Go Back   ZPOST > Marketplace > Sponsors Classifieds
      10-12-2012, 02:45 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
818
Drives: Independent Tuning Specialists
:: ECS Tuning :: JOM Invisible Valve Stems
Now you see them; now you don't. Ditch your unsightly stock valve stems, and install flush mount Invisible Valve Stems from JOM. Each kit comes with a complete set of short valve stems with removable caps, plus a special inflation tool for adding air. The stems have threaded necks and collar nuts to secure them in the wheel stem hole for a positive, leak-free fitting. Function aside, the flush mount stems come in aluminum or black oxide to fit a wide range of wheels for a look that gets you noticed.
Click HERE to order today!!!!!!!
      11-07-2012, 11:31 AM   #2
ECSTuning
ECSTuning's Avatar
818
Sometimes it's about what you don't see
      12-12-2012, 09:43 AM   #3
ECSTuning
ECSTuning's Avatar
818
There is no better time to buy than NOW!!!!!!!!!!!!!!!!!!!!!!!!
10% OFF as part of our 8th Annual Holiday Extravaganza!!!!!!!!
