01-16-2020, 11:56 AM | #1 |
Rep 145
Z4M calipers -> M3 E46
Can someone confirm if I can pull the OEM calipers from a Z4M and install them on a E46 M3 (2001 w/ non zcp/csl brakes)?
At the same time I'd be swapping out the rotors to CSL ones on the M3. Thanks |
01-17-2020, 08:59 AM | #2 |
Rep 431
Yes, same calipers and carriers. Just remember that the rear brake lines are different lengths.
01-17-2020, 09:43 AM | #3 |
Rep 775
Front calipers are the same. Carriers are the same as the ZCP/CSL (i.e sized for the 345mm rotors). To use non-CSL/ZCP rotors, you need to retain the stock M3 carriers.
Rear calipers and carriers are different (pistons are 46mm instead of 42mm). They will fit the M3, but would move the brake bias significantly rearward (and thus would not be recommended without the front 345mm rotors) |
01-17-2020, 11:02 AM | #4 |
Rep 145
So for the rear brake lines I can reuse the existing M3 lines or transfer the rear lines from the Z4M to the M3 (or neither option)?
thanks |
01-17-2020, 11:37 AM | #5 | |
Rep 431
I agree, if you're going to use the Z4M front calipers, be sure to pair them with the Z4M/ZCP/CSL rear calipers. Yes, you can reuse the M3 rear brake lines.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo Last edited by Azeka1; 01-17-2020 at 01:08 PM.. |
08-22-2022, 12:28 PM | #7 | |
Rep 34
I have a set of e46 m3 rear brackets for the 996 calipers and I'm wondering if I can throw these onto the rear of the z4m. |
09-03-2022, 02:53 PM | #8 | |
Rep 873
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
09-03-2022, 02:54 PM | #9 |
Rep 873
Carriers are the same but the calipers are not.
