Login
11-07-2017, 02:15 PM | #1 |
![]() 1033
Rep 4,248
► Built-To-Order Suspension Kits Available at APEX Race Parts (JRZ, Hyperco, GC)
![]() Built-To-Order Suspension Kits Available at APEX We know there's no one-size-fits-all for coilover kits. We also know that there's a difference between simply lowering your car, and actually improving its performance in a meaningful way. It is crucial that any coilover kit is built around a quality damper, which is why all of our kits are built around the JRZ RS Line. However, we all use our cars differently, so we offer the ability to customize a coilover kit using race-proven components to meet your specific goals and budget. Best of all, you can get it all from one place. Why buy from APEX? It's simple. We use better springs and camber plates, we custom-build kits to your specs, and best of all, everything is in stock and ready to ship from our Livermore, CA warehouse. Not to mention, we've priced our complete JRZ coilover kits below others that are selling them with lesser quality components. JRZ Suspension Engineering calls on over 60 years of experience in development and production of motorsport dampers. With numerous factors like track surfaces, weather conditions and tire compounds, the adjustability of JRZ dampers ensures you can utilize your car's full potential at all extreme ends of the spectrum. Ground Control has been building world-class street, track, and full road race suspension setups since the 1980s. They have designed and built setups for hundreds of different chassis and applications. From no-compromise racing camber plates to refined, comfortable street plates, Ground Control's engineering and attention to detail makes them our camber plate of choice for any street or race application. We chose Hyperco springs mainly because of their near-perfect (within 2-4%) linear rates. They're more resistant to bowing than most other brands of spring, and because of their highly developed design, the springs are able to maintain their original free length and rate throughout a near-infinite operational life. Visit our website to order Selecting The Right Suspension Kit All of our complete coilover kits include the following: 4x JRZ Dampers 2x Ground Control Front Camber/Caster Plates 4x Hyperco 2.25" ID Coilover Springs 2x JRZ Rear Ride Height Adjusters 4x JRZ Soft Bump Stops Optional Extras that can be added to your kit: 2x or 4x Hyperco 2.25" ID Helper Springs with Helper Spring Guides 2x Ground Control Rear Articulating Weight Jacks (replaces rear height adjusters) 2x Ground Control Rear Shock Mounts ![]() 1. JRZ RS ONE Single Adjustable Coilover Kit - Complete F30 kits starting $3,568.96 Single-adjustable dampers Preset compression setting Adjustable rebound settings (24 clicks) Ideal for the driver who wants a professional, adjustable, motorsport-proven damper without the higher price points of the RS TWO and RS PRO dampers. 2. JRZ RS TWO Double Adjustable Coilover Kit - Complete F30 kits starting $4,218.96 Double-adjustable dampers Adjustable compression settings (14 clicks) Adjustable rebound settings (24 clicks) Ideal for the semi-pro driver who wants to become more familiar with suspension tuning using a quality damper. 3. JRZ RS PRO Double Adjustable Coilover Kit - Complete F30 kits starting $5,143.96 Double-adjustable dampers with external reservoirs Adjustable compression settings (14 clicks) Adjustable rebound settings (24 clicks) Adjustable nitrogen gas pressure Quick-disconnect reservoir plumbing for front dampers (rear optional) Ideal for the pro racer who requires the precise adjustability that only external reservoirs can offer. Find Your Suspension Kit Suspension Kits Available For:
Questions about camber plates, suspension and wheel fitment? Click here to get a personalized fitment recommendation from one of our experts. Ordering and Contact Information
![]() Wheels /// Tires /// Suspension Kits /// Accessories /// Group Buys /// Vehicle-Specific Fitment Guides Last edited by Expert@ApexRaceParts; 07-02-2019 at 04:34 PM.. |
11-21-2017, 04:48 PM | #3 |
![]() 1033
Rep 4,248
Thank you for your post! They certainly are, and the build quality compared to many other options out there is extremely apparent when you're holding them in your hands.
![]() Wheels /// Tires /// Suspension Kits /// Accessories /// Group Buys /// Vehicle-Specific Fitment Guides |
12-22-2017, 05:38 PM | #4 |
![]() 1033
Rep 4,248
JRZ, Hyperco, and Ground Control - the coilover dream team.
01-12-2018, 04:27 PM | #5 |
![]() 788
Rep 2,303
We've done our homework and have selected only the highest-quality components to use in the suspension kits we offer. Best of all, we stock these parts in our own warehouse, so there is no need to order everything from a different supplier.
Choose your dampers. Choose your camber plates. Choose your spring rates. Give us a call or PM with any questions, we're happy to work with you to build the ideal setup for your application. ![]()
04-26-2018, 05:06 PM | #6 |
![]() 1033
Rep 4,248
Learn more about the JRZ RS-ONE damper in our blog article.
06-21-2018, 01:28 PM | #7 |
![]() 1033
Rep 4,248
Learn more about the JRZ RS-TWO damper in our blog article.
07-25-2018, 07:00 PM | #9 | |
![]() 1033
Rep 4,248
Feel free to PM us for details on the perfect setup for your car! - Max
11-27-2018, 12:36 PM | #10 |
![]() 1033
Rep 4,248
Here are a couple photos of the kits that were produced specifically for us in our last group buy:
01-04-2019, 10:26 AM | #11 |
![]() 47
Rep 197
Since there is another group buy on these available, I am considering the JRZ RS TWO and have a couple questions:
1. On the deal configuration, it lists a race camber plate option for Z4s and not Z4Ms. Is there a race camber plate offered for the Z4M in this deal? 2. The setup I am considering would include race plates and Level 1 spring rates since my vehicle is used daily and for autocross, as well as an occasional HPDE. How frequent would the dampers need to be rebuilt? (6,000ish street miles per year, ~ 15 autocrosses, and 4 HPDEs)
![]() 2006 Z4M - Epic Tune / Turner Pulleys / Eventuri / Euro Headers / Section 1 / Custom Stromungs / FA 500 + Camber Bolts / VT Engine Mounts / RE Trans Mounts / AS SSK / Arc 8s 2004 Z4 3.0i - Koni Yellows / Style 224s / AFE / Stromung Exhaust / Z4M Engine Mounts / M3 Trans Mounts / Beisan VANOS / GAS DISA |
01-04-2019, 04:38 PM | #12 | |
![]() 1033
Rep 4,248
In regards to the race camber plates, you will need to select the "Z4 Race Plates" option in the configurator. The race camber plate design for the Z4M and Non-M does not differ which is why there is only one single Race plate option for the Z4 chassis. The level 1 setup is ideal for a dual duty car that is not running any aero or slick tires. JRZ recommends a rebuild interval of 24,000km (roughly 15,000 miles) to "maintain peak performance for racing applications". We see no issue stretching a rebuild to over this 15k interval. With your current projections of how often you drive your Z4, you would easily be able to get 3 years (!) of use out of the dampers before we would recommend rebuilding them. - Max
jns_e8547.00 |
05-07-2019, 06:13 PM | #13 |
![]() 1033
Rep 4,248
![]() We have many full coilover kits with Ground Control camber plates and Hyperco springs in stock and ready to ship today. You already have an incredibly balanced chassis, watch it come to life with an adjustable suspension that can keep up. Your favorite tracks as well as the roads you drive every day will be much more enjoyable. Get yours fast as we are the largest stocking distributor of BMW-specific JRZ suspensions in the United States.
05-21-2019, 03:52 PM | #14 |
![]() 1033
Rep 4,248
Distinct "clicks" and easy-to-reach adjustments are just another reason why we're so excited to offer JRZ dampers in our coilover kits.
06-25-2019, 04:30 PM | #15 |
![]() 1033
Rep 4,248
12-05-2019, 06:46 PM | #16 |
![]() 1033
Rep 4,248
It's all in the details. Our helper spring adapters are designed to minimize stack height at all costs. Using a recessed mounting pad adds less than 1/4" to the overall height of the setup, while precisely matching the diameters of both springs and not allowing any play.
