktiv active E85 KALTUEBERWACHUNG_RL_3_RE COLD MONITORING - TAIL LIGHTS - RIGHT 3 nicht_aktiv not active E85 aktiv active KALTUEBERWACHUNG_RL_LI COLD MONITORING - TAIL LIGHTS - LEFT nicht_aktiv not active aktiv active E85 KALTUEBERWACHUNG_RL_RE COLD MONITORING - TAIL LIGHTS - RIGHT nicht_aktiv not active aktiv active |
05-02-2012, 12:29 PM | #3 |
Rep 518
do you think that I also need to do the
WARMUEBERWACHUNG_RL_LI WARMUEBERWACHUNG_RL_RE I did most most of the ones on the list just forgot KALTUEBERWACHUNG_RL_2_RE probably thats why is not eliminating the error light thanks or taking the time to help me
05-03-2012, 09:16 PM | #4 |
Rep 518
is not working error still there
05-03-2012, 09:41 PM | #5 |
Rep 2,546
Here's a factory trace file from my 2007 3.0si coupe w/ xenon. Maybe you could diff it and your file using ncs dummy and see what is different.
05-03-2012, 11:27 PM | #6 |
Rep 518
thanks for the quick respond I even added:
WARMUEBERWACHUNG_rl_3_li WARMUEBERWACHUNG_rl_2_re WARMUEBERWACHUNG_rl_3_re WARMUEBERWACHUNG_RL_LI WARMUEBERWACHUNG_RL_RE CC_LAMPEN :Check control lights light disappear but after 2 or 3 min is there again..
