Go Back   ZPOST > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Video + PC Gaming / Computing
      02-16-2022, 07:41 AM   #1
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
Drives: 2021 BMW M340i
Outdoor Speaker System Help
Good morning All,
I am looking at installing two speakers outside underneath our covered area on our back deck. We entertain alot and would like something better than just a JBL portable speaker that we use for when we have people over.
A few things I am looking at is:
Amp: Sonos (able to stream a variety of music services via bluetooth)
https://www.sonos.com/en-us/shop/amp
Speakers: (2) Bose outdoor speakers.
https://www.bose.com/en_us/products/...ml#v=251_black
I'm not looking to break the bank with this. I will be doing all of the labor. Any other suggestions for amp and outdoor speakers would be great.
The amp will be installed in my basement on the wall right next to the covered part of the deck. I do not see any issues with being able to stream music and the ability to change songs...etc.
Thoughts on the type of speaker cabling? I will be running conduit.
Thank you,
Jeff
Present: 2021 BMW M340i Mineral White
Past: 2018 BMW X5 Mineral White, 2018 BMW 340i Alpine White, 2016 BMW F15 X5 xDrive / Glacier Silver, 2011 BMW 335xi / Alpine White, 2008 BMW 135i Sedona Red
      02-16-2022, 09:36 AM   #2
Murf993
Murf993's Avatar
14116
Drives: Porsche 993
I have 3 sets of Sonos 1 speakers outside and have been running this set up for over 5 years. I have them tucked up under the eaves. I decided to to go this route using the Sonos 1 as they say they can be used in a humid environment like a bathroom. I live in Canada and get temp extremes between -30C and +30C with high humidity in the summer. They have worked flawlessly and despite some dust and cob webs they look like new.
We have 1.5 acre waterfront property, the speakers are on the back of the house facing the lake. the house is set back from the waters edge about 95'. When I have the speakers at moderate 3/4 volume I can easily hear them at the waters edge while sitting on our dock. Last winter we were out on the ice about 100' from shore, I had them cranked pretty loud and could hear them out there.
Sonos sound great and work well in this application, also no need for an amp as they are built into the speakers. You need 120V outlet for them but if you have to run speaker wires you can run discrete extension cords and they work great.
      02-16-2022, 09:48 AM   #3
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
Thanks for the reply and info.
I will look into those Sono's speakers.
Also, how is the range of the amp? Are you able to control music without any issues?
      02-16-2022, 10:12 AM   #4
ZL9M2
Drives: '17 M2 ZL9-'20 M2CS-'68 1600
I've run Sonos for a long time and love it. What I don't love is that my hardware is so old that its not supported anymore, but I'll live with that. My setup is somewhat unique however, in that my house was originally wired for central sound. So I have all the Sonos units on one shelf in my living room along with a multi channel amp. The Sonos units are not distributed throughout the house. I then have 6 different "zones" including the garage/shop and outside.
I believe your question on wire gauge to run form the Amp to the speakers would depend on the length of the run.
      02-16-2022, 10:18 AM   #5
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
Thanks for the info.
Wire run would be 50ft to one speaker then about 65-75ft to the other speaker.
      02-18-2022, 11:15 AM   #6
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
Anyother suggestions?
I know the Sonos is pretty pricey, if I can get something that does the samething for 1/2 the price, then I would for sure. I know alot of the receivers are going bluetooth now when it comes to streaming music. Just want to make sure I am able to do that when there is a concrete wall in the way. So I will be about 10-20ft from it at any given time.
      02-18-2022, 12:56 PM   #7
Murf993
Murf993's Avatar
14116
Drives: Porsche 993
I'm not sure what you mean, they work on wifi, which in my house is pretty decent so I get pretty good range through exterior walls etc. My biggest problem is using my phone to control them has somewhat limited range when I"m outside to hit the router. But my iPad works great range wise.
      02-28-2022, 12:40 PM   #8
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
Went with a Sony Bluetooth Receiver and Bose 251 Outdoor speakers. Everything has been delivered except for the Bose speakers, those should be here within the next hr or two. Cant wait!
      02-28-2022, 12:54 PM   #9
rwheels
Drives: E93 M3
Was looking for your post in the Are you waiting on something? thread; didn't see it. Guess you received them already.
      03-01-2022, 09:59 AM   #10
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
I have a quick question for you guys that know about receivers and stuff.
I bought this receiver for my Bose 251 outdoor speakers.
https://www.bestbuy.com/site/sony-2-...?skuId=6187501
My questions is, I will be installing 4 outdoor speakers to the receiver above..will that be enough power? 2 Bose 251 outdoor speaker and 2 Rock shaped outdoor speakers.
Or do I need to upgrade the receiver that has more power to handle 4 speakers as opposed to 2? I want the sound to be strong and clear. I dont want any issues.
      03-01-2022, 10:43 AM   #11
Custom Install
Custom Install's Avatar
Drives: G82 M4 Comp X-Drive Individual
2022 G82 XC   [10.00]
This amp should be fine. It has speakers A/B so you can connect 2 pairs easily.
E30 325i Sport: E36 318is: E36 328i Sport:
E46 330Ci Sport: E86 Z4 3.0i
F82 M4: F82 M4 Comp Individual LCI
G82 M4 Comp X-Drive Individual FDG
      03-01-2022, 10:51 AM   #12
rwheels
Drives: E93 M3
But the issue becomes if he can play both A and B at the same time. I don't think that is possible on most amplifiers.
      03-01-2022, 10:51 AM   #13
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
Thank you Custom Install
So you think it will be enough power to run the 2 bose speakers and the 2 rock speakers? I think the Bose in itself take 100 each to perform.
      03-01-2022, 10:55 AM   #14
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
I was just thinking that when I read his comment.
This is the other receiver I am looking at. Just $150 more.
https://www.bestbuy.com/site/sony-72...?skuId=6187502
      03-01-2022, 11:22 AM   #15
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
I just verified..you can play both A and B speakers at the same time.
      03-01-2022, 11:55 AM   #16
rwheels
Drives: E93 M3
This could be another option, or something similar. All bluetooth without the need for wires.
https://www.amazon.com/Channel-Wirel...157075&sr=8-20
      03-01-2022, 11:58 AM   #17
MoeTE87
OHIO STATE
MoeTE87's Avatar
657
Thanks for that. I was reading some of the reviews on that Pyle company and heard they are a nightmare to deal with.
