05-18-2016, 08:10 AM | #1 |
Rep 53
Alex's Z4 to Z4M Rear End Conversion
Hello all! Just completed my rear end conversion..including exhaust..
enjoy! so naked.. Z4M bumper came and finished painting. Test fitted Another test fit with the taillights. At this time I was debating if I should use these tails or not, but the gap between the taillight and bumper was too big for me Z4M X Pipe + S Pipe came! saved alot on ebay.. Taillights came and finally covered the gaping battery hole. Put it all together Now time for the shop. Out with the old... In with the new... Welded tips and VOILA Still some small bits I need to get such as battery box and heat shield for the right side. |
05-18-2016, 08:48 AM | #2 |
Rep 11,669
Nicely done.
I like what you did with the exhaust Xpipe & moving the battery box
05-18-2016, 12:57 PM | #4 |
Rep 12,570
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.09] |
How loud is if without mufflers?
05-18-2016, 02:46 PM | #5 |
#buildnotbought
11033
Rep 4,920
Was it difficult to reroute the battery wiring? or are all cables long enough for the z4m location of the battery?
And the amplifier wiring (I see you have the dsp amp). Are you relocating that to the z4m battery harnass as well? I also see you have the digital interlink in your amp. Do you have hifi DSP with navigation (large screen) or without? And your evap charcoal container. Did you relocate that also or not? Do you have more pictures?
05-18-2016, 03:43 PM | #6 |
Rep 53
05-18-2016, 03:46 PM | #7 | |
Rep 53
Evap charcoal filter was removed. I'll provide more pics once I clean it up a bit. |
05-18-2016, 04:29 PM | #9 |
#buildnotbought
11033
Rep 4,920
But actually that is very interesting. A lot of hifi DSP systems dont have a digital link between the cd changer and the amp. They use an analog connector. I think those are all systems with navigation, and the ones without navi have a digital link between changer and amp.
I dont know what's better, as I think the DSP function (graphic eq and room/echo) is done totally analog. There isn't much digital processing power in the amp, and digitally controlled analog graphic eq chips are simple and abundant. Maybe it has something to do with that navigation has to do voice directions while music is playing or so and that goes through the headunit.
05-25-2016, 05:30 AM | #10 | |
Rep 53
Set of 2 Exhaust Dual Slant Polished Tip Staggered Stainless 2.5"In 3.5"Out Left Right https://www.amazon.com/dp/B00W572U0Y..._R6xrxbWMJBWA0 |
06-13-2019, 09:17 AM | #11 |
Rep 1
Can you tell me if you did any work with the Tailights harness wise to get them to work as I see you had the older tailights. From what I understand their is some re-pinning that needs to be done and we are now using a 12V lead from the license plate lamp to power the new tailights. Can you send a picture of your harness if repinned to Alex13j1993@gmail.com. Trying to get this done this week if possible.
06-11-2022, 09:01 PM | #12 |
Rep 1
Did you still have the write up for this? I would like to get this done
Hello. I can't see the pictures you posted but I imagine it came out great. I was wondering if you still had the write up and picture for this conversion? I'm on a quest to install dual exhaust with quad tips.
