10-15-2018, 01:22 PM | #24 | |
Rep 1,965
Previous post edited. Good catch! |
10-15-2018, 01:25 PM | #25 |
Rep 1,965
No he wouldn't!
He would start a thread here about it, then make a video, then post it on youtube, then post it here, then hire a contractor to do it, then post a video about not being sure it was done right, then get upset after everyone makes fun of him. |
10-15-2018, 03:46 PM | #27 | |
Rep 3,241
wdb4721.50 |
10-15-2018, 03:50 PM | #28 |
2006 TIME Person Of The Year
9720
Rep 6,445
If it's a new display turn it on and test it before doing anything.
Definitely only mount your tv by grabbing studs... At least one stud plus anchors! Two stud minimum for articulating. It's worth it to buy a nice mount (Chief) if you going articulating. I personally would only buy Chief regardless of type. Keep in mind articulating mounts fold up thicker and your display will stand off the wall more. Run a hard wired network connection (Cat6) to the TV and any external streaming sources (AppleTV for example) if possible. Add two spare Cat6 for future use. I'd run a optical digital (Toslink) cable while I'm at it... Audio Return Channel is finicky. Make sure you're running an 18gbps-capable HDMI cable. You're going to need more than one HDMI if your TV is going to be tasked with switching sources. Companies make "bridge kits" that let you relocate power and stay within code. This is an example from Datacomm.... https://datacommelectronics.com/prod...t-blade-inlet/
Violator4587.50 |
10-15-2018, 04:14 PM | #29 | ||
Rep 14,522
Violator4587.50 |
10-15-2018, 07:52 PM | #30 |
Rep 611
Drives: ‘18 M240i, Estoril Blue
BE sure to install at least FOUR power outlets behind the TV, not just TWO.
—Steve
'19 MX-5 Miata GT-S soft top Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i |
Violator4587.50 |
