06-23-2020, 09:09 AM | #1 |
Rep 130
2 dash lights glowing yellow
I have a question. The other day I went on a spirited drive with some friends. Parked the car for awhile and then started to drive home. The "brake and the DSC lights both came on and were yellow. After stopping and restarting a couple of times the lights went away. Any ideas as to why those 2 came on but then went away?
06-23-2020, 11:14 AM | #2 | |
Rep 321
wdb4732.00 |
06-23-2020, 04:37 PM | #3 |
Rep 130
The car is a 2003. I did pull some codes from it I got 3 from the DSC, 5E20, 5E24 & 5E5C
In addition to those I got 4 from the EPS. 61 1B, 61 1E, 61 27, 61 28. The DSC did deal with pressure sensors and the EPS were steering angle & vehicle speed. I wish I understood the Foxwell 530 better as supposedly I can test things with the car on and driving it. Haven't figured out how that works yet. Is it possible the speed sensors in the wheels just need cleaning? Last edited by B328iC; 06-23-2020 at 05:56 PM.. |
06-24-2020, 01:39 PM | #4 |
dances with roads
4732
Rep 4,096
+1 on ModuleMasters, if DSC module turns out to be your culprit. Mine acted up every time the rear end got frisky. I could reset the code but as soon as the module was asked to do anything the lights would come on again.
EDIT: I was getting codes 5DF0 and 5DF1. My code reader also showed me steering and speed sensor outputs so I knew those were okay. Last edited by wdb; 06-24-2020 at 01:47 PM.. |
DEG67.50 |
06-25-2020, 08:04 AM | #5 |
Rep 130
So far all I have done is pull out and clean the wheel speed sensors. Front ones had a lot of metal filings on them but other than that were OK. Drove that car and everything seemed good.
