      09-13-2020, 08:54 AM   #1
jwatson
Drives: 2005 BMW Z4 2.5i
Lower Control Arms and creaky steering
Hello everyone.
So A few days ago I replaced my front lower control arms on my 2005 Z4. They both need replacing badly as the bushings on both arms were completely worn out. After replacing the control arms and bushings I went out and drove the car the next day. I noticed that every time I turned the wheel I was getting a creaky noise. It sounds like an old pirate ship. Ive researched this topic, but I'm not getting a clear answer to this problem. Would replacing the control arms and bushings have caused this? is there a simple fix?
      09-14-2020, 12:43 PM   #2
maupineda
Drives: E86 Z4MC
Did you use OE bushings?
      09-14-2020, 08:26 PM   #3
jwatson
I replaced the bushings and the control arms and yes they were all OEM
      09-15-2020, 03:11 AM   #4
polar
polar's Avatar
Sweden
53
Drives: Z4MC07
It could be the bearings on the top of the struts that are shot. (Not simple fix).
My Z4M started to sound like pirates (Arrrr ) turning at very low speed soon after I switched to Eibach springs. The pirates left the ship after upgrading to coilovers and camber plates.
perdidit in spatio
18" Arc-8 - Michelin Cup2 - KW V3 - GC camberplates - RE trans mounts - VT engine mounts - Vorshlag RTAB shims - RPi - stubby - CDV del
      09-16-2020, 07:58 PM   #5
jwatson
Hmm. Maybe I should make the switch as well. I havent touched the springs or struts at all.
