      08-20-2018, 11:38 PM   #507
MBan
Drives: BMW 125i
AmanYasirA - thanks for your feedback. What wheel specification do you run with the 255 tyre?
Thanks again M-Cast. I think those alignment settings and wheel specs will be a bit much for me but the car does look awesome.
M-Cast423.00
      11-12-2018, 06:35 PM   #508
JimBob0047
Drives: 2006 Z4MR
Hello I am new here. I installed these 260m(euro spec) on my new to me Z4M today. Stock suspension, got about -1.75 of camber in the front with the stock pins pulled. Running 235/40/18 and 265/35/18 Conti extremes. Absolutely no rubbing. I'm not totally in love with the look but they are wider and lighter than the OE wheels.
      05-04-2019, 07:41 PM   #509
Deniz4
Drives: 2007 Z4m
Hello all, being a recent 2007 z4mr owner, I would like to change my original wheels with Beyern 18". With stock suspension and everything else, could I use the following ?
front 18-8.5" et30 with Conti Extreme contact Sport 245-40-18
rear 18-9.5" et 20 same tires 275-35-18
Will that fit without any modifications?
Thanks.
      05-05-2019, 09:21 AM   #510
Azeka1
Track Junkie
Azeka1's Avatar
Albania
204
Drives: E86 M Coupe
Adding my new track setup here as a data point for others that might be looking to do the same.
Square Setup:
* Apex ARC-8 18X9.5 et35
* Optional 5mm rear spacer
* 275/35/18 Hoosier R7 or
* 275/35/18 BFG Rival (both fit and run very wide)
* Camber: F -3.4 | R -2.4
* Front fenders Rolled
* Spring Type: Linear (JRZ/MCS)
— front fitment may vary if using conical suspension like KW
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | SS Headers | Rouge Exhaust| APEX ARC-8 | APR Aero | Sparco Seats/Belts | Weichers Cage | Solid Motor/Trans/Shifter/SubFrame | Poly Bushings | Race Camber Plates/Arms | CSF Rad/Oil | BW Brake Ducts | Braille Battery | AC/EGR Delete | 3,100lbs
1991 SW20 MR2 Turbo | Widebody | 400WHP/355TRQ | 2017 Audi Q7 | 2010 VW CC 2.0T
Gone: 2014 Audi A6 | 2011 G37 S Coupe 6MT | 2004 G35 Coupe
      05-13-2019, 08:18 PM   #511
rsrider
rsrider's Avatar
Drives: 2006 Z4M Coupe E86
Hey guys, needing some confirmation on tyre sizes for my new wheels on the Z4M Coupe if at all possible. Have read through every page of this thread and no one has the exact setup I am looking at.
Basically I am wanting to know what the widest front and rear tyre I can run is without experiencing any rubbing issues on both standard suspension and also Eibach Pro springs.
Would 19x8.5 ET35 with 245/35/19 fronts and 19x9.5 ET22 with 275/35/19 or 285/30/19 rears work?
Wheels are Apex ARC-8.
Thanks in advance!
      05-14-2019, 12:43 AM   #512
XMetal
XMetal's Avatar
2008 Z4M Coupe  [0.00]
2004 X5  [3.50]
Thanks in advance!
I have the exact wheel/tire specs for the front and it should be no issue. I have 19x9.5 ET25 with 275/30/19 and there appeared to be only about 5mm or so clearance to spare on full/near full compression (I'm running Continental Extreme Contact DW). My guess is that I will be a tight fit with 275s on an ET22. But then again, it all depends on the tire brand as not all 275 tires measured equally across different brands. I'm almost certain that 285 will rub on ET22.
      05-14-2019, 02:10 PM   #513
angelr
I run et 22 10" wheel out back and have run 275's without issue fwiw.
      05-14-2019, 03:53 PM   #514
XMetal
XMetal's Avatar
2004 X5  [3.50]
What tire (brand and model) are you running?
      05-14-2019, 04:50 PM   #515
angelr
iirc I've run that size in nto1, v12 and conti dw. Typically run 265 square which is what I'm on again now.
XMetal455.00
      05-14-2019, 09:48 PM   #516
rsrider
rsrider's Avatar
Are you running 275 35 or only 275 30. I would like to run a 35 if possible as it matches closer to the diameter of the front wheels.
      05-15-2019, 12:12 AM   #517
XMetal
XMetal's Avatar
2004 X5  [3.50]
How do you figure that the 275/35 would be a better matched to the front 245/35 than the 275/30? If you look at the numbers below, you'll see that the 275/30 is a lot closer to the 245/35. The 275/35 is much taller than the 245/35 fronts. On the other hand, if you can fit 285/30, that would be perfectly matched to the fronts. I'm thinking about trying out 285/30 on my next set, but not sure if I want to chance it with rubbing issues.
245 x 0.35 = 85.75 mm sidewall
275 x 0.35 = 96.25 mm sidewall
275 x 0.30 = 82.50 mm sidewall
285 x 0.30 = 85.50 mm sidewall
      05-15-2019, 12:26 AM   #518
rsrider
rsrider's Avatar
Sorry you are right. 275/30 seems to be the better size. Are we sure a 285/30 wont fit?
      05-29-2019, 09:45 PM   #519
rsrider
rsrider's Avatar
Well I had the wheels fitted and they look amazing (in my humble opinion).
Went for 245/35 fronts and 275/30 rears. Tyres are Dunlop SP Sport Maxx 050+ and we have no rubbing at all even on full lock.
Very happy. Thanks for the help!
      06-21-2019, 07:05 AM   #520
kyriian
Drives: 06 Black Sapphire Z4MR
Finally joining the thread
Volk OG TE37
18x9.5 front, +28, +5mm spacer, 245/40-18 RS4, -2.5 camber
18x10.5 rear, +30, +12.5mm spacer, 275/35-18 RS4, -1.8 camber
Current: 06 BMW Z4MR, 11 Mercedes C63, 11 Scion tC
Past: 15 Golf TSI, 11 370Z, 07 MX5, 03 Miata, 03 Cooper S, 96 Civic, 02 Civic SiR
Azeka1203.50
      Yesterday, 03:51 PM   #521
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
When I was selecting wheels / tires, I created this spreadsheet to tell me what the difference would be from stock fitment - basically so that I could use a tape measure against the stock tires / wheels to determine clearance on the inside / outside top of the wheels. Sharing here in case others find it useful too.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
