09-04-2020, 10:11 AM | #1 |
Rep 779
Kinda forgot what Diff oil I used.. GL4/5 compatibility ?
I changed it a few times with redline 75w90 but can't remember if its GL4 or GL5. I dont have the bottles any more. Seems all the oil comes up on search is GL5, GL5 safe for the diff ? Non M 07
-Roranji
09-05-2020, 09:43 AM | #2 |
Rep 18,729
It 75W-90 API GL-5. Castrol SAF-XO, which is NLA. The replacement from Castrol is SYNTRAX Long Life 75W-90 you can use either type for limited slip or non-limited slip. The diff takes over 1 quart so you need 2 quarts to fully fill it.
