08-14-2019, 11:16 AM | #243 |
Rep 444
Hikvision, Nest - audio recording
With Nest, keep in mind that there is no onsite DVR capability. If you want any recording capability, you have to create a on-going subscription with Nest to the tune of ~ $5/mo for each camera. This also forces you to provide a copy of the recorded data to Nest. I am comfortable with doing this for data collected outside my home. I would not do this for data collected inside my home.
If you plan to do any audio recording, make sure you check you local laws. Some states require two/all person consent to record audio. A good combination may be one Nest with 5-day remote storage combined with an onsite DVR connected to multiple non-Nest cameras. This gives you remote monitoring/notification capability using the Nest app (via the single camera) and full coverage using the other (DVR-connected) cameras. Check out Hikvision for a broad range of cameras depending on required resolution and capability. Some of their DVRs also allow you to view any camera stream on their app when the DVR and the device running the app are on the same LAN. I believe this can also be expanded to allow you to view any camera stream if the device running the app can connect to the DVR remotely (non-LAN). Last edited by bayarea328xit; 08-14-2019 at 11:52 AM.. Reason: corrections |
MPBK449.00 |
08-14-2019, 11:21 AM | #244 |
Rep 769
I use the "Ring" door camera and one in the backyard. Very happy with resolution, Ring support, set up and Apps.
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
08-14-2019, 11:32 AM | #245 |
Rep 534
Just went through this after having my cars broken into over the course of one evening. I went with a Network video recorder system that has power over ethernet cameras aka POE. POE is great you only need to run one network cable for power and data. Whatever you go with make sure the cameras are POE.
I went with a Reolink system. Very easy to put together and accessible anywhere via the mobile app that is available for ios and android. Link: (check em out lots of solutions) https://reolink.com/ (also prime on amazon so you can easily return if you don't like the system) They have decent cameras one is even 4k and has good detail I used that pointing to the street since my driveway is very long. All the extra pixels go a long way. This is the mobile app:
Fritzer942.50 |
08-14-2019, 11:34 AM | #246 | |
Rep 534
08-14-2019, 01:17 PM | #247 |
Rep 5,983
I have Nest Doorbell. Works pretty good but you should get the $5 a month cloud plan to get the most out of it. Also brought a wyze cam for $19.99 that has 14 days free cloud storage for notification recordings only and continuous recording on an SD card.
08-14-2019, 01:33 PM | #248 |
Rep 1,904
Blink XT cameras by Amazon. Motion triggered, battery powered, recording to the cloud included for free (I think up to 7 days of recordings free).
I bought a set of 3 for the house and now bought another 3 we setup in the RV when we have it parked somewhere. You can dial in the motion sensitivity and areas pretty well so they are not constantly triggered for nonsense. Biggest downside is they obviously don't work when there is no internet and you have to change batteries, although mine are still full after like 3 months. Will obviously depend on how often they get triggered though. |
08-14-2019, 07:52 PM | #249 |
Guest
Rep n/a
Drives:
OP: if you don't end up going with a Ring, Nest, etc. type solution, I'd go with standalone IP cams and a dedicated NVR.
The latest/greatest is the 24/7 Color offering from LTS: http://www.ltsecurityinc.com/4-mp-fu...rk-camera.html Attached you'll find a screenshot I took of one I have up at a car lot in the Northeast. In this pic, there are (3) traditional 4MP IR mini dome cams and (1) of the 24/7 Color turret cams I mentioned above. This shot was taken at 3 AM after a rainstorm...yeah, it's that good. Cost is ~40% more than a traditional 4MP turret, but the results speak for themselves. Either way, go LTS for cams for sure. They are a US based company and if you buy direct from them, you won't have to worry about receiving a hacked/bricked Hikvision or Dahua from other random vendors on Amazon or eBay. I'd also go with turrets over dome cams for a number of reasons (ease of install, much less chance of water penetration, no IR bounce back, etc.). If you have a spare Windows machine kicking around, no need to buy an NVR either; just load this free VMS software onto it and you'll be in great shape: https://www.luxriot.com/product/ip-c...e/luxriot-evo/ Last edited by FCobra94; 08-14-2019 at 08:20 PM.. |
08-14-2019, 08:08 PM | #250 |
Guest
Rep n/a
Drives:
No worries there...just replace the existing cams with HD-TVI equipment:
http://www.ltsecurityinc.com/hd-tvi-...me-turret.html Tons of high MP cams out there that will operate just fine on that existing infrastructure and they're CHEAP!! |
08-14-2019, 08:31 PM | #251 |
Rep 20
Yi technology
https://www.yitechnology.com They sell both outdoor and indoor wifi connected cameras at very reasonable prices. Camera resolution 1080p with motion capture, etc. Added benefit is that the cameras have a slot for a max 32G Micro SD card so you can self monitor. App is very user friendly - can easily review motion capture footage and download motion capture video to your phone. They have options for cloud storage, but I've found it to be very slow. I've built a system comprised of 4 outdoor cameras and one indoor camera which I enable when we leave on trips. Very satisfied with the purchase. Nest is top quality for sure, but the cost of cloud storage adds up quickly. |
08-14-2019, 11:44 PM | #252 |
2JZ-GTE
2959
Rep 3,948
If you were going to do wired/POE what is the recommendation for set up if money is no problem. Requirements being the highest resolution and night visibility.
08-15-2019, 07:26 AM | #253 |
Rep 1,011
...thats my exact use case. 8 X 8.5MP IP/POE cams from Lorex, using two types of turrets. Then an NVR with 8TB using a RAID array of 2TB / 6TBs for atleast a month of storage recording continuous. Then I added a Ring wired for power doorbell to have that convenience, and finished with another Ring cam that has a siren which I can use as a panic button so to speak if I saw someone trying to so something and scare them away. The resolution is 4K and full color at night as long as you have some ambient lighting.
08-15-2019, 03:35 PM | #254 |
Recovering Perfectionist
14884
Rep 938
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
I picked up two Reolink 4MP wifi IP cameras on an Amazon Black Friday sale two years ago, and had them linked to my home Synology NAS. When I wanted to add a third camera last fall, I found out that the NAS only supported two and would need to be replaced with a much more expensive unit to add additional cameras.
I picked up a basic Amcrest NVR with a 4 TB video-grade hard drive from Amazon, along with an Amcrest wifi 4MP camera. The Amcrest NVR and Amcrest camera work great together, since they both do H.265 video. The Reolink cameras only do H.264, and seem to be struggling with wifi bandwidth with the Amcrest NVR despite performing acceptably with the Synology NAS. Long story short, all of the cameras support PoE, and I just had a new PoE ethernet switch arrive yesterday that will eventually wind up being wired to all three cameras as well as two more that I want to add. The Amcrest NVR interface on the device is clunky, and only supports a mouse and HDMI TV output. The software they provide is nothing to write home about, and is missing basic functions like a video jog feature on playback. It is usable enough remotely to check up on the lawn service or see if the mail carrier has delivered yet, but painful if you need to look for a specific event over several days even looking at the motion-triggered timelines. I live on a dead end street, and have the H.265 Amcrest camera hidden on a fence post at the side of the road. It has a really good shot at passing license plates during the day, and occasionally gets a legible rear plate at night because the headlights aren't washing it out. I want to pick up a second camera for the street with an IR-only lens filter and external IR illuminator, just for night time license plates. One of my neighbors further down the road had his outboard boat motor stolen back in the spring, and I was able to give the police a time-stamped vehicle pictures including the license plate number.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
08-15-2019, 07:32 PM | #255 | |
Rep 3,972
08-19-2019, 08:11 AM | #257 | |
Rep 3,972
Signed up for an account and still can't see a price, i'll search around to see if there is anywhere else i can buy from.
08-19-2019, 08:53 AM | #259 | |
Guest
Rep n/a
Drives:
https://www.nellyssecurity.com/4mp-e...lorvu-dm2.html |
tdott3930.50 |
08-28-2019, 05:08 AM | #260 |
2006 TIME Person Of The Year
9720
Rep 6,445
First, I used to sell camera systems at the national distributor I used to work for.
While I use nest cams, I only need 3 cameras, to cover my small condo. Plus my gf likes the remote access to check in on (and talk to ) our cats. The nest system is very friendly for remote access/monitoring, and reviewing/sharing footage. The drawback is the reoccurring fee for cloud storage, and the traffic added to your home's network. Most people with a home using 4-8 cameras are likely better off getting their surveillance system off their data network, and using a proper IP camera system with a local NVR. I second using LTS, but Hikvision is a major Chinese manufacturer a lot of people use. Personally I recommend people stay away from the crap systems seen at Walmart and such. I've seen plenty of times where the footage these systems captured was useless for anything other than confirming that something happened; and nowhere near detailed enough to identify anyone or anything.
08-28-2019, 08:54 AM | #261 |
Rep 11,128
We actually have a pretty large thread specifically dedicated to home security cameras here:
https://f15.bimmerpost.com/forums/sh....php?t=1132696 My entire system (9 cameras now) is based on LTS cameras. I'm actually in the process of upgrading them all to 6MP. |
08-30-2019, 07:27 AM | #262 |
Rep 1,965
Considering a 10 camera system for my place soon. 1 camera on the front door, 1 camera on the driveway, 1 camera on my front deck, the remaining 7 will go in my bedroom. Also looking at an 8TB external HDD If I'm going to have a camera system, I want to record something I actually want to watch.
08-30-2019, 07:17 PM | #263 |
14884
Rep 938
The videos of those other 7 cameras would all easily fit on a 3.5" floppy disk...with room to spare.....
08-31-2019, 01:57 AM | #264 |
Rep 301
Drives: BMW M235i
I highly recommend buying poe cameras like Dahua Starlight and using with Blue Iris and a NAS combined with an encrypted online backup service.
I wanted nothing to do with monthly fees or my video being stored on a cloud service owned by Google, Amazon, etc. |
jimbobiggens839.00 |
