03-27-2020, 08:26 AM | #1 |
Rep 267
Drives: 2006 Z4 M Roadster
Do ram air products really work on a BMW?
Folks -
First let me say that I know ram air has been proven to work on some car setups, particularly the older muscle cars which came this way from the factory. I’m interested to hear your thoughts/experience with ram air or scoops that are marketed for our BMWs. BMW is damn good at squeezing power from their engines, so the fact that Z4s didn’t come with an air scoop leads me to think that it’s not very effective. Otherwise I’d expect that they would have implemented something like the RPI scoop on our cars from the factory. At $130, I’m not willing to try it as I feel that money is better spent on basic maintenance items to keep the car in top notch running condition. If it does work then $130 is a no-brainer. Thoughts/experiences?
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
03-27-2020, 02:03 PM | #2 | |
Rep 49
Drives: Z4MR
Yes and no...
The factory air horn behind the grille is actually a small restriction. You can remove it for free and get the same gains as the after market "scoops". The restriction is only 2inH20 or 0.07PSI so not much! Proper ram air has a shape that allows the air to slow down after it enters to build pressure. You also need to be travelling 150mph to get even 0.4PSI out of it. From this page: https://www.musclecardiy.com/perform...se-horsepower/ Quote:
wdb4721.50 |
03-27-2020, 06:34 PM | #3 |
Rep 2,782
This is my setup on my 3.0i. I had to retune the intake manifold tables in the ECU to account for the higher airflow, so I know it works.
03-27-2020, 07:47 PM | #4 |
Rep 267
That’s a nice setup pokey. True cold air intake.
Salty Dog3574.50 |
03-28-2020, 06:19 AM | #5 | |
Down Under!!
1621
Rep 4,294
following .. (pulls out shitty manual) Pram=0.5x P x V^2 Pram obviously being ram pressure in PSI/Sft^2 P being sl air pressure in slugs.. V^2 is the speed in feet/sec so lets take a look see. P = constant (depending on alt, but lets assume SL) 0.0023769 V^2 at 150 mph is 220 feet/sec (close enough for government work) anyways, plug it all in at youll get somewhere around 57 PSI/square feet. which is actually a considerable amount, obviously depending on what your surface area is and what restrictions you have going to your inlet. (this has been talked bout a lot before on this forum) And again, dependant largely upon the surface area of the intake. Which ours is actually super small. The scoop, increases that surface area by a bit, which is why it works. at any rate, lots of variables, so many in fact that looking at a single part of those variables is useless (The intake restrictions). nothing for nothing staying NA, esp without a tune. Bored as hel isolation, otherwise I Def wouldent have bothered. Lol
Powered by Last edited by Vanne; 03-28-2020 at 06:34 AM.. |
03-29-2020, 10:25 AM | #7 |
Rep 49
Drives: Z4MR
Intake modifications should focus on 1) coldest possible air and 2) lowest possible restriction. Forget ram air.
#1 is already done from the factory. #2 is close, I measured 14inH20 and it's possible to get it down to 7inH20 by removing the scoop, charcoal filter and MAF screen. The 06+ ECU can absolutely compensate (up to a point) assuming the MAF section remains unchanged. It also has wideband O2s for closed loop fueling even under WoT. My logs show it's right around 13.0 AFR so why mess with it. |
04-18-2020, 08:29 AM | #8 |
Rep 484
What Pokeybritches has shown above is definitely NOT a ram air intake. Any difference he has found is likely due to less restriction from the cone filter and routing.
His setup has merely moved the cone filter further into the high pressure area in front of the radiator. Air is free to move around that cone filter. I am also skeptical of gains to be had by air intake scoops like rpi. I made a larger scoop and sealed it to the kidney grill, but doubt it really does anything when you consider the rest of the path the air has to take before getting to the throttle bodies. Measuring air pressure at the TB’s would be the only way to verify efficacy. If one were to take a CSL air box and route the 8” intake tube straight out to the front of the car with a large trumpet opening, say 12”, then maybe at 150 mph you would see an increase in air pressure at the TB’s. But then you would have to consider the aerodynamic drag introduced by this ram air. Gains in HP may be more than offset by drag. The fact that you see no development and use of this type of intake on road race cars, and even no rules time attack cars, answers this question... |
Residentj3553121.50 |
04-18-2020, 09:17 AM | #9 | |
Rep 267
04-18-2020, 12:56 PM | #11 | |
Rep 2,782
Whether you can call it a ram air system is moot IMHO. Placing the filter into an area with high dynamic pressure might increase the static pressure in the intake tubing when the throttle body is closed, and then again it might not. Mass flow and temperature are ultimately more important. Higher pressure at the filter and reduced restriction will increase flow. The heat shield and filter location help prevent heat soak. I normally see IAT at the MAF sensor (located just before the supercharger inlet) 2-3 deg higher than ambient, no matter how hard I drive the car. I got the idea to develop an OTR intake from LS Holdens, where OTR intakes are a popular mod that provides ~20 whp gain. This isn't just forum BS - I've seen these cars get tuned independently on the dyno and show real power gains of 20+ whp. Instead of measuring pressure at the TB, why not monitor MAF voltage, since that's ultimately what's important? I'd expect the pressure would vary wildly at an ITB on a Z4M due to the intake manifold design.
04-18-2020, 07:29 PM | #12 |
Rep 484
You’ve given a very good analysis on the benefit of a cold air intake...but the OP was asking about ram air intakes. Something that someone with a forced air induction system would have no interest in. You’re mechanically pressurizing your intake charge. Ram air alleges to do the same thing as your supercharger to a lessor extent by capturing free air flow and ramming it into the intake, thereby creating a pressurized charge...Which is bogus, IMO.
04-18-2020, 09:04 PM | #13 | |
Rep 155
Drives: M4; X4 M40i
04-22-2020, 09:05 AM | #14 |
Rep 49
Drives: Z4MR
Water, dirt and bugs mostly. Definitely a restriction though, 2inH2O measured at WOT.
