Login
11-10-2018, 11:46 AM | #89 |
![]() ![]() 18
Rep 31
Expert@ApexRaceParts
Loving the looks of the ARC-8’s! Picking up a Z4MC next week. Based upon reading through hours of fitment threads, it appears the following “should” work without rubbing... 18x9 ET30 with Hankook V12 245/35 18x10 ET25 with Hankook V12 275/35 Two things I’d like to verify if possible, though: 1) are camber plates necessary for a proper alignment on stock suspension? 2) will lowering on H&R springs potentially change the answer to #1? Thanks in advance. |
11-12-2018, 12:42 PM | #90 | |
![]() 1033
Rep 4,248
The 18x9 ET30 and 18x10 ET25 setup is a very popular one, and will fit without much drama in the following configuration: Front: 18x9" ET30 with 235/40-18 tires Rear: 18x10" ET25 with 275/35-18 tires
In regards to your questions: We would recommend opting for a camber plate if you intend on lowering the car at all over stock. At stock height, there will be moderate camber required (less than -1.8˚). If you intend on fitting those H&R springs then you would need to run around -1.8˚ to -2˚ in front depending on how low you end up. I hope this was helpful information, post up some pics of your car when you take delivery as well. I'm excited for you! ![]() - Max
![]() Wheels /// Tires /// Suspension Kits /// Accessories /// Group Buys /// Vehicle-Specific Fitment Guides |
primm90718.00 |
11-14-2018, 01:43 PM | #91 |
![]() 1033
Rep 4,248
Satin Black ARC-8s on this Z4M Roadster:
![]() We have many sizes finishes of the ARC-8's in Z fitment in stock right now.
11-21-2018, 03:48 PM | #92 | ||
![]() ![]() 18
Rep 31
I pulled the trigger on a set of Arc8's, but ended up doing 19's in anthracite. Can't wait, so hurry that order along please!!
VW GTI - Daily
BMW Z4M - Fun BMW X3 - Wife BMW X1 - Kid1 VW Tiguan - Kid2 |
11-28-2018, 06:58 PM | #93 |
![]() 1033
Rep 4,248
12-08-2018, 10:01 AM | #94 |
![]() ![]() 18
Rep 31
Finally got my anthracite 19's on yesterday. Now to address the ride height...
VW GTI - Daily
01-14-2019, 06:38 PM | #95 | |
![]() 1033
Rep 4,248
12-02-2019, 07:23 PM | #97 |
![]() 1033
Rep 4,248
![]() Check out Josh's 2006 BMW Z4 M Coupe on 18" ARC-8 wheels! Here is his setup: Front: 18×8.5 ET38 ARC-8 in hyper black 15mm spacer 225/45 Bridgsetone Potenza s-04 pole positions Rear: 18×10 ET25 ARC-8 in hyper black 255/40 Bridgsetone Potenza s-04 pole positions
