Go Back   ZPOST > BIMMERPOST Universal Forums > Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs)
      04-18-2026, 08:18 AM   #1
93civEJ1
Drives: 24 m440i GC X, 07 335i(gone)
new to me m440i, want to make it best it can be
So i picked up a 2024 m440i with 44k on it. It looks great, but it has the spider web looking swirls in the clear, not bad, but they are there. The front has a bit of road debris thats nicked the paint. Its not so bad that its obvious unless you get down and inspect. The hood has a couple tiny dots that have been hit with touch up but not great, as you can tell it.
I know its really too late for ppf unless you go and get all that fixed, but i prefer to spend money on performance mods, so expensive paint repairs are prob not gonna happen.
I thought about doing ppf but read that it all needs to be repaired and painted first.
How many of you are not running any sort of PPF? How does your vehicle look? Any tips or tricks to keep it looking good for those who go non ppf.
Also, for light clear coat spider web rings, what would be the best process for that? Otherwise the paint looks great really.
Oh, and some parts of the car have like tiny copperish colored parts kind of stuck in the clear. I tried clay, and it would get some but it would take a lot of work. Is there a product that gets rid of all of that?
      04-18-2026, 09:46 PM   #2
TimmyTurbos
Drives: 2017 M3 Comp
Take the car to a detailer for a proper paint correction. It's going to be much easier to maintain everything with a professional start. They will buff and polish everything they can out for you. After this step is where you want to pull the trigger on PPF since the prep is done. PPF is the only way to protect against road debris. You can do what's called a "highway" package if you don't want to go full car.
Also DO NOT take the car through one of the drive-through washes. Washing and wiping the car incorrectly is what has caused the "spider web" swirls in the 1st place..GL
CJ4212565.50
FrankL228.00
      04-18-2026, 10:55 PM   #3
fiveightandten
fiveightandten's Avatar
225
Drives: F22 M235, E36 M3, E30, X3 M40i
What color is the car?
You can put PPF on a car with some rock chips and imperfections. It will guard against additional imperfections. Though if there's notable paint damage (read: more than some small rock chips), then the compromised paint could potentially be pulled off down the line when you need to remove the PPF. If the paint is factory and generally in good shape, you won't have to worry about that.
The touched up areas can be wet sanded to take down the touch up paint and blend it with the surrounding material so it's much less noticeable.
Cars arguably look best without PPF. People use PPF because it protects the paint from damage, not because it looks better than uncovered paint. The biggest thing is rock chips and damage from snow removal (if you live in the snow belt). But if you are serious about keeping the paint nice, you can keep damage at bay from most other things.
Good washing and drying habits are a must.
  • Wash the car regularly.
  • Always rinse down before doing a contact wash. A pressure washer at ~1,000 PSI with a 40º nozzle is good, but a hose works ok as well.
  • Use a liberal amount of quality soap with a plush microfiber towel or mitt.
  • Change the microfiber often, or rinse the mitt often. I like to use the pressure washer or hose to aggressively rinse off the towel/mitt after each panel. Start at the top of the car and make your way down. Use a separate towel or mitt for the lower parts of the car and don't let it touch the upper parts.
  • When drying, use a drying aid or drying lubricant. Using a leaf blower for no-contact drying is a good habit as well.
  • When washing use the 2 bucket method and grit guards. Or change microfibers often and wash them after each car wash.
Those are the basics, but there are plenty of YouTube videos and other resources that cover good washing methods. Never ever take the car to a brushed carwash. Don't let a dealer or oil change place do a "courtesy wash" for you. Don't go to a car wash where they hand dry the car as you leave. Don't let people lean up against the car. For some reason people love to lean up against cars, with the rivets on their jeans gouging the paint. And if possible, remind people not to beat their shoes up against the side skirts in an attempt to remove dirt from them before entering the car. The floor mats can be vacuumed. For some reason, some people are in the habit of beating their shoes into the side skirts like this.
It sounds like it could benefit from a full paint correction. Understand that buffing and polishing a car is permanently removing clear coat. There is a finite amount of clear coat on the car. So you generally want to take care of it to avoid the need for future paint correction.
Generally for a full correction you'd decon the paint (chemical decon / iron remover, clay bar), then compound it to remove the imperfections, then polish it to make it glossy and remove any artifacts that the compound leaves behind. Then apply protection to keep the paint looking good (panel wipe or alcohol mix wipe down after polishing to remove polishing oils).
That's probably iron. This is common to see behind the wheels and on the rear of the car, as metal particles from the brakes get shed and the hot particulate embeds itself in the paint. It's most visible on white cars. An Iron remover should take it off. If you live near a railroad or industrial area, airborne metals can be higher than in other places.
Iron removers generally turn color when they contact iron particles, and you'll see a purple or brown bleed coming from the iron particles. It's possible it's another type of contamination. But generally you see the following:
  • Iron (use an iron remover, which smells horrible but is generally pH neutral)
  • Tar, road film (oily residue from rain water flinging oil up from the road), bugs; use a high pH (alkaline) decon soap
  • Water spots, mineral contamination from rain water or hard water used during washes: use a low pH (acidic) decon soap.
When using high or low pH products, always rinse very well, and ideally follow up with a pH neutral soap to neutralize the harsh stuff.
      04-19-2026, 03:31 PM   #4
93civEJ1
Thanks for the couple of responses. I usually do stuff on my own. Its been a good bit of years since I took the rotary or orbital to anything, but im thinking about it.
I have a brooklyn gray metallic vehicle. It looks good minus the swirls which i think is due to previous owner or dealers using car wash. I noticed it the night of picking up the car. Cant see it unless sun hits the right way.
Since I have had it, i hose off the car. Then i presoak it with a ONR / Water mix from a pressurized spray bottle. After that I use a sponge i got for no rinse washing, and two big microfiber towels. For when I wipe and then dry, I do a panel at a time.
Id just like to get the chips touched up the best they can on my own, and then get the car ready by removing the contaminants and swirls, and then coating with some sort of ceramic.
      04-19-2026, 07:16 PM   #5
fiveightandten
225
Nice. Brooklyn Gray isn't a tough color. It's much more forgiving than black or other dark colors. If you've had experience with paint correction you could definitely do it yourself. IME, the clear on modern BMWs is pretty forgiving and hard enough that it's difficult to do damage or go too far. I actually bought a forced rotation machine to do my X3 as my regular DA was a bit slow at getting work done.
There are a lot of different touch up methods. But generally the idea is to fill the chip with the touchup paint standing at the same level as the surrounding paint. You could fill a chip so the touchup is below the level of the surrounding paint and make it much less noticeable (and more importantly, protected). But whenever it bubbles up too high, it's very noticeable and doesn't look good. Professionals will often build the paint up a bit too high, then knock it down either with polishing, or in some cases wet sanding first to blend it in.
I've had success with using rubbing alcohol to knock the fill down before it's fully cured. For that, I fill above the surrounding paint, wait 5 minutes or so, then rub the fill with a microfiber that's wet with iso. This isn't as good as a pro-level fix, but makes for a pretty good looking repair with very little work. It's fine for my Alpine White DD, where this stuff isn't very visible. But for a black weekend car, for instance, I'd do better.
Presoaking then rinsing before contact wash is a good habit. Depending on what your sponge is made of, a microfiber wash mitt or microfiber towels are likely safer for the paint. They're made to pick up particulate and suspend it in the fibers so it's not getting dragging around on the paint. A traditional sponge keeps that same particulate on its surface and therefore carries a higher chance of micromarring.
      04-21-2026, 12:42 AM   #6
N1rve
Racecar Driver
N1rve's Avatar
No_Country
2258
Drives: BMW M4
2019 BMW M4  [9.70]
I have full car PPF and I will tell you that anything that has nicked your paint -- will also nick the PPF bunch it up and leave a dot/cut into it lol. The only thing PPF really does well against is pitting and against swirl marks. PPF is also good at hiding swirl marks though.
Those copperish thing might be iron so you might want to use something like Carpro Iron X or Adam Polish Iron remover.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
      04-21-2026, 11:52 AM   #7
93civEJ1
Thanks for the info yall.
      04-21-2026, 01:45 PM   #8
TimmyTurbos
It will take and show the road debri dings, bird sh*t etchings, etc. etc. - all while protecting the paint under it. Its sacrificial. This means it's working as designed.
      04-22-2026, 05:32 PM   #9
louielouie
Drives: '18 F80
When I picked up my F80 used, it already had ~15 rock chips on the front. Looking into PPF, most shops are looking for $2K+ on a full front. I live near a freeway that has a lot of construction trucks so after a year of commuting, my front bumper was destroyed despite always leaving long gaps in front of me.
If I wanted to PPF, I'd have to get a respray first. When I looked into resprays, front bumper (only section that needed it) was $800. Decided to just skip PPF as I can respray it again later for perfect paint if needed and it'd still be cheaper than a PPF job. I used to be a little more knit picky with every little imperfection but while I still keep it pretty clean, I find it less stressful lately to just take it out and enjoy it.
      04-23-2026, 10:56 AM   #10
Late_Apex
Late_Apex's Avatar
18
Drives: 2025 BMW M340
Based on what you described, ceramic coating may be the best middle-ground option for your goals. If you’d rather put money into performance mods than full paint correction and PPF, a reputable detail shop could do a light polish to reduce the spider web swirls first, then apply a quality ceramic coating.
It won’t prevent rock chips the way PPF does, but it will improve gloss, make washing easier, and help keep the paint looking better with less effort.
The copper-colored specs also sound like iron contamination, so I’d use an iron remover/decontamination treatment before any coating.
If you go this route, avoiding automatic car washes will make the biggest long-term difference.
