04-12-2020, 08:01 AM | #1 |
Rep 399
upsizing 265 to 275
Hello folks
will upsizing of 235/35 -> 245/35 and 265/30 -> 275/30 give me a big comfort difference on 19" rims? my current setup feels like too stiff |
04-12-2020, 08:07 AM | #2 |
Rep 1,336
Drives: Porsche 993
I'm no expert but I don't think you'll notice the difference going to a wider tire. I had 19" on my Z4MC and those side walls are pretty short. I think if you want to soften the ride you'd probably have to go to an 18" rim, or softer suspension components.
04-12-2020, 08:28 AM | #3 |
Rep 399
its not about comfort only, I have my 10" rims and 265 looks odd on them, thats another reason for upsizing
04-12-2020, 08:46 AM | #4 | |
Rep 1,336
Drives: Porsche 993
https://www.tyresizecalculator.com/c...rim-size-chart |
AK72286.00 |
04-12-2020, 09:12 AM | #5 | |
Rep 975
I learned my lesson too late as I had bought my tires already, I went back to OE sizes and went with a tire that is too stiff on the sidewall, so the change from the 19s to the 18s was not significant in my case even when I added a significant amount of sidewall height. I was running Falken on the 19s and Now Potenza S007A, which is a good tire and much better to the budget Falken subjectively, but stiffer. On the upside it makes the car feel more direct. Whatever you do, go with a good tire even if you need to budget up |
AK72286.00 |
04-12-2020, 09:51 AM | #6 | |
Rep 399
post #2050 my rear tires are too small for my rims but I got this way and now trying to fix it |
04-12-2020, 09:52 AM | #7 | |
Rep 1,336
Drives: Porsche 993
04-12-2020, 10:32 AM | #8 |
Rep 2,866
Drives: Anything
OP, are you running 10" wide wheels on all 4 corners? If so, that 235 or even 245 are still too narrow for the 10" wheel.
The rear, especially looked stretched in your post. I don't remember 275 on a 10" wide wheel being that stretched, so may be going to 275 will help a bit. As "maupineda" indicated, tire is a factor too - not all 265/30 have the same treadwidth. Some have more squarish shoulders than others. I think 285/30/19 is best on a 10" wide wheel. Even my 275/30/19 Conti's on 9.5" wide wheel have a tiny bit stretch, which I think can be fixed going to MPS4s |
04-13-2020, 06:06 AM | #9 | |
Rep 399
I don't think that I can fit 285 in my car Thanks |
04-21-2020, 12:19 AM | #13 | |
Rep 1,483
I'm running a 275/30 Firestone Firehawk Indy 500 on a 19x10 ET 38 with a 15m space. I rub the outside face of the tire under really hard compression (on track only) so going down to a 12 or 10mm spacer will possibly fix the outside rub on this tire but not sure if I'll rub on the inside. PS I have a set of H&R coilovers I used for about 10k km if interested.
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter |
04-22-2020, 12:58 PM | #15 |
Rep 2,704
AK click on any tire and hit specs on the next page.
Compare the section width and the measured rim width, it tells the story of the theoretical bulge in a particular tire. https://www.tirerack.com/tires/TireS...earDiameter=17
04-22-2020, 10:07 PM | #16 | |
Rep 399
04-24-2020, 05:05 AM | #17 | |
Rep 399
M359 wheels specs Front Wheels - 19x9" ET31 Rear Wheels - 19x10" ET25 |
07-04-2020, 12:14 PM | #19 |
Rep 57
Too hot outside today to do anything outside so I'm looking at what mods I want to do on my Z4MR and it seems that on both the exhaust and rim/tire threads, you have done exactly what I want to do. Where did you buy your rims or did they come with the car when you purchased it? Looks real nice btw.
07-05-2020, 06:58 AM | #20 | |
Rep 399
I purchased them from local guy, BMW OE M359s hard to get and they pricey so I would suggest you to go with avant garde rims |
