      08-05-2020, 05:03 PM   #1
creativeliberty1776
Drives: 2003 bmw z4 3.0 6 speed
2003 BMW Z4  [0.00]
brake booster line collasped
So today I found out that my lower intake boot was cracked in the flexible tab going up and ordered a new oem one that should be here in a week. Although I notice brake booster vacuum line that connects into that octopus looking mess there was nearly collapsed, Like sucking on a straw with your finger on the bottom. obviously I have to replace this, my question though is, is this normally the way they fail? Is this indicative of another underline issue? Does anyone make a rigid version of this line?
https://photos.app.goo.gl/dG3Sc9zCyTYjANrU7
https://photos.app.goo.gl/46vxprYxvJzdiE1T6
Thanks,
      08-05-2020, 08:14 PM   #2
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
Underlying issue? I think not. Rubber has perished from age/heat/cool cycles.
      08-05-2020, 09:58 PM   #3
creativeliberty1776
2003 BMW Z4  [0.00]
So you think I'm good replacing with the stock OEM boost line, and I don't need to worry about the stuff it's connected to being stuck closed or anything think else weird like that up stream? When I disconnected the fire wall end it made a hissing sounds an was defiantly under a vacuum with the engine off.
Car has a 130 k... bought as a $1,500 basket case and have replaced everything I could on the bottom end, to include but not limited too,oil pan gasket, oil filter, oil level sensor, oil pressure sensor, rotors, brakes, clutch, front wheel hubs, fuel filter (In tank "PITA" ) Shocks, struts, rtabs, other misc bushing (each requiring their own special tool) 10 piece front lower control kits, both cup holders bumper cover and both fenders, 3rd tail light , and a titanium solid gear shift, because yeah it's a stick I just now replaced the the intake boot which smoothed out the idle, which I ordered on eBay this morning only to find a brand new one in the misc parts box left in the trunk by the previous owners good intentions....God provides next is replacing the valve cover gasket,(which is getting out of my comfort zone) due to a small leak on the back rear cover right above the o2 sensors and exhaust pipe which are currently clean and would like to remain that way.
https://photos.app.goo.gl/3s3vYLA5JYBha9e56
I'm now chasing a laundry list of codes down and working on the vacuum related ones at the moment. I should probable due plug check when replacing valve cover gasket .
some pics of work to date.
as received
https://photos.app.goo.gl/xkXjK4zHYtWcHAra9
tear down begins
https://photos.app.goo.gl/MuuarViykH4s2B739
Clean up and tires stripped.
https://photos.app.goo.gl/UBQZtVfiCQ7k2E5y8
home made engine brace (truck ladder rack and 2x4s
https://photos.app.goo.gl/7NNtrP6aGG6rCs5N6
cleaning
https://photos.app.goo.gl/5A1mbJCFwbrKd7Pa9
Tires painted
https://photos.app.goo.gl/C4D49uQFLJyHNFbY6
Neat pic, multiple things in progress
https://photos.app.goo.gl/rwvt1w6kTbT7koWVA
Body work rear right fender
https://photos.app.goo.gl/PsRfK6UcAi4wPWQ89
Front end rebuild
https://photos.app.goo.gl/eaMDSZQr7Au5bjNP8
Front struts
https://photos.app.goo.gl/XiUKzZsHTtY4HEudA
new oil level sensor and oil pan gasket, and cleaning, lots and lots of cleaning....
https://photos.app.goo.gl/jBuSuCaz2CijbZRP8
Pads and rotors, hubs
https://photos.app.goo.gl/uBrWLqMJ8gJFnHEg6
Rear shocks pads and rotors, rtabs, bushings
https://photos.app.goo.gl/gNAzXEjdyXHXafue8
Rear dbl shot
https://photos.app.goo.gl/vYLquzbuCnGFkg7Z8
old pivot bearing and throw out,
https://photos.app.goo.gl/5hXgK8ypCrSfj6DM8
New throw out, cleaned, and bass pivot
https://photos.app.goo.gl/AQkPSdjBtFk8ZXPRA
New fuel filter
https://photos.app.goo.gl/wKCjag3C7M23ncsy7
Also next big thing is need to take it in for an alignment now that I've replaced the whole front end.
What else on my list? what a labor of love, going to be nice to take the Saint Bernard to Deals Gap in soon
