01-14-2008, 01:12 PM | #23 |
Rep 2,128
01-14-2008, 03:27 PM | #25 |
Rep 1,262
01-15-2008, 07:06 AM | #26 |
Rep 11,667
$100 for 30min? ...seems a little on the high side.
This is a DIY if you can handle a wrench & bleed some brake fluid.
01-15-2008, 07:18 AM | #27 |
Rep 1,262
yeah, a bit more than i wanted to spend... but i watched him... he checked, re-checked, had all the right tools for the job.... was very thorough... plus, i had no desire to climb under my car this time of year.
01-15-2008, 09:08 AM | #28 | |
Z4M CSL
31
Rep 173
I didn't need to bleed the clutch either. When are you heading to the NS? We're there over the Easter weekend (20th - 24th March). Just booked our accomodation yesterday!
01-15-2008, 12:03 PM | #29 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
I'll likely hit every descent weekend that I possibly can for the upcoming season. I live only one hour from the NS. Keep in touch and I'll see about getting up there over Easter. Are you staying at the Hotel Tiergarten? I love the food there!
You have to be 100% behind someone before you can stab them in the back.
David Brent |
01-15-2008, 05:32 PM | #30 |
Rep 6
Has anyone in the Bay Area had this done at a shop? I'm mechanically challenged and want to get someone to do it for my 07 M Coupe that I just finished break in. Just need to find a shop that can do it and has no affiliation with BMW SF.
01-16-2008, 06:46 AM | #31 |
My favorite sign.
169
Rep 4,333
I'm sure the local BMW CCA chapter could point you in the right direction...
01-23-2008, 11:35 AM | #32 |
Rep 821
01-23-2008, 12:04 PM | #33 | |
M Slut
18
Rep 564
Sorry for the pointed jab D.
David Brent |
01-23-2008, 12:13 PM | #34 |
Rep 4,365
I always wondered what that was, I always thought it was a user error! Always happens going into 2nd gear right after I hit a bump! It has only happened when pulling into my workplace.
01-23-2008, 12:54 PM | #35 |
My favorite sign.
169
Rep 4,333
It's all good man. I'll end up doing it eventually...just not on the top of the to do list since I've dealt with it for over a year...
01-23-2008, 02:01 PM | #36 |
M Slut
18
Rep 564
I should be here when you return. I just received another three years to begin this Summer.
David Brent |
01-23-2008, 04:29 PM | #37 |
My favorite sign.
169
Rep 4,333
Nice. Congrats...hopefully mother Army allows me to return
01-28-2008, 05:19 AM | #39 |
Car Guy
31
Rep 796
Lower Shield (cheese grater) is removed by removing 4-10mm bolts
Clutch line is clamped and CDV is removed by first removing hard line (11mm flare wrench) and then CDV from flexible line (17mm flare wrench) Clutch line is bled using pressure bleeder and 7mm wrench Some of the information in my 335i write-up may be applicable (like the pressure bleeding process) found at http://www.billswebspace.com/BMWCDVMod.htm
01-28-2008, 10:22 AM | #40 |
pig pa
Rep 23
desk drawer as well.
01-28-2008, 03:29 PM | #42 | |
Rep 666
Pressure bleed
When you disconnect the flex clutch hose to remove the CDV you will most likely introduce some air into the clutch line. If air is introduced you will feel a very spongy clutch pedal. Sometimes if you let the car sit overnight the air bubble will rise up through the line and disperse into the brake fluid reservoir. I prefer to pressure bleed the clutch system using a Motive Power Bleeder.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
01-28-2008, 07:12 PM | #43 |
391
Rep 3,149
01-28-2008, 07:56 PM | #44 | |
My favorite sign.
169
Rep 4,333
