Go Back   ZPOST > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
      01-25-2022, 08:31 PM   #1
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
No_Country
25085
Drives: A Car
Toyota Reveals All-New Generation of the Sequoia - First Redesign in 15 Years
Standing Tall: All-New 2023 Sequoia Full-Size SUV is Ready to Make its Mark
Originally Posted by Toyota Newsroom
PLANO, Texas (Jan. 25, 2021) – Much like the coastal redwoods after which it is named, the all-new 2023 Sequoia makes an immediate, indelible impression. The three-row SUV is all new from the ground up, and it aims to elevate the full-size segment with luxurious comfort, impressive technology and breath-taking performance from an efficient new hybrid powertrain.
On the surface, the “Sequoia” name is befitting of this large SUV because of its size. Peeling back the symbolism a bit more, the species of tree is not only the largest in the world but it’s also one of the strongest and most stout, known for its longevity with some being nearly 2,000 years old. Seeing the forest for the trees, the “Sequoia” name for Toyota’s largest SUV represents its stature in addition to its long-lasting quality, durability and reliability. The all-new 2023 Toyota Sequoia is projected to be available in summer of 2022.
Premium and Powerful
This third-generation Sequoia is completely redesigned and worthy of the “all-new SUV” description. All 2023 Sequoias will feature the powerful twin-turbo V6 hybrid i-FORCE MAX powertrain. First unveiled on Tundra, this exceptional hybrid produces 437 horsepower and 583 lb.-ft. of torque.
i-FORCE MAX isn’t just big on power, as this cleverly engineered powertrain features a unique motor generator within the bell housing between the twin-turbo engine and the 10-speed automatic transmission. This design provides both maximum performance and amazing efficiency, and it is designed and built with heavy-duty performance and demand in mind. Fuel economy estimates are not available at this time, but the i-FORCE MAX’s output it is expected to be extremely competitive at the top of the segment – and a huge improvement over the previous generation.
Sequoia will be offered in 2WD or the available part-time 4WD system on SR5, Limited, Platinum and Capstone grades. TRD Pro will be offered only in 4WD. The part-time 4WD system relies on a transfer case, controlled via a lever on the center console, to select between 2WD, 4WD high or 4WD low.
Setting Sights on the Open Road
As it should be, the full-size SUV segment is a demanding lot. That means the Sequoia needs to handle a multitude of tasks in stride. Built with this in mind, the all-new SUV is rooted in a modern body-on-frame chassis with a fully boxed frame that shares architecture with the all-new Tundra and all-new global Land Cruiser (which shares its platform with the Lexus LX). The core objective of this platform is to provide excellent handling, supreme comfort and impressive capability.
The engineering team behind this next-generation frame was able to increase rigidity and improve ride comfort by utilizing new techniques, such as new laser welding technology that helps reduce mass and weight in areas it’s not needed while reinforcing the areas that need it most.
Sequoia features an independent front suspension and adopts a new rack-mounted electronic power steering system for improved steering feel. A modern multi-link rear suspension is employed out back to offer a smooth ride and create opportunity to add the available Load-Leveling Rear Height Control Air Suspension and Adaptive Variable Suspension (AVS) for those looking to tow regularly.
The three-row SUV offers a range of configurations for seating and cargo. Depending upon the grade, second-row passengers get bench seating or captain’s chairs, either of which recline for passenger comfort or fold down/tumble forward if larger cargo space is needed. The third-row passengers benefit from a spacious reclining backseat with available power folding, but the third row also gets one of the most noteworthy new features on Sequoia: the exclusive Sliding Third Row with Adjustable Cargo Shelf System. This segment-first feature allows the third row to slide with 6 inches of adjustment range. The third row can also fold down to complement the different storage positions of the new Adjustable Cargo Shelf System: a removeable shelf that can be set in a variety of storage positions depending upon the situation. The Cargo Shelf System is designed to offer the ultimate flexibility in rear cargo and storage needs.
Since full-size SUVs need to do it all, towing – whether it be a trailer, boat or RV – is high on that list of demands. That’s why the all-new Sequoia offers up to an impressive 9,000-pound maximum towing capacity, a nearly 22% increase over the prior generation.
Towing can be an intimidating proposition for some drivers. Not to worry! Towing becomes a less daunting task thanks to impressive technology available on Sequoia. The Tow Tech Package, available on all grades but standard on TRD Pro and Capstone, offers a suite of features that include Trailer Backup Guide to aid in backing up the SUV with a trailer, and Straight Path Assist which helps provide steering control to keep the trailer straight on its intended path when backing up.
Drive Mode Select is an all-new feature on Sequoia, offering different driving modes depending upon driver preference, and it includes standard settings Eco, Normal and Sport. With available Load-Leveling Rear Height Control Air Suspension and Adaptive Variable Suspension settings expand to include Comfort, Sport S+ and Custom. Using the SPORT or SPORT S+ settings, for example, the i-FORCE MAX powertrain makes use of the electric motor’s instantaneous responsiveness. While the electric motor does the bulk of the work at lower speeds, once above 18 mph, the gasoline engine assumes primary operation for excellent performance in the mid- and high-speed range. When in TOW/HAUL mode, the i-FORCE MAX system is constantly in tandem operation to provide impressive acceleration and torque for towing needs.
The view around this stunning SUV is improved as well due to Sequoia’s plethora of cameras, displaying multiple exterior angles that are viewable from the available 14-inch touchscreen or the available digital display rearview mirror. Those trailering will appreciate Panoramic View Monitor, which displays a top-down view of the SUV and the area around it. Options include a rear split view to show what’s nearby on each side of the trailer, and a hitch view to assist with trailer connecting. For the first time on Sequoia, factory available power folding, extending and retracting tow mirrors can provide added peace of mind when pulling a trailer.
Three Rows, Five Grades
Sequoia offers space for families who need it – whether that be to haul passengers, gear or both. It will be available in five grades that include SR5, Limited, Platinum, TRD Pro and the new-to-Sequoia Capstone grade. Each grade has its own unique look and feel, but the team at Toyota’s North American design studio Calty was responsible for the styling and had primary objectives that would carry across the lineup.
“Our primary design goal for Sequoia was to create a sophisticated, yet tough and active lifestyle SUV that looks capable of handling a diversity of big adventure needs,” says Calty President Kevin Hunter. “That holds true whether it’s a night out on the town with friends, towing a boat to the lake with family or taking a more extreme off-road adventure.”
Sequoia’s grade lineup starts with the well-equipped SR5 that offers a strong foundation of power, efficiency and technology. It touts impressive standard features that include the i-FORCE MAX powertrain that is mated to the standard 10-speed automatic transmission, standard Toyota Safety Sense 2.5, moonroof, heated seats and more. It also features a standard 12.3-inch digital instrument display and Panoramic View Monitor (PVM). When upgrading to the SR5 Premium package, Sequoia adds the 14-inch Toyota Audio Multimedia display, power third row, hands-free liftgate, Softex seats, and cabin and cargo 120-volt power outlets.
Also available on SR5 models is the TRD Sport package, which upgrades the standard 18-inch wheels to 20-inch matte black TRD wheels. To complement sporty handling, it adds TRD sport-tuned Bilstein monotube shocks and TRD-tuned springs. Inside TRD accents include aluminum pedals and a red TRD push-button start.
Limited builds upon the SR5 with a clear emphasis on added convenience. Not only does it gain a standard 14-inch Toyota Audio Multimedia touchscreen, but it also adds standard heated/ventilated front seats with memory settings, standard heated steering wheel, power-folding third row and hands-free power liftgate. Limited also receives standard second- and third-row manual sunshades to keep the back half of the SUV sun-free, when needed.
Available for both SR5 and Limited 4×4 models is the first-for-Sequoia TRD Off-Road package. Whereas TRD Sport is more focused on the on-road qualities, TRD Off-Road enhances off-road capability with the addition of a selectable locking rear differential, Multi-Terrain Select that helps controls wheel spin for improved traction and Downhill Assist Control to aid with steep descents. Crawl Control also comes standard, functioning as an off-road cruise control for low-speed trail navigation in 4WD Low. To keep a better eye on trail obstacles, TRD Off-Road also comes with Multi-Terrain Monitor to provide a better view of hard-to-see spots for the driver. TRD-tuned Bilstein monotube shock absorbers and TRD-tuned springs are added, and a red front axle driveshaft provides added flair. Inside, aluminum gas/brake pedals are included, and a red TRD push-button start button adds to the performance look and feel. Both SR5 and Limited are outfitted with unique 18-inch alloy wheels unique to the package.
Stepping up to the Platinum grade puts an emphasis on added comfort and premium features, thanks to heated and ventilated front and second-row, second-row captain’s chairs, standard 14-speaker JBL® Premium Audio system, standard panoramic moonroof, standard Head-Up Display and more. High-grade LED headlights and taillights are added, along with sequential turn signals. Rain-sensing wipers are added to Platinum, as is standard Qi wireless charging.
TRD Pro is a great option for adventure-minded families that plan to get off the beaten path regularly. TRD Pro is not just an off-roader though, as it is loaded with premium features such as standard second-row captain’s chairs, TRD heated steering wheel and TRD accents on the seats and shift knob. TRD Pro comes with additional cargo hauling options thanks to the TRD roof rack. TRD-tuned FOX internal bypass shocks offer a smooth on-road ride, but most importantly, they can confidently handle off-road terrain when the trail gets rough. A 1/4-inch aluminum TRD front skid plate offers added trail protection. Sequoia TRD Pro also offers additional trail capability with a standard selectable locking rear differential, Multi-Terrain Select, CRAWL Control and Downhill Assist Control. TRD Pro proudly sports a heritage-inspired “TOYOTA” grille with an embedded TRD light bar and marker lights toward the top of the grille. It’s equipped with Pro-specific black 18-inch TRD alloy wheels with an increased offset to provide a wider stance. A dual TRD Pro exhaust tip provides added growl and visual appeal.
The Capstone grade sits atop the Sequoia lineup, building upon the great features of Platinum while adding additional top-shelf features to make it the most luxurious Sequoia to date. Capstone features unique chrome accents to provide an upscale appearance, with the most eye-catching feature being the standard 22-inch chrome wheels – a first for Sequoia and exclusive to Capstone. The premium cabin experience begins at the first step with standard power running boards that provide access to the standard semi-aniline leather-trimmed seats. Not only are the seats luxury-grade, but they also tout stylish perforation and a Capstone-exclusive black-and-white color combination. The center console and passenger-side dash are accented with authentic American Walnut with an open-pore finish that highlights the wood grain. On the dash, the Walnut pieces surround a Capstone logo that is accentuated with LED mood lighting when the doors are opened. To help provide an even quieter cabin, Capstone is the only Sequoia grade to feature acoustic glass in the front doors for more exterior sound deadening.
A wide variety of colors are available on the all-new Sequoia, including White, Wind Chill Pearl, Celestial Silver, Lunar Rock, Magnetic Gray Metallic, Blueprint, Army Green, Midnight Black Metallic, Smoked Mesquite, Supersonic Red and the TRD-exclusive Solar Octane. Premium paint colors* Wind Chill Pearl and Supersonic Red are available, and the premium color Solar Octane is exclusive to TRD Pro models.
*Premium paint colors will be available for an additional cost. Pricing will be available closer to the on-sale date.
New Toyota Audio Multimedia
Sequoia will be fitted with the new multimedia system first launched in Tundra. It is headlined by a large 8-inch or available 14-inch touchscreen that controls the all-new Toyota Audio Multimedia system designed and engineered by Toyota’s Texas-based Connected Technologies team. The Toyota Audio Multimedia system offers an improved user experience thanks to new sight, touch and voice activation. With Intelligent Assistant available through Drive Connect*, simple phrases like “Hey Toyota” awakens the system for voice-activated commands to search for directions, find POIs, adjust audio controls, change the cabin temperatures and more. The cloud-based native navigation system offered through Drive Connect allows for real-time Over the Air updates for mapping and Points of Interest (POI), and Google POI data is integrated to ensure up-to-date search capability. It also supports standard wireless Apple CarPlay® and Android Auto compatibility.
Toyota Audio Multimedia allows for simultaneous dual Bluetooth phone connectivity. A Wi-Fi Connect subscription offers 4G connectivity for up to five devices by turning Sequoia into an AT&T Hotspot*, and it also offers the ability to link your separate Apple Music® and Amazon Music subscriptions to your vehicle with Integrated Streaming.
Active Safety System: Toyota Safety Sense
All Sequoia grades come standard with Toyota Safety Sense 2.5. This active safety system includes Pre-Collision System with Pedestrian Detection that features multiple enhancements over the previous generation, including not only detecting the vehicle ahead but also a pedestrian in low light, bicyclist in daytime, an oncoming vehicle and a pedestrian at intersections when making a turn. At intersections, the system is designed to detect an oncoming vehicle or pedestrian when performing a left-hand turn and provide audio/visual alerts and automatic braking in certain conditions. Emergency steering assist is an additional function designed to detect pedestrians and stabilize the driver’s emergency evasive steering maneuvers and help prevent lane departure.
Sequoia will be equipped with Dynamic Radar Cruise Control (DRCC). Lane Departure Alert with Steering Assist is designed to notify the driver via audible and visual alerts and slight steering force if it senses the vehicle is leaving the lane without engaging a turn signal. When DRCC is set and engaged, Lane Tracing Assist uses visible lane markers or a preceding vehicle to help keep the vehicle centered in its lane.
Automatic High Beams are designed to detect preceding or oncoming vehicles and automatically switch between high beam and low beam headlights. Road Sign Assist is designed to recognize certain road sign information using a forward-facing camera and display them on the multi-information display (MID).
Toyota’s Rear Seat Reminder comes standard on Capstone and all 2023 Sequoias. The feature can note whether a rear door was opened within 10 minutes of the vehicle being turned on, or at any time after the vehicle has been turned on, with a reminder message in the instrument cluster after the engine is turned off, accompanied by multitone chimes.
In addition to the TSS 2.5 system, other standard safety features include Blind Spot Monitor, which is designed to help detect and warn you of vehicles approaching or positioned in the adjacent lanes. Rear Cross Traffic Alert can offer added peace of mind by helping to detect vehicles approaching from either side while backing out and alerting you with a visual and audible warning. The Front and Rear Parking Assist with Automatic Braking is designed to implement brake control when there’s a possibility of a collision with a stationary object, approaching vehicle or while parking.
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300
Burrcold5324.50
S1nner126.00
DrFerry6728.50
      01-25-2022, 09:01 PM   #2
damnitBobby
Drives: 2018 M3 ZCP
Nice. I would totally get this over the LX600.
      01-25-2022, 09:12 PM   #3
Burrcold
Drives: 2024 M3 Comp xDrive
Nice looking. Manufacturers need to stop the trend of spelling out the model on the tailgate.
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
AlexFL7837.00
      01-25-2022, 09:26 PM   #4
AlexFL
Drives: BMW
This car is going to be a huge hit. Great job by Toyota! I would take the TRD Pro one.
      01-25-2022, 10:39 PM   #5
M3WC
Drives: BMW
Front looks a lot better than the Tundra.
The giant Toyota over the glovebox in the TRD version is absolutely disgusting.
      01-26-2022, 01:30 AM   #6
chassis
chassis's Avatar
6566
Drives: 9Y0 Cayenne S
Toyota knows what they are doing.
Love the two tier rear load floor, from the turn of the century 4Runner. Cool feature.
Need to fully digest what’s going on here.
      01-26-2022, 01:47 AM   #7
DanMpower
DanMpower's Avatar
Drives: BMW M3s and a Red VW
Toyota is on a roll, a lot of their newer designs are quite stunning.
Wish I could say the same about BMW.
      01-26-2022, 07:41 AM   #8
wtwo3
wtwo3's Avatar
17971
Drives: 23 X7 40i; 23 M3; 24 cooper s
This thing looks like an absolute beast. It looks like if you hit it with a rocket launcher it wouldn't even scratch.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT
2024 Mini Cooper S Convertible
'20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima
ntg442888.50
nicholasn261.00
      01-26-2022, 08:37 AM   #9
W///
W///'s Avatar
7494
Drives: F82GTS, E36/E92M3, Z4M
Interesting you say that, because most of the feedback from previous Tundra owners is that this is the worst front end ever made.
Personally, I'm a big Toyota truck/SUV fan, they make such amazing DD's, even though the MPG is usually not so great. There's something great about knowing you drive some of the most bulletproof cars out there. I miss my Tundra big time.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      01-26-2022, 08:55 AM   #10
jmack
jmack's Avatar
549
Drives: OG M2, E70 X5M
Looks much better than the new Tundra, even though it's styled similarly it looks much more balanced. Should be good competition for the Tahoe and Expedition, which the old Sequoia hasn't been competitive with for a decade.
      01-26-2022, 09:47 AM   #11
heavyD^2
heavyD^2's Avatar
Drives: X3M Competition
Please elaborate on which of their models are "stunning". I think Toyota has made strides in design in that their vehicle no longer are the blandest on the planet but outside of the Supra or maybe the GR86 I don't see anything close to stunning. This doesn't look bad but stunning isn't a word I would use to describe what's essentially a large, boxy SUV with a monster grille.
      01-26-2022, 10:41 AM   #12
DanMpower
DanMpower's Avatar
Well maybe it's just a matter of opinion but I think the new GR86 is stunning, I think their Venza (higher trim), Avalon (Nightshade), Corolla (XSE), TRD PRO trucks (Tacoma and 4Runner), and even their Sienna all look fantastic, best in class looks wise to me.
This new Sequoia is stunning to me, maybe I'm just old with kids but I was watching the whole video with my mouth open and a little drool running down the side.
      01-26-2022, 12:23 PM   #13
AlexFL
Drives: BMW
I agree about the new Sequoia. Looks like it will be the best full size SUV on the market. Good traditional “American SUV” looks, nice tech, strong engine, and of course the legendary Toyota reliability.
      01-26-2022, 12:50 PM   #14
dizz81
Moving on
313
Drives: 2018 Mineral White F82 ZCP 6pd
I'm loving the look of this. I agree with some of the remarks about the branding on panels. Manufacturers need to stop putting the gaudy lettering on everything. Just keep it clean and simple. Nobody gives a shit to see the name splattered everywhere, we want to see the clean design panels (my opinion of course).
2011 Blk M3 ESS VT2 625/ES Race *Sold*
2018 MW F82 ZCP 6spd *Sold*
2021 Audi S5 SB
      01-26-2022, 02:23 PM   #15
maxdriver
maxdriver's Avatar
88
Drives: ‘23 GRolla; MDX S
Can only imagine what the markups will be on this. Standby for the new 4Runner!
      01-26-2022, 02:31 PM   #16
chassis
chassis's Avatar
6566
- two speed t/case and optional rear locker
- 9k lb towing capacity
- semi aniline leather option
- real walnut trim
Dislikes:
- hybrid is the only powertrain option, looking for the ICE only version
Observation:
- wide range of options and models with no mention of content restrictions due to chip supply. Has Toyota solved the situation for themselves?
      01-26-2022, 03:16 PM   #17
stein_325i
stein_325i's Avatar
No_Country
25085
Drives: A Car
      01-26-2022, 05:11 PM   #18
Germanauto
Germanauto's Avatar
Drives: Alfa Romeo Giulia, Rosso
Massive improvement.
Former
-2008 E90 328 black/brown
-2012 Lexus IS250 black/black
      01-26-2022, 11:49 PM   #19
MaC-N54-E82
S58 Love
MaC-N54-E82's Avatar
Drives: 2023 M4 Competition xDrive
Yes please! 👏🏻
MAC
Current: 2023 G82|BG over BLK
Prior: 2008 N54 E82|AW over CR
Also: FJ60, Volvo Recharge
      01-26-2022, 11:55 PM   #20
Sedoy
Drives: F10
Jeez, NiMH battery in 2023, while cheaper RAV4 gets Li-ion battery... Toyota ?
      01-27-2022, 12:51 AM   #21
D22M2
Drives: Not a real M Car
Nice!!
      02-03-2022, 10:24 PM   #22
jnj2455
Drives: 440i 6MT/RWD/MPPSK/2VF
I know I'm in the minority here but I will never fully understand why we Americans love these gaudy offensively large skyscraper on wheels.
I like the handsome rugged looks and proportions, sure, but all these massive SUVs are just overkill IMO.
nicholasn261.00
Mavus2032.50
