03-03-2019, 02:26 PM | #23 | |
Rep 1,966
Dog Face Pony Soldier9719.50 |
03-03-2019, 03:13 PM | #24 | ||
2006 TIME Person Of The Year
9720
Rep 6,445
All this being said, if there's a relatively confined listening area, and you can achieve proper speaker positioning, then of course I'd run a stereo signal. I don't want to digress too much, but this same theory of running mono also applies to in-ceiling speaker locations in common distributed "whole home" audio systems. Usually the speakers are placed in relation to lighting fixtures, and not listening positions. For this same reason mono is often a better choice. BTW... While this is my opinion; it is coming from a person with a degree in audio engineering, and decades of experience designing, installing, and tuning audio (and video) systems.
2000cs3496.50 Grumpy Old Man6476.50 |
03-03-2019, 03:22 PM | #25 | |
Rep 1,966
03-03-2019, 03:26 PM | #26 |
Rep 2,404
If you don’t care about wiring them, then I would get a sonos amp and any outdoor speaker you want. Not sure why anyone needs the sonos outdoors speakers if they have to be wired back to the amp either way.
03-03-2019, 03:51 PM | #27 | |
9720
Rep 6,445
While I haven't spoken to any of my friends at Sonance about exactly how deep the tailoring went towards designing these SONOS-orientated speaker products, I don't expect anything earth shattering. I will say, there are some small accommodations that you can do if you know what specific amplifier will be driving the speaker. This is the big advantage of using active monitors, over passive monitors and an external amplifier. Perhaps Sonance made the speaker more sensitive (think: efficient), at the cost of sacrificing power handling you don't need with a SONOS ConnectAmp? 🤔 For those unaware... Sonance is an absolutely first-rate architectural speaker company. I love how their in-ceiling speakers let the entire midrange and tweeter (not just the tweeter) pivot on an eyeball. I'm a big fan.
03-03-2019, 05:23 PM | #28 |
Rep 472
active speakers would be way to go but then they need power access. passive speakers definitely cheaper but then they gotta be amped and have some wireless receiver. id take a look at the BlueSound options - i can vouch that they sound decent but they dont have dedicated outdoor models. the klipsch outdoor speakers look decent. a cheap option if you already have a receiver would be to add yamaha wxc-50 to your current setup then just wire some outdoor speakers. keep in mind that long cable runs are less than ideal especially with inexpensive small gauge speaker wire...
if price were no object theres lots of options. hard to make a decent rec without a budget, what are you looking to spend? this is one of those things you could spend 1000 or 100000 dollars on. best to set budget then consider options. theres many active speakers that have bluetooth or wifi built in.. some of them are truly fantastic. Last edited by stbm5; 03-03-2019 at 05:28 PM.. |
03-03-2019, 10:04 PM | #29 | |
Rep 774
Drives: E90 335i & E60 550i
Pure S2 Turbos | Vargas Outlets | RB Inlets | OEM SS Kit & Performance Steering Wheel| LCI Rear Conversion | Euro Xenons | RD Sport Quad Exhaust | Spearco Intercooler | Cobb V3 | MORR VS7 | KW V3 | H&R Sways | Mtech Bodykit | Vorsteiner CF Hood, CSL Trunk & Front Lip | Quaife LSD | Rotora BBK | GruppeM Intake | Forge UK DV | AR Design Catted DP's
03-03-2019, 10:08 PM | #30 | ||
9720
Rep 6,445
03-03-2019, 10:19 PM | #31 |
Rep 774
I am actually a Sonos dealer as I am in the home/commercial automation and integration industry. I just looked into it to refresh my memory. It is definitely not a manual option. I cannot share details as it is not released yet but it has something to do with the unique hardware signature of the Sonance speakers that they are using to automatically detect.
03-05-2019, 05:36 AM | #32 | |
Rep 12,726
Instagram; @roastbeefmike
spazzyfry1234358.50 |
03-14-2019, 11:20 AM | #33 |
Rep 239
I think sonos is great, i used to have Harman kardon. But since we were moving i wanted something else.
So now i have the sonos playbar, sub, 2 play 3s in the livingroom. And 2 play 1s for the backyard. Only problem is you need good wifi if not connected with ethernet cable. My wifi in the backyard isnt great so i wired them with eternet cable. But you also need your phone with wifi to control the speakers. Need to find a good solution for that, since im getting tired walking to the house to change volume |
03-14-2019, 11:54 AM | #34 | |
Rep 1,004
ramonE90-NL34.50 |
03-15-2019, 05:42 PM | #35 |
9720
Rep 6,445
When it comes to high-end WiFi access points you only need to know one word... Ruckus. Their antenna technology is amazing. The only thing I'd use for demanding applications in congested environments like Manhattan.
https://www.ruckuswireless.com
03-16-2019, 10:06 AM | #36 | |
Rep 472
03-16-2019, 10:13 AM | #37 | ||
9720
Rep 6,445
https://ruckus-www.s3.amazonaws.com/...-portfolio.pdf
03-19-2019, 11:32 AM | #38 |
Rep 600
I can vouch that both of these sound good and perform well outdoors.
https://www.klipsch.com/products/out...s?model=aw-650 https://www.klipsch.com/products/out...del=awr-650-sm |
roastbeef11586.00 |
03-19-2019, 11:49 PM | #39 |
Rep 9,032
OP, Sonos 1's are fine outdoors as long as they don't get direct rain.
They have an Alexa version so you can start the music as you're opening your beer. You just tell Alexa to play xxx Artist or xxx's Playlist on Amazon Music or Spotify. Set an alarm or tell you the score on a game or what the weather is tomorrow. No phone needed. You do want a good wifi signal. Mesh systems seem to do the trick, then you can skip the connect. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
03-20-2019, 09:14 AM | #40 |
Rep 12,726
Here's another thought guys... I've hand this klipsch home theater system for about eight years now. It's not WiFi/blue tooth, but after using it for my home theater, is there something I can buy to piggyback off of it for the purposes of what I want?
edit- receiver is onkyo
03-20-2019, 10:36 AM | #42 |
Rep 600
I bought this to power my outdoor speakers. It has plenty of power to do the job on the speakers I posted earlier. It is a referb, mine arrived in perfect condition. Has bluetooth and wifi. You can steam music from your phone or tables and use the denon remote app to adjust volume and settings.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I use this one to power my home theater in a 9.1 configuration. I have been pleased with the outcome. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Last edited by Nuckle; 03-20-2019 at 11:58 AM.. |
