09-02-2020, 10:03 AM | #23 |
Rep 3,005
I have Craftsman GDOs, essentially rebranded LiftMasters. I can use Siri to open and close the garage door either through the iPhone or Apple CarPlay.
My GDOs do not have MyQ built-in so I had to retrofit a solution. Be careful they offer various ways to retrofit and it's not always clear, why. I chose the 819LMB myQ Home Bridge vs. the G821LMB myQ Smart Garage Hub and the 828LM Internet Gateway. The latter two provide connectivity to the myQ app but do NOT support Apple HomeKit integration. G821LMB myQ Smart Garage Hub I didn't choose this option b/c it attaches to the garage door and it only supports two garage door sensors. I have three garage doors. https://www.liftmaster.com/smart-garage-hub/p/G821LMB 828LM Internet Gateway https://www.liftmaster.com/myqpck-sm...pener/p/MYQPCK This doesn't list all products, e.g. hub but does provide a nice overview. https://embed.widencdn.net/pdf/plus/...7.pdf?u=mcyivk I have this solution working for 1 door. To support the other two doors, I will need to add additional 889LM control panels. I used... 819LMB myQ Home Bridge This bridge is plugged into the ceiling and zip tied to the operator bracket... https://www.liftmaster.com/myq-home-bridge/p/G819LMB 889LM Control Panel in combination with this control panel which is hardwired to the operator and attached to the wall. I wish the control panel wasn't hardwired. The control panel does have a motion sensor that can be configured to turn on the operator light when you enter the garage. https://www.liftmaster.com/myq-control-panel/p/889LM The older 888 control panel had issues... Scroll down the 889LM page and you will see a link to request a replacement... https://cloud.info.liftmaster.com/88...845.1599058305 Last edited by omasou; 09-02-2020 at 12:29 PM.. |
Soul_Glo13346.00 |
09-02-2020, 10:15 AM | #24 | |
Rep 3,241
09-02-2020, 11:06 AM | #26 | |
Rep 3,005
I did "fix" it by reconfiguring the pieces and it's working fine again, while I wait fo r the 889LM replacements. |
09-02-2020, 11:07 AM | #27 |
Rep 3,241
That's surprising. Because the guy I had help was very good.
09-02-2020, 11:11 AM | #28 |
Rep 3,241
The "version 1" of the system has been in service since February of 2017. It was first used with my Genie opener in my primary home. I moved it when I got the "version 2" of the system in November of 2019. Version 1 is now installed in my vacation home mated to a Liftmaster opener. And of course version 2 is now mated to my Genie opener in my primary home.
09-02-2020, 11:25 AM | #29 | |
Rep 312
09-02-2020, 11:30 AM | #30 |
Rep 3,005
This thread reminded me to check on the status of my replacements 889LM control pads, which should be in stock in a few weeks.
So I asked the question. To which, I received the incorrect answer but upon clarifying the question again was told yes. The 819LMB myQ Home Bridge will support multiple 889LM (one for each door) control pads or newer operators. |
09-02-2020, 11:41 AM | #31 |
I'm Batman!
3948
Rep 1,477
This is the one I have, bought it mainly because I have it connected to my Google assistant, as I pull into my street I long press the mic button on the steering wheel, say "open garage" or whatever you set it to and it works, love it. You connect two cables to the back of the opener and plug it into a power outlet, run a sensor to the top of the door, easy
https://www.amazon.com/gp/product/B0...language=en_US
S55, 2JZ, M48.00 |
09-02-2020, 11:44 AM | #32 | |
Rep 3,241
The smaller box is the door sensor. This is velcro'd to the garage door to tell the base station if the door is up or down. This is battery powered with a Lithium cell. I've only had to replace the battery in this sensor in the version 1 unit once since owning it. I did get a low battery warning on the version 2 system for the door sensor. I got a replacement battery but checked the old one first which turned out to still be good. I replaced the old battery and haven't had any warnings since. All the other components you and omasou have discussed, I'm not using. I haven't looked into those components but what the basic setup has is enough to satisfy my needs for now. |
QM287.00 |
09-02-2020, 11:49 AM | #33 | |
Rep 3,005
The 889LM control panel connects to the operator using normal bell wire to get power. I still need to trench the wire into the drywall. Liftmaster 889LM Instructions Last edited by omasou; 09-02-2020 at 01:46 PM.. |
QM287.00 |
09-02-2020, 05:54 PM | #34 |
F15 daddymobile
2350
Rep 3,510
This seems a little gimmicky to me. 80/20 rule here, I don't see how I'd benefit from this? Why do I need to control my garage door from my phone?
09-02-2020, 06:00 PM | #35 |
Rep 3,241
It provides piece of mind. There are times I'm in such a hurry I forget to shut the garage door. The system provides me with a real time update as to if the door is up or down. In the past, I would be able to see if my garage door was up or down as I have a security camera in the garage of my primary home. But even if I saw the door open, I couldn't do anything about it till I got home. Now I can.
Second advantage is that I can open the door remotely for neighbor of friends to get into my garage. I've done this a couple of times. Third, it's another backup to get the garage door open. I don't carry my house keys with me much for my primary home. |
09-03-2020, 08:12 AM | #37 |
Rep 3,241
There is no subscription fee for just the base function which is monitoring the status of the garage door and remotely opening and closing. I seem to recall if you leverage integration with other Smart home type systems then there is a subscription.
I also remembered another feature that is present in the version 2 unit which is scheduled closing of the garage door. Nice feature when you forget to close the garage door when you're home. I've done this too where I've been working in the garage and forgot to close it when turning in for the night. Been a number of occasions where I wake up in the morning and realize the door was left open all night. Some of my neighbors have done this too. |
M_Chronos112.00 |
09-03-2020, 08:20 AM | #38 | |
"Salud"
13834
Rep 4,669
Drives: F01 & F15 / Mineral White
I like to leave my door cracked because of the extreme heat build up. I sometimes forget to close it before bed. I have tons of valuables in there. |
09-03-2020, 11:48 PM | #39 | |
Rep 3,005
The reasons I like it are... 1) I can use my phone to double check that my garage door is closed and doors are locked. Similar to BMW Connected Drive to know my car windows are closed and the doors are locked when it starts raining. 2) I can or my children can open the garage door and enter the house without keys. Yes, we need to have our phones but we always do. Now of course if that still seems silly then home automation isn't something you will find value in. |
09-04-2020, 10:30 AM | #40 |
"Salud"
13834
Rep 4,669
Made my decision.
As always, I appreciate everyone's input and opinions. That's Wray these online forums should be about: Either helpful tips abd recommendations or fun. After a few days of research and MANY reviews and what will fit my particular need, I went with the Tailwind iQ3. Once I receive and install it and use it a few times, I will update. |
09-04-2020, 12:14 PM | #41 |
Rep 1,031
Drives: Like a bat out of hell.
You can use MyQ opener or buy an add-on module that works with most modern door openers. For voice and remote activation/monitoring, you can use Apple Homekit, Google Home and Alexa should also work.
I use Apple Homekit myself. I can open and close my garage with my Apple Watch, iPhone, iPad and Macbook, iMac and Apple TV remote. Apple Homepod will only close and lock doors but won't unlock for obvious reason so intruders can't summon SIRI and open doors. |
09-04-2020, 12:20 PM | #42 |
Rep 1,031
09-04-2020, 02:13 PM | #43 |
Rep 1,079
I had a couple coupons a year or so ago to Lowes and I got a myQ set for my garage. Do I need it? Probably not.. have I actually used it in a year or so? Twice. So for those two times that A) the wife left the house and didn't close the garage door.. and B) I told the kids to close the door and they ended up opening the other door late at night. Not only saving me a potential loss if someone stole something from my garage.. I'm certain that overnight I would get all sorts of animals heading into the garage to find whatever food was possible (I do have stored food and fridge in my garage too.. which a year ago two mice managed to chew through the garage door plastic seal and hide away in the winter. The mice managed to go everywhere including the engine bay of the cars).
There's a setting that it will not only send a push notification, but an email to you if the door is left open too long (in my case I have it for 30 minutes) I'm either outside working so I know it is.. or I didn't realize it was open. I do also have cameras, but as stated before, you know it's open but you can't do a thing about it. |
09-04-2020, 03:10 PM | #44 |
Rep 1,031
I would also recommend adding a camera to confirm the status of your garage door so that you're not just relying on the door sensor alone.
